587,768 active members*
3,548 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > 20 or 25 mm for the Ballscrew Diameter?
Results 1 to 14 of 14
    Oct 2008
    9
    Hi Guys,
    I tried search the forum to decide this, but each case is a new case and I need some help.
    I'm building my cnc project. The dimensions will be 1200x800x360 mm. I'm thinking to use 25 mm ballscrews with a lead of 10 mm and belt reductions of 2-1. Additionally, I intend to use 23 kgf step motors.
    I'm undecided with the ballscrews diameter. 25 mm will be weighty to these motors and 20 mm will be just fine or not a problem?
    BEst Regards
    Paulo
    Why do you need such large diameter ball screws?
    Also what motors are you thinking of using? you say 25kgf motors, but kgf is not a measure of torque, do you mean kg-cm?
    If you mean 25Kg-cm, then this is 2.4Nm and with this you will not need anything larger than 16mm diamter?
    Is it the speed and whipping that you are worried about?
    A 16mm ball screw that is 1200 long has a critical speed of about 1100 RPM.
    Zapp Automation Ltd
    www.slidesandballscrews.com
    Oct 2008
    9
    Quote Originally Posted by Zappautomation View Post
    Thanks for your answer!
    You are correct, I wanted to say 23 kg.cm. with the reduction 2-1 it will have 46 kg.cm. BEcause of this reduction I believe that a lead of 10 mm is important.
    My machine must be robust and prepared to work with aluminum. I must say, my idea of using ballscrews with a 25 mm of diameter came from looking other projects with identical dimensions of free working area. The other reason is because a higher charge capacity ballscrew will last more.
    But I don't have any experience and sufficient knowledge...
    REgards
    Paulo
    There is no point adding a 2:1 ratio then doubling the lead of the screw, this will infact give you less thrust than going direct and having a 5mm lead on the screw.
    If we work on 2.3Nm of torque at the motor with a direct drive to the ball screw and a 5mm lead, the thrust is 59Kg.
    This is way within the capabilities of the 16mm ball screw.
    have a look at the attached file.
    Also, if the stepper motor is rated as 23Kg-cm, this is only the holding torque and the actual torque while running will be a lot lower and will depend on the driver you are using and voltage.
    Quote Originally Posted by pauloms View Post
    REgards
    Paulo
    Attached Files Attached Files
    Zapp Automation Ltd
    Oct 2008
    9
    I intend to use, for now, the cnc3ax. Then, I will see. The same for the motors. First, I want to see the machine working...
    What are the differences between SFU and SFI Ballscrews?
    REgards
    Paulo
    Only the mounting on the ball nut.
    The FSI has four holes and the FSU has six.
    REgards
    Paulo
    Zapp Automation Ltd
    Oct 2008
    9
    Thanks.
    I saw your website. I intend to use BK and BF supports. My concern is about the maintenance that the bearings of these supports need. Is this something to consider in the mechanical project to facilitate the access to the end supports? Or is the periodical maintenance (with a regular work) of several months?
    Regards
    Paulo
    The BK comes with a seal on front and back so this will stop dirt getting into the bearing.
    Generally they don’t need a lot of servicing, but if you application is particually demanding the BK is also available with a grease nipple so you can service the bearings quite easily.
    Thanks.
    Regards
    Paulo
    Zapp Automation Ltd
    Oct 2008
    9
    If I choose the normal version, will it be necessary to dismount the seals on both sides to grease the bearings?
    Regards
    Paulo
    For proper servicing grease needs to be injected between the two bearings so it goes into both bearings.
    The Q option (Grease nipple) does not cost that much more, so if ease of servicing is something you need, then this is the option for you.
    Dismantling the support unit every few months is not be an option i would suggest.
    Zapp Automation Ltd
    Jul 2007
    887
    Agreed on the reduction vs screw lead - no use in going 2:1 and doubling the lead.... However the thrust calculation seems a bit off. My calcs gives 2889N or 295kg of thrust for 2.3Nm on a 5mm lead (100% effective). (2.3 / 0.005/2PI)
    /Henrik.
    Oct 2008
    9
    Yes, I believe that the GRease nipple is important.
    But, is it not necessary to adjust the nuts (7 and 6 in the draw of BK supports) times to times?
    Regards
    Paulo
    Thanks for picking that up.
    Quote Originally Posted by H.O View Post
    /Henrik.
    Zapp Automation Ltd
    That is the locking nut and only holds the ball screw in the support, the bearings are held in with the square plate that is secured with 4 socket head screws, and you can see in the picture on the datasheet.
    It is not advised to strip and re grease the unit.
    Also the bearings are allready packed with grease at the factory.
    Regards
    Paulo
    Zapp Automation Ltd
  1. what diameter size for ballscrew?
    By 15mgtar in forum Linear and Rotary Motion
    Last Post: 09-02-2009, 09:21 AM
  2. Shaft Diameter, LeadScrew Diameter, Motor Torque?
    By cnc-newb in forum DIY CNC Router Table Machines
    Last Post: 12-24-2007, 09:51 PM
  3. Shaft Diameter, LeadScrew Diameter, Motor Torque?
    By cnc-newb in forum Uncategorised MetalWorking Machines
    Last Post: 12-15-2007, 04:25 AM
  4. rolled ballscrew minor diameter?
    By ged in forum Linear and Rotary Motion
    Last Post: 12-03-2006, 08:48 PM
  5. general ballscrew diameter for benchtop mills
    By xovationx in forum Uncategorised MetalWorking Machines
    Last Post: 03-29-2006, 04:05 PM
