Hey guys, I'm hoping that some of you might have been through some of these newbie problems that I'm having and hopefully can give me some insight. I'm converting my Grizzly G0602 lathe using a stepperworld.com FET 3 board that a friend gave me, and 2 Keling 425oz motors. I've got them wired up as unipolar, although I'm not sure I have nailed down the proper wiring order yet. Here's the spec sheet:
http://www.kelinginc.net/KL23H286-20-08B.pdf
I'm pretty sure I have the two center taps correct, basically connecting A-C- and B-D- and putting those to power. The other 4 are just a guess, but I've tried all combinations with very little change. Right now for the test I'm giving the board +5v and the steppers +5v, though they're rated for 6. Eventually I'll step up to my 24v power supply, but right now I just want to make it work properly.
Anyways, the main problem that I'm having is that the steppers are just extremely jerky and slow, sometimes not responding at all and just jittering along the table. Here is a video of them while using the stepperworld VBStepDirXP.exe program.
[ame="http://www.youtube.com/watch?v=TUpzGW6kp70"]YouTube - CNC testing[/ame]
As you can see the stepper closest to the camera (Z) rotates fairly well, although it pulses a lot, for about 14 seconds until it just stops rotating. The other motor (X) just makes a pulsing noise and vibrates. It should be noted that the two are wired up differently, although wiring them identical seems to give the same result.
And here is with trying to use Mach3Turn to control them with the arrow keys, the settings are posted below. Now the motor that didn't work before (X) sort of rotates, although only in one direction, but the Z motor doesn't:
[ame="http://www.youtube.com/watch?v=gW8OL7ECdt4"]YouTube - CNC testing[/ame]
http://www.cravingboost.com/cars/lathe.43.jpg
http://www.cravingboost.com/cars/lathe.44.jpg
For a computer I've got a dell pc with 650mhz processor and 500mb ram. Got it from a friend, he had just installed a fresh version of XP on it and it didn't have any extra programs at all. I tried all of the hacks and mods in this article to no avail:
http://www.machsupport.com/downloads...timization.txt
Just last night I reformatted the computer, put XP pro SP2 on it and followed those mods to a T, same exact results. One thing that just occured to me that I forgot to try after reformatting it is to use that "specialdriver.bat" file. I tried this before the reformat and it made no change.
DriverTest.exe shows a consistent 25393 +-1, then every 10 seconds or so it shows 25593 for one tick, that's +200.
My question for you fine gentlemen is, is this a computer problem or a stepper driver board problem? If driver, what should I get next? I need 2 axis for cheap, I'm pretty tapped out from getting this far on the lathe. Cheap meaning if I can do it for sub $100 I'll be happy. The easy route would be to get two of those small Geckos, that'll run me $150 shipped. I'm very comfortable with a soldering iron so I'm not at all opposed to soldering my own kit, but I don't have the time or resources to mill/print my own board from scratch right now, so it would be nice to buy a board and a Digikey parts list. I'm interested in the PMinMo projects and I'd be very happy to hear some thoughts on it. Even just showing me a link to some good threads about them or similar technology would be great. I've been searching and cramming for days/weeks now. Since I have the 24v power supply ready to go, it sounds like chopper circuits are totally the way to go, what a cool technology! Makes perfect sense. I was reading something about how the A3977 chips are loud, how does that work? Is it unbearable? The price is right. Ohh and for the PMinMo boards will I have to program my own chips? Because I don't have that technology.
Thanks for all your help and advice! If you need more info I'll be happy to provide. Off to the dentist right now... yay...
John
In other news, my lathe conversion is coming along swimmingly! All the machining is done, just gotta wire it up and make it work properly.
http://www.cravingboost.com/cars/lathe.41.jpg
http://www.cravingboost.com/cars/lathe.42.jpg
