587,450 active members*
4,657 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Estopping Mach and other drives with fault condition
Results 1 to 3 of 3
    Mar 2004
    145
    Hi to all out there................................out there...
    Is there a electronics diagram out there / here on the zone for a reset/err estop/Mach .... for the gecko 320.
    All Iam after is that Mach registers a fault with geckos,so the program stops,
    and the other drives stop also.
    Any help or thoughts would be good.....Thanks?
    Regards
    JUbee
    Jun 2005
    1015
    i think this needs to be wired to the e-stop switch as well. ultimately though i am looking for the same info as the OP.
    thanks
    Dec 2003
    24220
    Did you check this out?
    http://www.sfu.ca/~alan/gecko/err.html
    Little bit cumbersome to have to go to this, but it may be an answer.
    Al.
    Albert E.
  1. conversion of anilam drives with mach 3 software
    By ptpz in forum Machines running Mach Software
    Last Post: 03-15-2011, 07:48 PM
  2. 201 drives fault over and over
    By wes in forum Gecko Drives
    Last Post: 07-03-2008, 06:06 PM
  3. how do i get mach to halt for a servo fault
    By fast89 in forum Mach Wizards, Macros, & Addons
    Last Post: 04-08-2008, 08:10 AM
  4. Replies: 2
    Last Post: 07-28-2007, 11:17 AM
  5. Is Mach 3 able to control 3 independent gecko drives?
    By mrmz in forum Mach Software (ArtSoft software)
    Last Post: 07-27-2007, 11:13 PM
