587,833 active members*
3,440 visitors online*
Results 1 to 4 of 4
    Aug 2009
    1
    Trochoidal Milling with VF4
    I'm trying to do some trochoidal milling to mill a slot which entails simply milling circles with every circle offset with a certain stepover. The trouble is I'm having a problem with the machine "bumping" everytime the circle completes. I'm running at 200IPM with a 0.25 radius toolpath and a 0.04" stepover. I've called HAAS and they've told me to adjust setting 191 (rough-medium-finish). The rough setting is certainly the bumpiest. The finish setting is a little smoother but moslty just seems to slow the feedrate. Is there any way (adjusting a parameter perhaps?) that will allow me to smoothly run the machine in this manner?
    Sample Code:
    G00 X0 Y0
    G03 J0.25
    G01 X0.04
    G03 J0.25
    G01 X0.08
    G03 J0.25 X0.12
    etc
    4826
    I think the bumping could be due to a feedrate change switching from circular to linear interpolation, as well as the sudden change in direction. If you are doing this in CAM you could draw a path which would involve fewer changes in direction.
    Here is a snippet of code, the tool looping towards the left along the X axis. The gist of the method is to have the tool move 270° at your .250 radius, then change radius to .210 from 270 to 360, enough to provide the .040 advance. Then add a straight line to join the end of this movement with the start of the next 270° circle.
    This code sequence has a definite pattern to it that would be fairly easy to copy and paste multiple copies in a text editor, if you had to, then modify one value to advance to each loop.
    G00 X0.25 Y0. Z1.
    Z0.05
    G01 S4074 Z0. F14.6
    G03 X0. Y-0.25 I-0.25 J0.
    X0.21 Y-0.04 I0. J0.21
    G01 Y0.
    G03 X-0.04 Y-0.25 I-0.25 J0.
    X0.17 Y-0.04 I0. J0.21
    G01 Y0.
    G03 X-0.08 Y-0.25 I-0.25 J0.
    X0.13 Y-0.04 I0. J0.21
    G01 Y0.
    Jul 2005
    12177
    You can reduce the 'bumping' if you write the program to have tangential changes between the G01 and G03 and you can save a lot of time if you do not do a full circle but just use a semi-circle. You can also save a lot of coding by putting things in a subroutine and making the X incremental.
    Have a look at posts #67, 73 and 74 in this thread: http://www.cnczone.com/forums/showth...t=73902&page=4
    I subsequently re-worked the program to take out all the air cutting and cut the cycle time in half. The program I posted was before the rework but I can dig out the reworked version and post it if you like.
    Jan 2008
    282
    OK so here is how it would look from TrueMill which does write a large program for sure. I made some guessaments as to length and material. the program below is for a 1/2" slot in the center of a 2"x2" block of 1018 steel with a TiALN coated carbide 3/8" EM cutting 1/2 inch deep with a 79degree TEA. I would not program it this way by hand for sure. I am cutting at 589.SFM 6000 RPM 60 inches per minute 1/2 inch deep no coolant and the plunge is in open air. There is a finishing cut on the walls.
    Lowell
    O2079
    G90 G80 G40 G17
    (.375 EM TIALN)
    T7 M6
    S6000 M3
    G0 G90 G59 X0.3875 Y-1.0567
    G43 Z1. H7 M8
    G0 Z0.1
    G1 Z-0.495 F81.5
    G3 X0.2875 Y-0.9567 Z-0.5 I-0.1 J0 F60.0
    G1 X0.2316
    G3 X0.1745 Y-0.9746 I0 J-0.1
    X0.1702 Y-0.9782 I0.0187 J-0.0268
    X0.1605 Y-1.0013 I0.023 J-0.0232
    X0.1701 Y-1.0245 I0.0327 J-0.0001
    X0.1745 Y-1.0282 I0.0231 J0.0231
    X0.2875 Y-1.0637 I0.113 J0.1623
    G1 Y-0.9687 Z-0.495 F200.0
    X0.1745 Z-0.5 F60.0
    X0.1705
    G3 X0.1474 Y-0.9782 I-0.0001 J-0.0327
    X0.1377 Y-1.0013 I0.023 J-0.0232
    X0.1472 Y-1.0244 I0.0327 J-0.0001
    X0.1703 Y-1.0341 I0.0232 J0.023
    G1 X0.1745
    X0.2875
    X0.2152 Y-1.0134 Z-0.495 F200.0
    G3 X0.2021 Y-0.9818 Z-0.4975 I-0.0447 J0
    X0.1705 Y-0.9687 Z-0.5 I-0.0316 J-0.0316 F60.0
    G1 X0.148
    G3 X0.1249 Y-0.9782 I-0.0001 J-0.0327
    X0.1152 Y-1.0013 I0.023 J-0.0232
    X0.1247 Y-1.0244 I0.0327 J-0.0001
    X0.1478 Y-1.034 I0.0232 J0.023
    G1 X0.1703 Y-1.0341
