587,758 active members*
2,863 visitors online*
Results 1 to 10 of 10
    Jul 2004
    93
    Anybody useing MasterCam post
    I have been setting up a BP knee mill manual tool change,
    and need some Ideas on modifying the post to M0 for the high / low speed switch
    IF ITS NOT BROKE YOUR NOT TRYING HARD ENOUGH
    Ashes to ashes , dust to dust , If it wasnt for Harleys the fast lane would rust.
    Apr 2003
    1876
    You could set a switch to test for certain speed limits, and if it changes between the two, have it output the M00 codes.
    Another way would be to use Misc Values, if you know what operations you'll be changing gears in.
    You could also use Manual Entry toolpaths, with the 1005 setting to output code, then type in the code you want, (or select a text file that contains it).
    Lot's of options. It depends on preference and necessity.
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Jul 2004
    93
    Rekd
    Thanks for the info , what i would like to do is, set up a statement that reads the upcoming s value and then write an statement in the code that states M0 (CHANGE TO HIGH OR LOW GEAR) depending on the up coming s value, but do not know how to do it.
    thanks Brad
    Apr 2003
    1876
    It will be real easy to do it without testing for the previous value. In other words, it will read each RPM, and output an M00 with the proper gear setting. Problem with this is that it will repeat even if the values haven't changed.
    For example, in your post, look for
    Code:
    ptlchg_com      #Tool change common blocks ()
    and add these lines to the function, before the coolant or Z move down to the part.
    Code:
             if speed <= 2000, n, "M00 (Low Gear)", E
             if speed >= 2001, n, "M00 (High Gear)", E
    This will give you:
    Code:
    N23 ( OPERATION: 2   DRILL )
    N24 ( OP 3 90 )
    N25 ( DRILL 6-32 )
    N26 T5 M06
    N27(T5:  1/8 DRILL)
    N28(MAX-DEPTH | Z-.5376)
    N29(OP ID: 2)
    N30 M03 S6500
    N31 M00 (HIGH GEAR) <-------------------------------------------
    N32 G00 G56 X-1.08 Y-1.2463
    N33 G43 H5 Z1.
    / N34 M08
    N35 Z.1
    N36 G98 G83 X-1.08 Y-1.2463 Z-.5376 R.1 I.25 J.0625 K.0625 F12.
    N37 X-.17 Y-.164
    N38 G80
    N39 Z1.
    N40 M09
    N41 G90
    N42 M01
    N43 ( OPERATION: 3   DRILL )
    N44 ( OP 3 90 )
    N45 ( TAP 6-32 )
    N46 T6 M06
    N47(T6: #6-32 ROLL TAP H3 BOTTOM)
    N48(MAX-DEPTH | Z-.35)
    N49(OP ID: 3)
    N50 M03 S500
    N51 M00 (LOW GEAR) <-------------------------------------------
    N52 G00 G56 X-1.08 Y-1.2463
    N53 G43 H6 Z1.
    / N54 M08
    N55 Z.1
    N56 G98 G84 X-1.08 Y-1.2463 Z-.35 R.1 F15.63
    N57 X-.17 Y-.164
    (This is for a HAAS post, so it may look different.)
    In order to only post the M00 when the gear needs to be changed, you'd need to create some logic to:
    a. store current speed of the first operation in newly declared variable
    b. test for a different speed. If different speed, is it also a different gear? Which gear?
    c. post M00 codes if gear is > or < than previous gear
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Apr 2003
    1876
    BTW, if you don't mind editing your posts, AFTER you back it up, you can modify this portion to tell you in the posted NC file WHERE in the post that particular line was generated..
    Code:
    # Debugging and Factory Set Program Switches
    fastmode    : 1   #Posting speed optimizition
    bug1        : 2     #0=No display, 1=Generic list box, 2=Editor
    bug2        : 40     #Append postline labels, non-zero is column position?
    bug3        : 0     #Append whatline no. to each NC line? 0
    bug4        : 0     #Append NCI line no. to each NC line? 0
    whatno      : yes   #Do not perform whatline branches? leave as yes
    For example, when setting fastmode to 0, you'll get:
    Code:
    N2 M01                                  psof ptlchg_com
    N3 ( OPERATION: 1   DRILL )             psof popnumber
    N4 ( OP 3 90 )                          psof pcomment
    N5 ( SPOT 6-32 )                        psof pcomment
    N6 T2 M06                               psof p__8:1113
    N7(T2: 1/4 CHAMFER MILL)                psof ptoolcomm
    N8(MAX-DEPTH | Z-.07)                   psof ptlchg_com
    N9(OP ID: 1)                            psof pstock
    N10 M03 S7000                           psof ptlchg_com
    N11 M00 (HIGH GEAR)                     psof ptlchg_com
    N12 G00 G56 X-1.08 Y-1.2463             psof ptlchg_com
    N13 G43 H2 Z1.                          psof ptlchg_com
    / N14 M08                               psof ptlchg_com
    N15 Z.1                                 pzrapid prapidout
    N16 G98 G82 X-1.08 Y-1.2463 Z-.07 R.1 P.3 F50.  pdrill
    N17 X-.17 Y-.164 P.3                    pdrill_2
    N18 G80                                 pcanceldc
    N19 Z1.                                 pzrapid prapidout
    N20 M09                                 ptlchg1002 pretract
    N21 G90                                 ptlchg1002 pretract
    N22 M01                                 ptlchg ptlchg_com
    N23 ( OPERATION: 2   DRILL )            ptlchg popnumber
    HTH
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Apr 2003
    1876
    Almost forgot; formatting in the .pst file is important. In the example in my previous post, put the "if speed" lines AWAY from the left margin. If it's against the left margin, you'll get an undeclared variable error.
