587,702 active members*
3,319 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > step file into bobcad 21 then into autocad 2000?
Results 1 to 3 of 3
    Dec 2005
    54
    i have 3 .step files from solidworks. they go into bobcad v21 nicely, and save well as .dwg or .dxf files. but any attempt to open them with autocad 2000 is fruitless, the .dwg file generates an "incompatable version" message of some sort, the .dxf file seems to read over with no errors, but when you look, there is nothing there. i am doing this as i am more competent in autocad and want to isolate peripheries for 2 1/2d milling. or can i explode this in bobcad? my attempts so far seem to break the solid into surfaces, but i would like to break surfaces into to individual line entities. thanks.
    Aug 2003
    449
    You need to use the Extract Edges function to get wire frame that is useful.
    Select your Surfaces/Solid and click on Solids -> Extract Edges. A dialog will appear asking what you want to extract, choose the All Edges Arcs and Lines option and click OK.
    Now you can either delete the original surfaces or blank them out, but you will find that you have wire frame that should export to AutoCAD just fine.
    Regards
    Dec 2005
    54
    it worked very well, my thanks!
  1. Autocad 2000 Move
    By N4NV in forum Autodesk
    Last Post: 03-23-2014, 03:30 AM
  2. Importing 3D from AutoCAD 2000
    By noisillator in forum Uncategorised CAM Discussion
    Last Post: 06-19-2009, 03:44 AM
  3. How to edit MPFAN post file step by step
    By m_bhui in forum Post Processors for MC
    Last Post: 10-04-2008, 11:42 AM
  4. AutoCad 2000 DXF Question
    By Holmes_ca in forum Autodesk
    Last Post: 01-20-2005, 12:50 AM
  5. AutoCad 2000 Missing .dll file
    By E-Stop in forum Autodesk
    Last Post: 05-30-2003, 05:43 PM