    G3 X0.1893 Y-1.0241 Z-0.495 I0.0001 J0.0231
    X0.1854 Y-0.9936 I-0.0189 J0.0131 F200.0
    G1 X0.1681 Y-0.9787
    X0.163 Y-0.9743 Z-0.4965 F60.0
    G3 X0.148 Y-0.9687 Z-0.5 I-0.015 J-0.0174
    G1 X0.1258
    G3 X0.1026 Y-0.9782 I-0.0002 J-0.0327
    X0.093 Y-1.0013 I0.023 J-0.0232
    X0.1025 Y-1.0244 I0.0326 J-0.0001
    X0.1256 Y-1.034 I0.0231 J0.023
    G1 X0.1478
    G3 X0.1668 Y-1.0241 Z-0.495 I0.0001 J0.023
    X0.163 Y-0.9938 I-0.0189 J0.0131 F200.0
    G1 X0.1458 Y-0.9787
    X0.1409 Y-0.9744 Z-0.4964 F60.0
    G3 X0.1258 Y-0.9687 Z-0.5 I-0.0151 J-0.0173
    G1 X0.1038
    G3 X0.0807 Y-0.9782 I-0.0001 J-0.0326
    X0.071 Y-1.0013 I0.023 J-0.0231
    X0.0805 Y-1.0244 I0.0327 J0
    X0.1036 Y-1.034 I0.0232 J0.0231
    G1 X0.1256
    G3 X0.1446 Y-1.024 Z-0.495 I0 J0.0229
    X0.1409 Y-0.9939 I-0.019 J0.0129 F200.0
    G1 X0.1238 Y-0.9787
    X0.119 Y-0.9745 Z-0.4964 F60.0
    G3 X0.1038 Y-0.9687 Z-0.5 I-0.0152 J-0.0172
    G1 X0.0821
    G3 X0.0589 Y-0.9782 I-0.0002 J-0.0326
    X0.0493 Y-1.0013 I0.023 J-0.0231
    X0.0588 Y-1.0244 I0.0326 J0
    X0.0819 Y-1.034 I0.0231 J0.0231
    G1 X0.1036
    G3 X0.1226 Y-1.024 Z-0.495 I0 J0.0229
    X0.119 Y-0.994 I-0.019 J0.0129 F200.0
    G1 X0.102 Y-0.9787
    X0.0974 Y-0.9746 Z-0.4963 F60.0
    G3 X0.0821 Y-0.9687 Z-0.5 I-0.0153 J-0.017
    G1 X0.0606
    G3 X0.0375 Y-0.9782 I-0.0001 J-0.0326
    X0.0279 Y-1.0012 I0.023 J-0.0231
    X0.0374 Y-1.0243 I0.0326 J-0.0001
    X0.0604 Y-1.0339 I0.0231 J0.023
    G1 X0.0819 Y-1.034
    G3 X0.1008 Y-1.024 Z-0.495 I0 J0.0229
    X0.0973 Y-0.9942 I-0.0189 J0.0129 F200.0
    G1 X0.0804 Y-0.9787
    X0.076 Y-0.9747 Z-0.4963 F60.0
    G3 X0.0606 Y-0.9687 Z-0.5 I-0.0154 J-0.0169
    G1 X0.0394
    G3 X0.0163 Y-0.9782 I-0.0002 J-0.0326
    X0.0066 Y-1.0012 I0.0229 J-0.0231
    X0.0162 Y-1.0243 I0.0326 J-0.0001
    X0.0392 Y-1.0339 I0.023 J0.023
    G1 X0.0604
    G3 X0.0793 Y-1.024 Z-0.495 I0.0001 J0.0228
    X0.076 Y-0.9943 I-0.0188 J0.0129 F200.0
    G1 X0.0591 Y-0.9787
    X0.0549 Y-0.9748 Z-0.4963 F60.0
    G3 X0.0394 Y-0.9687 Z-0.5 I-0.0155 J-0.0168
    G1 X0.0166
    G3 X-0.0064 Y-0.9782 I-0.0001 J-0.0326
    X-0.0161 Y-1.0012 I0.0229 J-0.0231
    X-0.0066 Y-1.0243 I0.0326 J-0.0001
    X0.0165 Y-1.0339 I0.0231 J0.023
    G1 X0.0392
    G3 X0.0582 Y-1.0239 Z-0.495 I0 J0.023
    X0.0541 Y-0.9934 I-0.019 J0.013 F200.0
    G1 X0.0369 Y-0.9787
    X0.0315 Y-0.9742 Z-0.4965 F60.0
    G3 X0.0166 Y-0.9687 Z-0.5 I-0.0149 J-0.0175
    G1 X-0.0058
    G3 X-0.0289 Y-0.9782 I-0.0001 J-0.0326
    X-0.0385 Y-1.0012 I0.023 J-0.0231
    X-0.029 Y-1.0243 I0.0326 J-0.0001
    X-0.0059 Y-1.0339 I0.0231 J0.023
    G1 X0.0165
    G3 X0.0355 Y-1.0239 Z-0.495 I0 J0.023
    X0.0315 Y-0.9935 I-0.019 J0.013 F200.0
    G1 X0.0143 Y-0.9787
    X0.0092 Y-0.9743 Z-0.4965 F60.0
    G3 X-0.0058 Y-0.9687 Z-0.5 I-0.015 J-0.0174
    G1 X-0.0279
    G3 X-0.051 Y-0.9782 I-0.0001 J-0.0326
    X-0.0606 Y-1.0012 I0.023 J-0.0231
    X-0.0511 Y-1.0243 I0.0326 J-0.0001
    X-0.0281 Y-1.0338 I0.0231 J0.023
    G1 X-0.0059 Y-1.0339
    G3 X0.013 Y-1.0239 Z-0.495 I0 J0.023
    X0.0092 Y-0.9937 I-0.0189 J0.013 F200.0
    G1 X-0.0079 Y-0.9787
    X-0.0128 Y-0.9744 Z-0.4964 F60.0
    G3 X-0.0279 Y-0.9687 Z-0.5 I-0.0151 J-0.0172
    G1 X-0.0498
    G3 X-0.0729 Y-0.9782 I-0.0001 J-0.0325
    X-0.0825 Y-1.0012 I0.023 J-0.023
    X-0.073 Y-1.0242 I0.0326 J0
    X-0.0499 Y-1.0338 I0.0231 J0.023
    G1 X-0.0281
    G3 X-0.0091 Y-1.0239 Z-0.495 I0.0001 J0.0229
    X-0.0128 Y-0.9938 I-0.0189 J0.013 F200.0
    G1 X-0.0298 Y-0.9787
    X-0.0346 Y-0.9745 Z-0.4964 F60.0
    G3 X-0.0498 Y-0.9687 Z-0.5 I-0.0152 J-0.0171
    G1 X-0.073
    G3 X-0.0961 Y-0.9781 I-0.0001 J-0.0325
    X-0.1057 Y-1.0012 I0.023 J-0.0231
    X-0.0962 Y-1.0242 I0.0326 J0
    X-0.0732 Y-1.0338 I0.0231 J0.023
    G1 X-0.0499
    G3 X-0.0309 Y-1.0238 Z-0.495 I0 J0.023
    X-0.0353 Y-0.993 I-0.019 J0.013 F200.0
    G1 X-0.0526 Y-0.9787
    X-0.0584 Y-0.9739 Z-0.4966 F60.0
    G3 X-0.073 Y-0.9687 Z-0.5 I-0.0146 J-0.0178
    G1 X-0.096
    G3 X-0.119 Y-0.9781 I-0.0001 J-0.0325
    X-0.1286 Y-1.0011 I0.0229 J-0.0231
    X-0.1191 Y-1.0242 I0.0325 J-0.0001
