I purchased 4 x VSDE drivers a few months ago.
I Have just recently finished wiring up a custom built 4 axis lathe and have begun to iron out the issues.
I have 3 x 180 Volt PMDC motors they are 4 pole and are working perfect.
I have 1 x 200 Volt (7amp peak) BLDC control techniques motor with 24 VDC brake and its having a few issues.
Ive gone through and set it all up......
It begins to turn and makes about 10 full rotations then it just feezes and doesnt go any further. Ive tried a few other VSDE in its place to confirm it wasnt the driver and they all do the same thing.
I was wondering how far down the road your firmware is for the BLDC motor or does it have some bugs.
If I was to take a guess from limited knowledge it appears as though the phases are swapping to begin the rotation but the timing goes out and causes the motor to stall. I have a 1000 CPR encoder on the top which has been tested and works fine. I can see the counts going up and down correctly in yoru diagnostics section. of GDTOOL.
