587,372 active members*
3,595 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > G320X Released and Customer Appreciation Sale
Results 1 to 14 of 14
    Jan 2007
    467
    Just letting you guys know we are running our annual "Customer Appreciation Sale" right now until August 23rd, 2009. This means that all motor controls are on sale for the 100 piece price in single quantities and even more discounted in higher quantities. You can go to the product page here to see all of the prices:
    http://www.geckodrive.com/products.aspx?n=698865
    Also, we have just released our newest servo drive, the G320X. Below is a quick rundown of the new features:
    Built in step pulse multiplier
    Current mode or voltage mode servo
    Stall torque time limit
    Four settable following error limits
    Encoder fail detect
    Short circuit protection
    Dynamic motor braking during fault condition
    STEP and DIRECTION COMMON can be either +5VDC or GND
    PID trimpots with settable integral coefficient
    IN-POSITION, WARN, FAULT and POWER indicator LEDs
    STEP and DIRECTION is +3.3VDC and +5VDC compatible at 6mA
    20A 80VDC continuous operating maximum
    PID loop closed internally
    Quadrature encoder inputs
    +5VDC 50mA onboard encoder supply
    Opto-isolated STEP and DIRECTION inputs
    20kHz PWM frequency
    Settable current limit from 0A to 20A
    You can go to it's product page here:
    http://www.geckodrive.com/product.aspx?c=2&i=14474
    As always, if you have any questions just let me know either here or at [email protected]. Have a great weekend!
    Marcus
    Jun 2004
    6618
    Marcus, the 540's look to be free on the site right now. Dangit! And I just received mine today.
    Lee
    Jan 2007
    467
    Lee,
    Well, I suppose its a good thing I didn't decide to knock off early on Friday! I fixed it, and it should show up with the appropriate pricing now. Thank you for catching that!
    Marcus
    Jan 2007
    355
    Quote Originally Posted by CoAMarcus View Post
    ... This means that all motor controls are on sale for the 100 piece price in single quantities ...
    Marcus
    Marcus, I was told to never look a gift horse in the mouth, but shouldn't the G540 be sale priced at $210 instead of $240 ?
    btw, the new site loads fairly quickly on my painfully slow dialup connection.
    Thanks.
    Diplomacy is the art of saying "Nice doggie" until you can find a rock. - Will Rogers
    Jun 2008
    467
    Question
    Quote Originally Posted by Eurisko View Post
    Thanks.
    Eurisko,
    How did you come up with $210 for a G540?
    JoeyB
    A doughnut a day keeps the doctor away.
    Jul 2003
    586
    i checked the the price on the540 and was wondering if there is a different price schedule. don't get me wrong,,,great price but was not the 100 price 210 and not posted discounted price? maybe the casing and other components can't be discounted as steeply? i am hooked either way. thanx for the sale by the way.
    Oct 2004
    742
    Recommended Servos and encoders for the 320X
    Thinking about purchasing 3 of the 320X.
    What brand servos and encoders do you guys recommend for the G320X?
    I have 3 used 4000 RPM servos without encoders that I have considered using, but they are only rated at 24 VDC, (No current rating shown) and I am afraid to attempt operation at a higher voltage. Will the voltage and/or current mode allow one to operate such servos at a somewhat higher than rated voltage? With 1.5 VDC "D" battery as voltage source, I cannot apply enough pressure with my hands to stall the servo. I was told the servos were about 3 or 4 HP units.
    I am running 3ea G320's on a system with 65 VDC and 500 line encoders, and it has worked perfectly for about 4 years without a single problem. I am a fan of your drives.
    Jerry
    Mar 2007
    3
    G320X Anti-Dither Feature
    Marcus,
    Is the anti-dither feature that prevents motor groaning implemented on the G320X? It was in the early G380 spec but I don't see it as a feature on the G320X.
    Steve
    Oct 2006
    47
    Quote Originally Posted by sehast5 View Post
    Marcus,
    Steve
    I am also curious about this.
    Frank
    Nov 2003
    126
    I, too, am interested in the anti-dither feature. Is it in the 320x?
    Thanks-
    Anti-dither is not an option in the first revision (REV6) of the G320X. It will be included in the next revision.
    Anti-dither is not a panacea. That means there is a drawback for every perceived advantage. Anti-dither works by decreasing the PID coefficients by a set percentage when the motor is within a very small distance of where it should be. The drawback is it makes the servo response sluggish (detuned) over this range.
    The advantage is a nearly complete audible silence in the servomotor while it's stopped or turning slowly. The disadvantage is the servo stops trying real hard to pull in the position error to zero when it's within a few encoder counts (+/-2) of the desired position.
    Who wins in the end? I don't like to listen to noise so anti-dithering wins for me. I modified a G320X with an anti-dither circuit and it is silent; anechoic room silent kind of silent. The PID coefficients can be cranked up to be really aggressive yet be totally milk-toast when the motor position is within +/-2 counts of perfect. People who don't like this kind of sloppiness will have the option of switching the anti-dither circuit out. SW1 (presently uncommitted) will control its presence or absence.
    Mariss
    Nov 2003
    126
    Thanks for the update.
    Might be a stupid question (yes they do exist), but if I were to purchase 8x of these Rev6 G320x tomorrow, and then the anti-dither gets implemented later down the road, would the be any way to get these Rev6 units traded in or upgraded to have that feature? I would at least like to have it available for future use, even if it is not used on an axis for now.
    Thanks-
    Colin
    No. That's not how it works. A new revision means a new printed circuit board, not something that can be tacked-on afterward. It also means earlier revisions stand on their own; this is not a correction, it is an improvement.
    Most companies do not talk about future product improvements and perhaps it's a mistake that we do. They simply roll them out as a fait accompli. As an example, the G201 is in its 17th revision. There were many people that bought revision 1 and the drives have worked for them as advertised. A lot of features were added between REV1 and REV17. If we had been expected to retroactively upgrade previous versions every time a new revision came out, the G201 development would have ended with REV1.
    The G320XR6 does a heck of a lot more for the same price than the G320 ever did. The G320X is new and it will have at least as long of a product life as the G320 did; 10 years. Over that expected lifespan it will go through at least as many revisions as the G320 did. Each new revision will do more than the previous one.
    I'm just laying out the facts here because I believe most people appreciate knowing them. You as a customer have the option to purchase what is available now, or at the other extreme, to wait a few years for revision 25 or so.:-)
    Mariss
    Nov 2003
    126
    Answered my question with flying colors.
    The honesty is much appreciated.
  1. G320X First Revision Manual
    By CoAMarcus in forum Gecko Drives
    Last Post: 08-06-2009, 12:35 AM
  2. Customer Appreciation Promotion
    Last Post: 11-21-2008, 12:48 AM
  3. how to impress the customer
    By DONNYBRASS in forum MetalWork Discussion
    Last Post: 03-31-2008, 01:18 PM
  4. Looking for a new customer
    By Billmac in forum Employment Opportunity
    Last Post: 01-02-2008, 04:33 AM
  5. Customer Appreciation Sale
    By Mariss Freimanis in forum News Announcements
    Last Post: 11-10-2004, 10:52 PM