    X-0.0961 Y-1.0338 I0.023 J0.023
    G1 X-0.0732
    G3 X-0.0542 Y-1.0238 Z-0.495 I0 J0.023
    X-0.0584 Y-0.9932 I-0.019 J0.013 F200.0
    G1 X-0.0757 Y-0.9787
    X-0.0812 Y-0.974 Z-0.4966 F60.0
    G3 X-0.096 Y-0.9687 Z-0.5 I-0.0148 J-0.0177
    G1 X-0.1186
    G3 X-0.1416 Y-0.9781 I-0.0001 J-0.0325
    X-0.1512 Y-1.0011 I0.0229 J-0.0231
    X-0.1417 Y-1.0242 I0.0325 J-0.0001
    X-0.1187 Y-1.0337 I0.023 J0.023
    G1 X-0.0961 Y-1.0338
    G3 X-0.0771 Y-1.0238 Z-0.495 I0 J0.023
    X-0.0812 Y-0.9933 I-0.019 J0.013 F200.0
    G1 X-0.0984 Y-0.9787
    X-0.1037 Y-0.9741 Z-0.4965 F60.0
    G3 X-0.1186 Y-0.9687 Z-0.5 I-0.0149 J-0.0175
    G1 X-0.1409
    G3 X-0.1639 Y-0.9781 I-0.0001 J-0.0325
    X-0.1735 Y-1.0011 I0.0229 J-0.0231
    X-0.164 Y-1.0241 I0.0325 J-0.0001
    X-0.141 Y-1.0337 I0.023 J0.0229
    G1 X-0.1187
    G3 X-0.0998 Y-1.0238 Z-0.495 I0 J0.0229
    X-0.1037 Y-0.9935 I-0.0189 J0.013 F200.0
    G1 X-0.1208 Y-0.9787
    X-0.1259 Y-0.9743 Z-0.4965 F60.0
    G3 X-0.1409 Y-0.9687 Z-0.5 I-0.015 J-0.0173
    G1 X-0.1629
    G3 X-0.1859 Y-0.9781 I-0.0001 J-0.0325
    X-0.1955 Y-1.0011 I0.0229 J-0.0231
    X-0.186 Y-1.0241 I0.0325 J-0.0001
    X-0.163 Y-1.0337 I0.023 J0.0229
    G1 X-0.141
    G3 X-0.1221 Y-1.0237 Z-0.495 I0 J0.0229
    X-0.1259 Y-0.9937 I-0.0189 J0.0129 F200.0
    G1 X-0.1429 Y-0.9787
    X-0.1478 Y-0.9744 Z-0.4964 F60.0
    G3 X-0.1629 Y-0.9687 Z-0.5 I-0.0151 J-0.0171
    G1 X-0.1846 Y-0.9686
    G3 X-0.2076 Y-0.9781 I-0.0001 J-0.0326
    X-0.2172 Y-1.0011 I0.0229 J-0.0231
    X-0.2077 Y-1.0241 I0.0325 J-0.0001
    X-0.1847 Y-1.0337 I0.023 J0.0229
    G1 X-0.163
    G3 X-0.1441 Y-1.0237 Z-0.495 I0 J0.0229
    X-0.1477 Y-0.9938 I-0.0189 J0.0129 F200.0
    G1 X-0.1647 Y-0.9786
    X-0.1694 Y-0.9745 Z-0.4964 F60.0
    G3 X-0.1846 Y-0.9686 Z-0.5 I-0.0152 J-0.017
    G1 X-0.206
    G3 X-0.229 Y-0.9781 I-0.0001 J-0.0325
    X-0.2386 Y-1.0011 I0.0229 J-0.023
    X-0.2291 Y-1.0241 I0.0325 J0
    X-0.2061 Y-1.0336 I0.023 J0.023
    G1 X-0.1847 Y-1.0337
    G3 X-0.1658 Y-1.0237 Z-0.495 I0 J0.0228
    X-0.1693 Y-0.994 I-0.0189 J0.0128 F200.0
    G1 X-0.1862 Y-0.9786
    X-0.1906 Y-0.9746 Z-0.4963 F60.0
    G3 X-0.206 Y-0.9686 Z-0.5 I-0.0154 J-0.0168
    G1 X-0.2271
    G3 X-0.2501 Y-0.9781 I-0.0001 J-0.0325
    X-0.2597 Y-1.0011 I0.0229 J-0.023
    X-0.2502 Y-1.0241 I0.0325 J0
    X-0.2272 Y-1.0336 I0.023 J0.023
    G1 X-0.2061
    G3 X-0.1872 Y-1.0237 Z-0.495 I0 J0.0227
    X-0.1906 Y-0.9942 I-0.0189 J0.0128 F200.0
    G1 X-0.2074 Y-0.9786
    X-0.2116 Y-0.9747 Z-0.4963 F60.0
    G3 X-0.2271 Y-0.9686 Z-0.5 I-0.0155 J-0.0167
    G1 X-0.2494
    G3 X-0.2724 Y-0.9781 I-0.0001 J-0.0325
    X-0.282 Y-1.0011 I0.0229 J-0.023
    X-0.2725 Y-1.024 I0.0325 J0
    X-0.2495 Y-1.0336 I0.023 J0.0229
    G1 X-0.2272
    G3 X-0.2083 Y-1.0236 Z-0.495 I0 J0.0229
    X-0.2122 Y-0.9934 I-0.0189 J0.0129 F200.0
    G1 X-0.2293 Y-0.9786
    X-0.2345 Y-0.9742 Z-0.4965 F60.0
    G3 X-0.2494 Y-0.9686 Z-0.5 I-0.0149 J-0.0173
    G1 X-0.2714
    G3 X-0.2944 Y-0.9781 I-0.0001 J-0.0325
    X-0.3039 Y-1.001 I0.0229 J-0.023
    X-0.2945 Y-1.024 I0.0324 J-0.0001
    X-0.2715 Y-1.0336 I0.023 J0.0229
    G1 X-0.2495
    G3 X-0.2306 Y-1.0236 Z-0.495 I0 J0.0229
    X-0.2344 Y-0.9936 I-0.0189 J0.0129 F200.0
    G1 X-0.2514 Y-0.9786
    X-0.2563 Y-0.9743 Z-0.4964 F60.0
    G3 X-0.2714 Y-0.9686 Z-0.5 I-0.0151 J-0.0172
    G1 X-0.2945
    G3 X-0.3175 Y-0.9781 I-0.0001 J-0.0325
    X-0.327 Y-1.001 I0.0229 J-0.023
    X-0.3176 Y-1.024 I0.0324 J-0.0001
    X-0.2946 Y-1.0335 I0.023 J0.0229
    G1 X-0.2715 Y-1.0336
    G3 X-0.2525 Y-1.0236 Z-0.495 I0 J0.023
    X-0.2569 Y-0.9929 I-0.019 J0.013 F200.0
    G1 X-0.2741 Y-0.9786
    X-0.2799 Y-0.9739 Z-0.4966 F60.0
    G3 X-0.2945 Y-0.9686 Z-0.5 I-0.0146 J-0.0177
    G1 X-0.3172
    G3 X-0.3402 Y-0.9781 I-0.0001 J-0.0325
    X-0.3498 Y-1.001 I0.0229 J-0.023
    X-0.3403 Y-1.024 I0.0325 J-0.0001
    X-0.3174 Y-1.0335 I0.023 J0.0229
    G1 X-0.2946
    G3 X-0.2757 Y-1.0236 Z-0.495 I0 J0.0229
    X-0.2798 Y-0.9931 I-0.0189 J0.013 F200.0
    G1 X-0.297 Y-0.9786
    X-0.3025 Y-0.974 Z-0.4965 F60.0