    In the following code, I created 2 new functions that are triggered either automatically or by setting a switch in the Misc Value's Misc Integer section.
    Note that the function name is all the way against the left margin, and the function itself is away from the margin.
    Code:
    popnumber	#Count Operations, add op type ()
    	op_number = op_number + 1
    	# = op_number
          n, "(", stopno, op_number, " ", stoper, ")", e
    pcorner_round	#corner rounding ()
          if mi5 = 1 & mr5 > 0 & flg_mi5 = 0,
          	sav_mr5 = mr5,
          	pbld, n, "G187", *sav_mr5, e
          	flg_mi5 = 1
          if mi5 = 1 & mr5 = 0,
          	"( WARNING!! CORNER ROUNDING CONTROL HAS )", e
          	"( BEEN ENABLED WITHOUT A VALUE SET! USE )", e
          	"( MISC VALUES-MISC REALS TO SET A VALUE )", e
          	"( CORNER ROUNDING CONTROL IS DISABLED   )", e
          if mi5 = 0 & flg_mi5 = 1,
          	n, "G187", e
          	flg_mi5 = 0
    Now, any time I want to call the pcorner_round function, I call it like this:
    Code:
    ptlchg0         #Call from NCI null tool change (tool number repeats)
          pcorner_round <----------call this function
          pcuttype<----------------then call this one
          toolcount = toolcount + 1<------do some stuff here
          if toolcountn <= tooltotal, nexttool = rbuf(4,toolcountn)<-----do some if then statements here
            else, nexttool = first_tool
          if mi10=one & op_id<>last_op_id, pstop <---- test an if then statement and call another function if true
    Hope I'm not confusing you..
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Jul 2004
    93
    Rekd :cheers:
    thanks that works great, will work on some logic can you give me any advice ,were how, but I can not figure out how to remove op comment see below
    here is what i have so far
    % pheader
    O0100 pheader
    (PROGRAM NAME - LONGHORN2 ) pheader
    (DATE=DD-MM-YY - 23-12-04 TIME=HH:MM - 16:55 ) pheader
    N100 ; TOOL - 01 DIA. - .2500 pwrtt
    N102 ; TOOL - 02 DIA. - .0625 pwrtt
    ( rough profile ) pcomment want to remove comment
    N104 G17 G40 ; Setup for XY plane, no cutter comp, psof
    N106 G20 ; inch measurements psof
    N108 G80 ; cancel canned cycles, psof
    N110 G90 ; absolute positioning, psof
    N112 M25 G49 ; Goto Z home, cancel tool length offset psof
    N114 G91 G28 X0. Y0. psof
    N116 T1 (CHANGE TOOL) psof
    N118 S3000 psof
    N120 M00 (High Gear) psof
    N122 ( 1/4 FLAT ENDMILL TOOL - 01 ) psof ptoolcomment
    N124 ( ) psof pcomment
    N126 S3000 M3 psof
    N128 G00 G90 G54 X-.2955 Y1.5862 psof
    N130 G43 H1 Z.25 psof
    N132 M07 ;Mist on psof
    N134 Z.1 pzrapid
    source________________________________________
    psof0 # Start of file for tool zero
    psof
    psof # Start of file for non-zero tool number
    pinit
    !opcode
    n, "G17 G40 ; Setup for XY plane, no cutter comp,"
    n, "G20 ; inch measurements"
    n, "G80 ; cancel canned cycles,"
    n, "G90 ; absolute positioning,"
    n, "M25 G49 ; Goto Z home, cancel tool length offset"
    n, pinc , *sg28ref, "X0.", "Y0.", e
    n, *t, "(CHANGE TOOL)"
    n, speed
    n, ptoolcomment
    n, pcomment
    n, *speed, *spdlon
    pcan
    pcan1, n, "G00", pabs, pwcs, *xr, *yr, strcantext
    pcan2
    n, ptllncomp, *zr
    pcoolon
    Jul 2004
    93
    its a little confusing ,but will try to modify what u sent and see what happens , got to learn some how!
    Brad
    Apr 2003
    1876
    Like I said, make a copy of your original post before you go too far.
    The comment is comming from the "pcomment" function
    Change this line:
    Code:
    n, pcomment
    to this:
    Code:
    #n, pcomment
    The "#" prevents MP from reading that line during posting. It's for comments or skipping blocks that you dont want to delete from the post.
    Are you familiar with any other types of programming/coding? Like Visual Basic, C, C++, Java, PHP, batch, etc? If not, that's gonna be your roughest learning curve.
    The MP (Mastercam Post) language is just that; a complete programming language for post processors in Mastercam. (Like html is to web pages.) The possibilities are literally unlimited.
    Also, I just guessed at what RPM your machine shifts gears at, so you'll want to change that to the real values.
    :cheers:
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Jul 2004
    93
    look like i have it
    Rekd
    thanks for you help.
    the post looks pretty much like i need it,
    really dont need any logic ,sence I have to M0 between tools any how
    I just remove pcomment from the source, being that i am limited to 9999 in a post to the control and wasted info is bad for me.
    Again thanks
    Brad :banana: :banana: :banana:
  1. Emco Compact 5 PC...have ????
    By Double G in forum Mini Lathe
    Last Post: 08-23-2010, 12:26 AM
  2. Upgrading control hardware - Emco
    By eDudlik in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-08-2009, 07:52 AM
  3. Modify Mastercam MPFAN post
    By COPO427 in forum Mastercam
    Last Post: 05-26-2004, 05:59 PM
  4. Mastercam post to Kellyware Kcam??
    By gcamlibel in forum Mastercam
    Last Post: 03-09-2004, 05:04 PM