    G3 X-0.3172 Y-0.9686 Z-0.5 I-0.0148 J-0.0175
    G1 X-0.3396
    G3 X-0.3626 Y-0.9781 I-0.0001 J-0.0325
    X-0.3721 Y-1.001 I0.0229 J-0.023
    X-0.3627 Y-1.024 I0.0324 J-0.0001
    X-0.3397 Y-1.0335 I0.023 J0.0229
    G1 X-0.3174
    G3 X-0.2984 Y-1.0235 Z-0.495 I0.0001 J0.0229
    X-0.3024 Y-0.9933 I-0.0189 J0.0129 F200.0
    G1 X-0.3195 Y-0.9786
    X-0.3247 Y-0.9741 Z-0.4965 F60.0
    G3 X-0.3396 Y-0.9686 Z-0.5 I-0.0149 J-0.0174
    G1 X-0.3617
    G3 X-0.3846 Y-0.9781 I0 J-0.0324
    X-0.3942 Y-1.001 I0.0229 J-0.0229
    X-0.3847 Y-1.0239 I0.0325 J0
    X-0.3618 Y-1.0335 I0.023 J0.0229
    G1 X-0.3397
    G3 X-0.3208 Y-1.0235 Z-0.495 I0 J0.0228
    X-0.3247 Y-0.9935 I-0.0189 J0.0128 F200.0
    G1 X-0.3417 Y-0.9786
    X-0.3466 Y-0.9743 Z-0.4964 F60.0
    G3 X-0.3617 Y-0.9686 Z-0.5 I-0.0151 J-0.0171
    G1 X-0.3834
    G3 X-0.4063 Y-0.9781 I0 J-0.0324
    X-0.4159 Y-1.001 I0.0229 J-0.0229
    X-0.4064 Y-1.0239 I0.0325 J0
    X-0.3835 Y-1.0334 I0.023 J0.0229
    G1 X-0.3618 Y-1.0335
    G3 X-0.3429 Y-1.0235 Z-0.495 I0.0001 J0.0228
    X-0.3466 Y-0.9937 I-0.0188 J0.0128 F200.0
    G1 X-0.3635 Y-0.9786
    X-0.3682 Y-0.9744 Z-0.4964 F60.0
    G3 X-0.3834 Y-0.9686 Z-0.5 I-0.0152 J-0.017
    G1 X-0.4047
    G3 X-0.4277 Y-0.9781 I-0.0001 J-0.0324
    X-0.4372 Y-1.001 I0.0229 J-0.0229
    X-0.4277 Y-1.0239 I0.0324 J0
    X-0.4048 Y-1.0334 I0.0229 J0.0229
    G1 X-0.3835
    G3 X-0.3646 Y-1.0235 Z-0.495 I0.0001 J0.0227
    X-0.3681 Y-0.9939 I-0.0188 J0.0128 F200.0
    G1 X-0.3849 Y-0.9786
    X-0.3894 Y-0.9745 Z-0.4963 F60.0
    G3 X-0.4047 Y-0.9686 Z-0.5 I-0.0153 J-0.0168
    G1 X-0.4257
    G3 X-0.4487 Y-0.978 I-0.0001 J-0.0324
    X-0.4582 Y-1.0009 I0.0229 J-0.023
    X-0.4487 Y-1.0239 I0.0324 J-0.0001
    X-0.4258 Y-1.0334 I0.0229 J0.0229
    G1 X-0.4048
    G3 X-0.386 Y-1.0234 Z-0.495 I0 J0.0227
    X-0.3894 Y-0.9941 I-0.0188 J0.0127 F200.0
    G1 X-0.406 Y-0.9786
    X-0.4103 Y-0.9746 Z-0.4963 F60.0
    G3 X-0.4257 Y-0.9686 Z-0.5 I-0.0155 J-0.0167
    G1 X-0.449
    G3 X-0.472 Y-0.978 I-0.0001 J-0.0324
    X-0.4815 Y-1.0009 I0.0229 J-0.023
    X-0.472 Y-1.0239 I0.0324 J-0.0001
    X-0.4491 Y-1.0334 I0.0229 J0.0229
    G1 X-0.4258
    G3 X-0.4069 Y-1.0234 Z-0.495 I0 J0.0229
    X-0.4113 Y-0.9927 I-0.0189 J0.0129 F200.0
    G1 X-0.4286 Y-0.9786
    X-0.4345 Y-0.9737 Z-0.4966 F60.0
    G3 X-0.449 Y-0.9686 Z-0.5 I-0.0145 J-0.0178
    G1 X-0.4719
    G3 X-0.4948 Y-0.978 I0 J-0.0324
    X-0.5043 Y-1.0009 I0.0229 J-0.023
    X-0.4949 Y-1.0238 I0.0324 J-0.0001
    X-0.472 Y-1.0333 I0.023 J0.0228
    G1 X-0.4491 Y-1.0334
    G3 X-0.4302 Y-1.0234 Z-0.495 I0 J0.0229
    X-0.4344 Y-0.9929 I-0.0189 J0.0129 F200.0
    G1 X-0.4516 Y-0.9786
    X-0.4572 Y-0.9739 Z-0.4966 F60.0
    G3 X-0.4719 Y-0.9686 Z-0.5 I-0.0147 J-0.0176
    G1 X-0.4944
    G3 X-0.5173 Y-0.978 I0 J-0.0323
    X-0.5268 Y-1.0009 I0.0229 J-0.0229
    X-0.5173 Y-1.0238 I0.0324 J0
    X-0.4944 Y-1.0333 I0.0229 J0.0229
    G1 X-0.472
    G3 X-0.4531 Y-1.0234 Z-0.495 I0 J0.0228
    X-0.4571 Y-0.9931 I-0.0189 J0.0129 F200.0
    G1 X-0.4742 Y-0.9786
    X-0.4796 Y-0.974 Z-0.4965 F60.0
    G3 X-0.4944 Y-0.9686 Z-0.5 I-0.0148 J-0.0174
    G1 X-0.5164
    G3 X-0.5393 Y-0.978 I-0.0001 J-0.0323
    X-0.5488 Y-1.0009 I0.0228 J-0.0229
    X-0.5394 Y-1.0238 I0.0323 J0
    X-0.5165 Y-1.0333 I0.0229 J0.0229
    G1 X-0.4944
    G3 X-0.4756 Y-1.0233 Z-0.495 I0 J0.0228
    X-0.4795 Y-0.9933 I-0.0188 J0.0128 F200.0
    G1 X-0.4964 Y-0.9786
    X-0.5015 Y-0.9742 Z-0.4965 F60.0
    G3 X-0.5164 Y-0.9686 Z-0.5 I-0.0149 J-0.0172
    G1 X-0.5381
    G3 X-0.561 Y-0.978 I-0.0001 J-0.0323
    X-0.5705 Y-1.0009 I0.0228 J-0.0229
    X-0.5611 Y-1.0238 I0.0323 J0
    X-0.5382 Y-1.0333 I0.0229 J0.0229
    G1 X-0.5165
    G3 X-0.4977 Y-1.0233 Z-0.495 I0 J0.0227
    X-0.5014 Y-0.9935 I-0.0188 J0.0127 F200.0
    G1 X-0.5182 Y-0.9786
    X-0.523 Y-0.9743 Z-0.4964 F60.0
    G3 X-0.5381 Y-0.9686 Z-0.5 I-0.0151 J-0.017
    G1 X-0.5594
    G3 X-0.5595 Y-1.0333 I-0.0001 J-0.0323
    G1 X-0.5382
    G3 X-0.5194 Y-1.0233 Z-0.495 I0 J0.0227
    X-0.5229 Y-0.9938 I-0.0188 J0.0127 F200.0
    G1 X-0.5397 Y-0.9786
    X-0.5442 Y-0.9745 Z-0.4963 F60.0
    G3 X-0.5594 Y-0.9686 Z-0.5 I-0.0152 J-0.0168
    G1 X-0.5827 Y-0.9685
    G3 X-0.5828 Y-1.0332 I0 J-0.0324
    G1 X-0.5595 Y-1.0333
    G3 X-0.5406 Y-1.0233 Z-0.495 I0 J0.023
    X-0.545 Y-0.9926 I-0.0189 J0.013 F200.0
    G1 X-0.5623 Y-0.9785
    X-0.5682 Y-0.9737 Z-0.4966 F60.0
    G3 X-0.5827 Y-0.9685 Z-0.5 I-0.0145 J-0.0178
    G1 X-0.6055
    G3 X-0.6056 Y-1.0332 I0 J-0.0324
    G1 X-0.5828
    G3 X-0.5638 Y-1.0233 Z-0.495 I0.0001 J0.0228
    X-0.5681 Y-0.9928 I-0.0189 J0.0129 F200.0
    G1 X-0.5852 Y-0.9786
    X-0.5909 Y-0.9738 Z-0.4966 F60.0
    G3 X-0.6055 Y-0.9685 Z-0.5 I-0.0146 J-0.0176
    G1 X-0.6278
    G3 X-0.6279 Y-1.0332 I-0.0001 J-0.0324
    G1 X-0.6056
    G3 X-0.5867 Y-1.0232 Z-0.495 I0.0001 J0.0228
    X-0.5907 Y-0.9931 I-0.0188 J0.0128 F200.0
    G1 X-0.6077 Y-0.9785
    X-0.613 Y-0.974 Z-0.4965 F60.0
    G3 X-0.6278 Y-0.9685 Z-0.5 I-0.0148 J-0.0173
    G1 X-0.6498
    G3 Y-1.0332 I0 J-0.0323
    G1 X-0.6279
    G3 X-0.6091 Y-1.0232 Z-0.495 I0 J0.0228
    X-0.6129 Y-0.9933 I-0.0188 J0.0128 F200.0
    G1 X-0.6298 Y-0.9785
    X-0.6348 Y-0.9742 Z-0.4964 F60.0
    G3 X-0.6498 Y-0.9685 Z-0.5 I-0.015 J-0.0171
    G1 X-0.6713
    G3 Y-1.0331 I0 J-0.0323
    G1 X-0.6498 Y-1.0332
    G3 X-0.631 Y-1.0232 Z-0.495 I0 J0.0227
    X-0.6346 Y-0.9936 I-0.0188 J0.0127 F200.0
    G1 X-0.6514 Y-0.9785
    X-0.6561 Y-0.9743 Z-0.4964 F60.0
    G3 X-0.6713 Y-0.9685 Z-0.5 I-0.0152 J-0.0169
    G1 X-0.6923
    G3 X-0.6924 Y-1.0331 I0 J-0.0323
    G1 X-0.6713
    G3 X-0.6525 Y-1.0232 Z-0.495 I0 J0.0226
    X-0.656 Y-0.9938 I-0.0188 J0.0127 F200.0
    G1 X-0.6726 Y-0.9785
    X-0.677 Y-0.9745 Z-0.4963 F60.0
    G3 X-0.6923 Y-0.9685 Z-0.5 I-0.0153 J-0.0167
    G1 X-0.7151
    G1 X-0.6924
    G3 X-0.6735 Y-1.0231 Z-0.495 I0 J0.0228
    X-0.6777 Y-0.9928 I-0.0189 J0.0128 F200.0
    G1 X-0.6948 Y-0.9785
    X-0.7004 Y-0.9738 Z-0.4966 F60.0
    G3 X-0.7151 Y-0.9685 Z-0.5 I-0.0147 J-0.0175
    G1 X-0.7373
    G1 X-0.7151
    G3 X-0.6962 Y-1.0231 Z-0.495 I0 J0.0228
    X-0.7003 Y-0.993 I-0.0189 J0.0128 F200.0
    G1 X-0.7172 Y-0.9785
    X-0.7225 Y-0.974 Z-0.4965 F60.0
    G3 X-0.7373 Y-0.9685 Z-0.5 I-0.0148 J-0.0173
    G1 X-0.7591
    G3 Y-1.033 I0 J-0.0323
    G1 X-0.7373 Y-1.0331
    G3 X-0.7185 Y-1.0231 Z-0.495 I0 J0.0227
    X-0.7223 Y-0.9933 I-0.0188 J0.0127 F200.0
    G1 X-0.7391 Y-0.9785
    X-0.7441 Y-0.9742 Z-0.4964 F60.0
    G3 X-0.7591 Y-0.9685 Z-0.5 I-0.015 J-0.017
    G1 X-0.7812
    X-0.7823
    G1 X-0.7812
    X-0.7591
    G3 X-0.7402 Y-1.0231 Z-0.495 I0 J0.0228
    X-0.7447 Y-0.9924 I-0.0189 J0.0129 F200.0
    G1 X-0.7618 Y-0.9785
    X-0.7679 Y-0.9736 Z-0.4967 F60.0
    G3 X-0.7823 Y-0.9685 Z-0.5 I-0.0144 J-0.0178
    G1 X-0.805
    G3 Y-1.033 I0 J-0.0322
    G1 X-0.7823
    G3 X-0.7634 Y-1.023 Z-0.495 I0 J0.0228
    X-0.7677 Y-0.9927 I-0.0189 J0.0128 F200.0
    G1 X-0.7847 Y-0.9785
    X-0.7904 Y-0.9738 Z-0.4966 F60.0
    G3 X-0.805 Y-0.9685 Z-0.5 I-0.0146 J-0.0175
    G1 X-0.8271
    G3 X-0.8272 Y-1.033 I0 J-0.0322
    G1 X-0.805
    G3 X-0.7862 Y-1.023 Z-0.495 I0 J0.0227
    X-0.7902 Y-0.993 I-0.0188 J0.0127 F200.0
    G1 X-0.8071 Y-0.9785
    X-0.8123 Y-0.974 Z-0.4965 F60.0
    G3 X-0.8271 Y-0.9685 Z-0.5 I-0.0148 J-0.0172
    G1 X-0.8487
    G3 X-0.8489 Y-1.033 I0 J-0.0322
    G1 X-0.8272
    G3 X-0.8084 Y-1.023 Z-0.495 I0 J0.0227
    X-0.8121 Y-0.9934 I-0.0188 J0.0127 F200.0
    G1 X-0.8289 Y-0.9785
    X-0.8337 Y-0.9742 Z-0.4964 F60.0
    G3 X-0.8487 Y-0.9685 Z-0.5 I-0.015 J-0.0169
    G1 X-0.8699
    G3 X-0.87 Y-1.0329 I0 J-0.0322
    G1 X-0.8489 Y-1.033
    G3 X-0.8301 Y-1.023 Z-0.495 I0 J0.0227
    X-0.8336 Y-0.9937 I-0.0188 J0.0127 F200.0
    G1 X-0.8501 Y-0.9785
    X-0.8546 Y-0.9744 Z-0.4963 F60.0
    G3 X-0.8699 Y-0.9685 Z-0.5 I-0.0153 J-0.0167
    G1 X-0.8922 Y-0.9684
    G3 X-0.8924 Y-1.0329 I0 J-0.0323
    G1 X-0.87
    G3 X-0.8512 Y-1.023 Z-0.495 I0 J0.0227
    X-0.8552 Y-0.9929 I-0.0188 J0.0128 F200.0
    G1 X-0.8721 Y-0.9784
    X-0.8774 Y-0.9739 Z-0.4965 F60.0
    G3 X-0.8922 Y-0.9684 Z-0.5 I-0.0148 J-0.0173
    G1 X-0.914
    G3 X-0.9142 Y-1.0329 I0 J-0.0323
    G1 X-0.8924
    G3 X-0.8736 Y-1.0229 Z-0.495 I0 J0.0227
    X-0.8774 Y-0.9933 I-0.0188 J0.0127 F200.0
    G1 X-0.8941 Y-0.9784
    X-0.899 Y-0.9741 Z-0.4964 F60.0
    G3 X-0.914 Y-0.9684 Z-0.5 I-0.015 J-0.017
    G1 X-0.9368
    G3 X-0.9371 Y-1.0329 I-0.0001 J-0.0322
    G1 X-0.9142
    G3 X-0.8954 Y-1.0229 Z-0.495 I0 J0.0228
    X-0.8996 Y-0.9926 I-0.0188 J0.0128 F200.0
    G1 X-0.9166 Y-0.9784
    X-0.9223 Y-0.9737 Z-0.4966 F60.0
    G3 X-0.9368 Y-0.9684 Z-0.5 I-0.0146 J-0.0175
    G1 X-0.9591
    G3 X-0.9594 Y-1.0329 I0 J-0.0322
    G1 X-0.9371
    G3 X-0.9183 Y-1.0229 Z-0.495 I0 J0.0227
    X-0.9222 Y-0.993 I-0.0188 J0.0127 F200.0
    G1 X-0.9391 Y-0.9784
    X-0.9442 Y-0.974 Z-0.4965 F60.0
    G3 X-0.9591 Y-0.9684 Z-0.5 I-0.0149 J-0.0171
    G1 X-0.9807
    G3 X-0.981 Y-1.0328 I0 J-0.0322
    G1 X-0.9594 Y-1.0329
    G3 X-0.9406 Y-1.0229 Z-0.495 I0 J0.0227
    X-0.9442 Y-0.9934 I-0.0188 J0.0127 F200.0
    G1 X-0.9609 Y-0.9784
    X-0.9656 Y-0.9742 Z-0.4964 F60.0
    G3 X-0.9807 Y-0.9684 Z-0.5 I-0.0151 J-0.0168
    G1 X-1.0017
    G3 X-1.0021 Y-1.0328 I0 J-0.0322
    G1 X-0.981
    G3 X-0.9623 Y-1.0229 Z-0.495 I0 J0.0225
    X-0.9656 Y-0.9938 I-0.0187 J0.0126 F200.0
    G1 X-0.9821 Y-0.9784
    X-0.9864 Y-0.9744 Z-0.4963 F60.0
    G3 X-1.0017 Y-0.9684 Z-0.5 I-0.0154 J-0.0166
    G1 X-1.0237
    G3 X-1.024 Y-1.0328 I0 J-0.0322
    G1 X-1.0021
    G3 X-0.9833 Y-1.0228 Z-0.495 I0 J0.0226
    X-0.9871 Y-0.9932 I-0.0188 J0.0126 F200.0
    G1 X-1.0038 Y-0.9784
    X-1.0086 Y-0.9741 Z-0.4964 F60.0
    G3 X-1.0237 Y-0.9684 Z-0.5 I-0.0151 J-0.0169
    G1 X-1.0464
    G3 X-1.0468 Y-1.0328 I0 J-0.0322
    G1 X-1.024
    G3 X-1.0052 Y-1.0228 Z-0.495 I0 J0.0227
    X-1.0093 Y-0.9927 I-0.0188 J0.0127 F200.0
    G1 X-1.0262 Y-0.9784
    X-1.0317 Y-0.9738 Z-0.4965 F60.0
    G3 X-1.0464 Y-0.9684 Z-0.5 I-0.0147 J-0.0173
    G1 X-1.0683
    G3 X-1.0688 Y-1.0328 I-0.0001 J-0.0322
    G1 X-1.0468
    G3 X-1.028 Y-1.0228 Z-0.495 I0 J0.0227
    X-1.0317 Y-0.9932 I-0.0188 J0.0127 F200.0
    G1 X-1.0485 Y-0.9784
    X-1.0533 Y-0.974 Z-0.4964 F60.0
    G3 X-1.0683 Y-0.9684 Z-0.5 I-0.0151 J-0.017
    G1 X-1.0896 Y-0.9683
    G3 X-1.0901 Y-1.0327 I-0.0001 J-0.0322
    G1 X-1.0688 Y-1.0328
    G3 X-1.05 Y-1.0228 Z-0.495 I0 J0.0226
    X-1.0535 Y-0.9936 I-0.0188 J0.0126 F200.0
    G1 X-1.07 Y-0.9784
    X-1.0743 Y-0.9743 Z-0.4963 F60.0
    G3 X-1.0896 Y-0.9683 Z-0.5 I-0.0154 J-0.0166
    G1 X-1.1129
    G3 X-1.1134 Y-1.0327 I0 J-0.0322
    G1 X-1.0901
    G3 X-1.0713 Y-1.0228 Z-0.495 I0 J0.0227
    X-1.0756 Y-0.9924 I-0.0188 J0.0128 F200.0
    G1 X-1.0926 Y-0.9783
    X-1.0983 Y-0.9736 Z-0.4966 F60.0
    G3 X-1.1129 Y-0.9683 Z-0.5 I-0.0146 J-0.0175
    G1 X-1.1353
    G3 X-1.1358 Y-1.0327 I0 J-0.0322
    G1 X-1.1134
    G3 X-1.0946 Y-1.0227 Z-0.495 I0 J0.0227
    X-1.0985 Y-0.9929 I-0.0188 J0.0127 F200.0
    G1 X-1.1153 Y-0.9783
    X-1.1204 Y-0.9739 Z-0.4965 F60.0
    G3 X-1.1353 Y-0.9683 Z-0.5 I-0.0149 J-0.0171
    G1 X-1.1569
    G3 X-1.1575 Y-1.0327 I0 J-0.0322
    G1 X-1.1358
    G3 X-1.117 Y-1.0227 Z-0.495 I0 J0.0226
    X-1.1206 Y-0.9934 I-0.0188 J0.0126 F200.0
    G1 X-1.1372 Y-0.9783
    X-1.1417 Y-0.9742 Z-0.4963 F60.0
    G3 X-1.1569 Y-0.9683 Z-0.5 I-0.0152 J-0.0167
    G1 X-1.18
    G3 X-1.1807 Y-1.0327 I-0.0001 J-0.0322
    G1 X-1.1575
    G3 X-1.1386 Y-1.0227 Z-0.495 I0.0001 J0.0228
    X-1.1428 Y-0.9925 I-0.0188 J0.0128 F200.0
    G1 X-1.1598 Y-0.9783
    X-1.1655 Y-0.9736 Z-0.4966 F60.0
    G3 X-1.18 Y-0.9683 Z-0.5 I-0.0146 J-0.0174
    G1 X-1.2023
    G3 X-1.2029 Y-1.0326 I0 J-0.0322
    G1 X-1.1807 Y-1.0327
    G3 X-1.1619 Y-1.0227 Z-0.495 I0.0001 J0.0227
    X-1.1657 Y-0.993 I-0.0187 J0.0127 F200.0
    G1 X-1.1824 Y-0.9783
    X-1.1873 Y-0.9739 Z-0.4964 F60.0
    G3 X-1.2023 Y-0.9683 Z-0.5 I-0.015 J-0.017
    G1 X-1.2237
    G3 X-1.2244 Y-1.0326 I0 J-0.0321
    G1 X-1.2029
    G3 X-1.1842 Y-1.0227 Z-0.495 I0 J0.0225
    X-1.1876 Y-0.9936 I-0.0187 J0.0126 F200.0
    G1 X-1.2041 Y-0.9783
    X-1.2084 Y-0.9743 Z-0.4963 F60.0
    G3 X-1.2237 Y-0.9683 Z-0.5 I-0.0153 J-0.0165
    G1 X-1.2463
    G3 X-1.247 Y-1.0326 I0 J-0.0321
    G1 X-1.2244
    G3 X-1.2056 Y-1.0226 Z-0.495 I0 J0.0226
    X-1.2095 Y-0.9928 I-0.0188 J0.0126 F200.0
    G1 X-1.2263 Y-0.9783
    X-1.2315 Y-0.9738 Z-0.4965 F60.0
    G3 X-1.2463 Y-0.9683 Z-0.5 I-0.0148 J-0.0171
    G1 X-1.268 Y-0.9682
    G3 X-1.2687 Y-1.0326 I0 J-0.0322
    G1 X-1.247
    G3 X-1.2283 Y-1.0226 Z-0.495 I0 J0.0226
    X-1.2317 Y-0.9934 I-0.0187 J0.0126 F200.0
    G1 X-1.2483 Y-0.9782
    X-1.2527 Y-0.9742 Z-0.4963 F60.0
    G3 X-1.268 Y-0.9682 Z-0.5 I-0.0153 J-0.0166
    G1 X-1.2905
    G3 X-1.2913 Y-1.0326 I-0.0001 J-0.0322
    G1 X-1.2687
    G3 X-1.2499 Y-1.0226 Z-0.495 I0 J0.0227
    X-1.2538 Y-0.9928 I-0.0188 J0.0127 F200.0
    G1 X-1.2706 Y-0.9782
    X-1.2757 Y-0.9738 Z-0.4965 F60.0
    G3 X-1.2905 Y-0.9682 Z-0.5 I-0.0149 J-0.0171
    G1 X-1.3121
    G3 X-1.3129 Y-1.0325 I0 J-0.0322
    G1 X-1.2913 Y-1.0326
    G3 X-1.2726 Y-1.0226 Z-0.495 I0 J0.0226
    X-1.276 Y-0.9935 I-0.0187 J0.0126 F200.0
    G1 X-1.2925 Y-0.9782
    X-1.2968 Y-0.9742 Z-0.4963 F60.0
    G3 X-1.3121 Y-0.9682 Z-0.5 I-0.0153 J-0.0166
    G1 X-1.3343
    G3 X-1.3352 Y-1.0325 I0 J-0.0322
    G1 X-1.3129
    G3 X-1.2941 Y-1.0226 Z-0.495 I0 J0.0226
    X-1.2978 Y-0.9931 I-0.0188 J0.0127 F200.0
    G1 X-1.3145 Y-0.9782
    X-1.3193 Y-0.9739 Z-0.4964 F60.0
    G3 X-1.3343 Y-0.9682 Z-0.5 I-0.015 J-0.0169
    G1 X-1.3571
    G3 X-1.3579 Y-1.0325 I0 J-0.0322
    G1 X-1.3352
    G3 X-1.3164 Y-1.0225 Z-0.495 I0.0001 J0.0226
    X-1.3203 Y-0.9928 I-0.0187 J0.0126 F200.0
    G1 X-1.3371 Y-0.9782
    X-1.3422 Y-0.9737 Z-0.4965 F60.0
    G3 X-1.3571 Y-0.9682 Z-0.5 I-0.0149 J-0.0171
    G1 X-1.3785
    G3 X-1.3794 Y-1.0325 I-0.0001 J-0.0321
    G1 X-1.3579
    G3 X-1.3392 Y-1.0225 Z-0.495 I0 J0.0225
    X-1.3425 Y-0.9935 I-0.0187 J0.0125 F200.0
    G1 X-1.359 Y-0.9782
    X-1.3632 Y-0.9742 Z-0.4963 F60.0
    G3 X-1.3785 Y-0.9682 Z-0.5 I-0.0154 J-0.0165
    G1 X-1.4003
    G3 X-1.4012 Y-1.0325 I0 J-0.0321
    G1 X-1.3794
    G3 X-1.3607 Y-1.0225 Z-0.495 I0 J0.0226
    X-1.3642 Y-0.9934 I-0.0187 J0.0126 F200.0
    G1 X-1.3806 Y-0.9782
    X-1.3851 Y-0.9741 Z-0.4963 F60.0
    G3 X-1.4003 Y-0.9682 Z-0.5 I-0.0152 J-0.0166
    G1 X-1.4222
    G3 X-1.4231 Y-1.0324 I0 J-0.0321
    G1 X-1.4012 Y-1.0325
    G3 X-1.3825 Y-1.0225 Z-0.495 I0 J0.0226
    X-1.386 Y-0.9933 I-0.0187 J0.0126 F200.0
    G1 X-1.4025 Y-0.9782
    X-1.4069 Y-0.9741 Z-0.4963 F60.0
    G3 X-1.4222 Y-0.9682 Z-0.5 I-0.0153 J-0.0166
    G1 X-1.4452
    G3 X-1.4462 Y-1.0324 I0 J-0.0321
    G1 X-1.4231
    G3 X-1.4043 Y-1.0225 Z-0.495 I0 J0.0226
    X-1.4083 Y-0.9926 I-0.0188 J0.0127 F200.0
    G1 X-1.4252 Y-0.9782
    X-1.4305 Y-0.9736 Z-0.4965 F60.0
    G3 X-1.4452 Y-0.9682 Z-0.5 I-0.0147 J-0.0172
    G1 X-1.4666 Y-0.9681
    G3 X-1.4677 Y-1.0324 I-0.0001 J-0.0322
    G1 X-1.4462
    G3 X-1.4275 Y-1.0224 Z-0.495 I0 J0.0225
    X-1.4307 Y-0.9936 I-0.0187 J0.0125 F200.0
    G1 X-1.4471 Y-0.9782
    X-1.4512 Y-0.9743 Z-0.4962 F60.0
    G3 X-1.4666 Y-0.9681 Z-0.5 I-0.0154 J-0.0163
    G1 X-1.4888
    G3 X-1.4898 Y-1.0324 I0 J-0.0322
    G1 X-1.4677
    G3 X-1.4489 Y-1.0224 Z-0.495 I0.0001 J0.0225
    X-1.4525 Y-0.9932 I-0.0187 J0.0125 F200.0
    G1 X-1.469 Y-0.9781
    X-1.4736 Y-0.974 Z-0.4964 F60.0
    G3 X-1.4888 Y-0.9681 Z-0.5 I-0.0152 J-0.0167
    G1 X-1.5112
    G3 X-1.5123 Y-1.0324 I0 J-0.0322
    G1 X-1.4898
    G3 X-1.4711 Y-1.0224 Z-0.495 I0 J0.0226
    X-1.4748 Y-0.993 I-0.0187 J0.0126 F200.0
    G1 X-1.4914 Y-0.9781
    X-1.4962 Y-0.9738 Z-0.4964 F60.0
    G3 X-1.5112 Y-0.9681 Z-0.5 I-0.015 J-0.0169
    G1 X-1.5336
    G3 X-1.5347 Y-1.0323 I0 J-0.0321
    G1 X-1.5123 Y-1.0324
    G3 X-1.4936 Y-1.0224 Z-0.495 I0 J0.0226
    X-1.4972 Y-0.993 I-0.0187 J0.0126 F200.0
    G1 X-1.5138 Y-0.9781
    X-1.5185 Y-0.9739 Z-0.4964 F60.0
    G3 X-1.5336 Y-0.9681 Z-0.5 I-0.0151 J-0.0168
    G1 X-1.5556
    G3 X-1.5567 Y-1.0323 I0 J-0.0321
    G1 X-1.5347
    G3 X-1.516 Y-1.0224 Z-0.495 I0 J0.0225
    X-1.5195 Y-0.9933 I-0.0187 J0.0126 F200.0
    G1 X-1.5359 Y-0.9781
    X-1.5403 Y-0.974 Z-0.4963 F60.0
    G3 X-1.5556 Y-0.9681 Z-0.5 I-0.0153 J-0.0166
    G1 X-1.5768
    G3 X-1.578 Y-1.0323 I-0.0001 J-0.0321
    G1 X-1.5567
    G3 X-1.538 Y-1.0223 Z-0.495 I0 J0.0224
    X-1.5412 Y-0.9937 I-0.0187 J0.0124 F200.0
    G1 X-1.5574 Y-0.9781
    X-1.5613 Y-0.9743 Z-0.4962 F60.0
    G3 X-1.5768 Y-0.9681 Z-0.5 I-0.0156 J-0.0162
    G1 X-1.5985
    G3 X-1.5997 Y-1.0323 I0 J-0.0321
    G1 X-1.578
    G3 X-1.5593 Y-1.0223 Z-0.495 I0 J0.0225
    X-1.5626 Y-0.9935 I-0.0187 J0.0125 F200.0
    G1 X-1.5789 Y-0.9781
    X-1.5831 Y-0.9742 Z-0.4963 F60.0
    G3 X-1.5985 Y-0.9681 Z-0.5 I-0.0154 J-0.0163
    G1 X-1.6198
    G3 X-1.621 Y-1.0323 I0 J-0.0321
    G1 X-1.5997
    G3 X-1.581 Y-1.0223 Z-0.495 I0 J0.0224
    X-1.5841 Y-0.9937 I-0.0187 J0.0124 F200.0
    G1 X-1.6003 Y-0.9781
    X-1.6042 Y-0.9743 Z-0.4962 F60.0
    G3 X-1.6198 Y-0.9681 Z-0.5 I-0.0156 J-0.0162
    G1 X-1.6422 Y-0.968
    G3 X-1.6434 Y-1.0323 I0 J-0.0322
    G1 X-1.621
    G3 X-1.6023 Y-1.0223 Z-0.495 I0 J0.0226
    X-1.6059 Y-0.993 I-0.0187 J0.0126 F200.0
    G1 X-1.6224 Y-0.9781
    X-1.6271 Y-0.9739 Z-0.4964 F60.0
    G3 X-1.6422 Y-0.968 Z-0.5 I-0.0151 J-0.0167
    G1 X-1.6641
    G3 X-1.6654 Y-1.0322 I0 J-0.0321
    G1 X-1.6434 Y-1.0323
    G3 X-1.6247 Y-1.0223 Z-0.495 I0 J0.0225
    X-1.6281 Y-0.9933 I-0.0187 J0.0125 F200.0
    G1 X-1.6445 Y-0.978
    X-1.6487 Y-0.9741 Z-0.4963 F60.0
    G3 X-1.6641 Y-0.968 Z-0.5 I-0.0154 J-0.0164
    G1 X-1.6855
    G3 X-1.6869 Y-1.0322 I-0.0001 J-0.0321
    G1 X-1.6654
    G3 X-1.6467 Y-1.0222 Z-0.495 I0 J0.0224
    X-1.6498 Y-0.9936 I-0.0187 J0.0124 F200.0
    G1 X-1.6661 Y-0.978
    X-1.67 Y-0.9743 Z-0.4962 F60.0
    G3 X-1.6855 Y-0.968 Z-0.5 I-0.0156 J-0.0162
    G1 X-1.7077
    G3 X-1.7091 Y-1.0322 I0 J-0.0321
    G1 X-1.6869
    G3 X-1.6682 Y-1.0222 Z-0.495 I0 J0.0225
    X-1.6716 Y-0.9932 I-0.0187 J0.0125 F200.0
    G1 X-1.6881 Y-0.978
    X-1.6925 Y-0.974 Z-0.4963 F60.0
    G3 X-1.7077 Y-0.968 Z-0.5 I-0.0152 J-0.0165
    G1 X-1.7288
    G3 X-1.7302 Y-1.0322 I-0.0001 J-0.0321
    G1 X-1.7091
    G3 X-1.6904 Y-1.0222 Z-0.495 I0.0001 J0.0224
    X-1.6934 Y-0.9938 I-0.0186 J0.0124 F200.0
    G1 X-1.7095 Y-0.978
    X-1.7132 Y-0.9744 Z-0.4961 F60.0
    G3 X-1.7288 Y-0.968 Z-0.5 I-0.0157 J-0.016
    G1 X-1.75
    G3 X-1.7727 Y-0.9773 I0 J-0.032
    X-1.7821 Y-1. I0.0227 J-0.0227
    X-1.7727 Y-1.0227 I0.0321 J0
    X-1.75 Y-1.0322 I0.0227 J0.0227
    G1 X-1.7302
    G3 X-1.7169 Y-1.027 Z-0.4975 I0 J0.0198
    X-1.7105 Y-1.0142 Z-0.495 I-0.0133 J0.0146 F200.0
    G1 X-0.8009 Y-1.015
    G3 X-0.7946 Y-1.0278 Z-0.4975 I0.0197 J0.0018
    X-0.7812 Y-1.033 Z-0.5 I0.0134 J0.0146 F60.0
    G1 X0.1745 Y-1.0341
    X0.2875
    Y-0.9375 Z-0.495 F200.0
    X0.1745 Z-0.5 F60.0
    X-0.7812
    X-1.75
    G3 X-1.8125 Y-1. I0 J-0.0625
    X-1.8025 Y-1.0221 Z-0.4982 I0.0295 J0
    X-1.7622 Y-1.0208 Z-0.495 I0.0195 J0.0221 F200.0
    G1 X-1.7292 Y-0.9878
    G3 X-1.7279 Y-0.9475 Z-0.4982 I-0.0208 J0.0208
    X-1.75 Y-0.9375 Z-0.5 I-0.0221 J-0.0195 F60.0
    G1 X-1.7844
    G3 X-1.8125 Y-0.9656 I0 J-0.0281
    G1 Y-1.
    G3 X-1.75 Y-1.0625 I0.0625 J0
    X-1.7279 Y-1.0525 Z-0.4982 I0 J0.0295
    X-1.7292 Y-1.0122 Z-0.495 I-0.0221 J0.0195 F200.0
    G1 X-1.7622 Y-0.9792
    G3 X-1.8025 Y-0.9779 Z-0.4982 I-0.0208 J-0.0208
    X-1.8125 Y-1. Z-0.5 I0.0195 J-0.0221 F60.0
    G1 Y-1.0344
    G3 X-1.7844 Y-1.0625 I0.0281 J0
    G1 X-1.75
    X-0.7812
    X0.1745
    X0.2875
    G3 X0.3875 Y-0.9625 Z-0.495 I0 J0.1
    G0 Z1.
    S7000 M3
    X0.1 Y-1.0375
    Z-0.495
    G3 X0 Y-0.9375 Z-0.5 I-0.1 J0 F81.5
    G1 X-1.7844 F40.0
    G1 Y-1.0344
    G1 X0
    G3 X0.1 Y-0.9625 Z-0.495 I0 J0.1
    G0 Z1.
    G0 G49 G90 Z0 M9
    G28 G91 Y0
    M30
  1. Trochoidal Milling with Solidcam
    By MRM RCModels in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 09-28-2010, 10:54 AM
  2. PCB milling
    By Ubarch in forum Benchtop Machines
    Last Post: 03-27-2009, 06:56 PM
  3. Offset Chain Milling vs Path Milling
    By ynnek in forum Uncategorised CAM Discussion
    Last Post: 03-11-2009, 11:29 PM
  4. Milling Help
    By ligito in forum Uncategorised MetalWorking Machines
    Last Post: 02-27-2009, 11:30 PM
  5. Milling with bottom vs milling with side?
    By REVCAM_Bob in forum Community Club House
    Last Post: 06-30-2008, 03:23 PM
