587,326 active members*
3,125 visitors online*
Page 5 of 5 345
Results 81 to 98 of 98
  1. #81
    May 2007
    250
    Smile My problem
    Bigtoy and Friend,
    I found some problems.
    I have the limit switch of floating head on Z-axis. It links to pin13 and port1,Z-home.I use active high and NC connection.I toggle the THC ON to ON in mach3 screen and then click on the cycle start. the X and Y move to the first pierce point.The Z-axis move down by a little and torch fire immediately. Sounds like it ignores G28.1 Z3.00 to move Z down to hit the material and not hit the limit switch.of the floating head
    What is the rootcause for jumping from G28.1 z3.00 line to M03 line? ( not work on G28.1 z3.00 line)
    Mongkol
  2. #82
    Nov 2005
    152
    Quote Originally Posted by Mongkol View Post
    Bigtoy and Friend,
    Mongkol
    Post up what your program actually looks like.
  3. #83
    May 2007
    250
    Smile
    Bigtoy,
    I use sheetcam and here's my g-code.
    Mongkol
    Attached Files Attached Files
  4. #84
    May 2007
    250
    g-code
    I use the switch offset= -6.612 mm
    N0000 (Filename: test8.tap)
    N0010 (Post processor: Plasma THC300.post)
    N0020 (Date: 9/17/2006)
    N0030 G21 (Units: Metric)
    N0040 G53 G90 G40
    N0050 F1
    N0060 S500
    N0070 (Part: circle)
    N0080 (Process: Set variable switch offset = -6.612 )
    N0090 (Process: Plasma, IN, Plasma, 1 mm kerf)
    N0100 M06 T1 (Plasma, 1 mm kerf)
    N0110 G00 Z0.0000
    N0120 X25.0000 Y42.1490
    N0130 G28.1 Z3.00
    N0140 G92 Z0.0
    N0150 G00
    N0160 G92 Z0.0
    N0170 G00 Z2.0000
    N0180 M03
    N0190 G04 P0.1
    N0200 G01 X25.0000 Y42.1490 Z1.0000 F500
    N0210 G03 X25.0000 Y42.1490 I0.0000 J-3.5000 F1000.0
    N0220 M05
    N0230 G00 Y13.0038
    N0240 Z2.0000
    N0250 M03
    N0260 G04 P0.1
    N0270 G03 X25.0000 Y13.0038 Z1.0000 I0.0000 J-3.5000
    N0280 (Process: Plasma, OUT, Plasma, 1 mm kerf)
    N0290 M05
    N0300 G00 X25.0000 Y-0.5000
    N0310 Z2.0000
    N0320 M03
    N0330 G04 P0.1
    N0340 G03 X25.0000 Y-0.5000 Z1.0000 I-0.0000 J25.5000
    N0350 M05
    N0360 M05 M30
  5. #85
    May 2007
    250
    Smile Circle is not round
    Hi Bigtoy,
    I can clear the problem of micro switch on the floating head already. It work fine by now.
    I have some questions.
    If you cut the circle, the external circle and internal circle is round or not.
    I found some problems. The external circle is good but the internal circle is bad after cutting. It is not round and has the slack. I am not sure what is the problem.
    It may be the torch is not perpenticular with meterial. Your machine is OK or not if you cut the circle. Is it round?
    Mongkol
  6. #86
    Nov 2005
    152
    So the other day I sold my Hypertherm 1000 and bought the new Hypertherm powermax45. OMG this thing is awesome. It puts my 1000 to shame on cut quality. I can actually cut holes that are round and put a bolt through without drilling. A 3/8" hole in 1/4" only needs to be cut .015 over sized to get a bolt through it. At only 45 amps it still cuts 1/4" and 3/8" steel way better then the 1000. If anybody is thinking of buying a new plasma this is it. I have only cut about 15 parts so far so I don't know about consumable life yet but Hypertherm claims up to 3 hours of cut time on one set of consumables.
    Here is a piece of 1/4" with a 3/8" hole cut at 50ipm. The hole was cut at 25ipm.
    Here is a piece of 3/8" AR500 cut at 30ipm. Almost laser quality.
    This thing is tiny compared to the 1000.
  7. #87
    May 2007
    250
    Smile If you cut stainless steel
    After cutting, the edge of steel is very beautiful and the hole is round.
    If you change to cut stainless steel, Is it O.K.?
    Mongkol
  8. #88
    Nov 2005
    152
    Mongkol
    I have not had a chance yet to cut stainless.
  9. #89
    May 2006
    47
    Very nice. A couple quick questions. Could you give me some approximate dimensions of your gantry side plates? I was going to design mine differently but really like how yours came out.
    For your rack & pinion and gear reduction parts, where did you get the parts and what ratios did you use?
    I am working on a very similar build.
    Thanks,
    Brian
  10. #90
    Feb 2009
    227
    I finally got a chance today to actually read all the post and look at all the photos. Your build was very professional and had superb craftsmanship. Thank You for your pics/post and wish you good luck in the cnc world. After cutting a few parts is everything working good? Do you have any problems or things you would change? Where did you buy your plastic cable chain or part # ? Thanks, Dustin
  11. #91
    Nov 2005
    152
    Quote Originally Posted by Dustin407 View Post
    Everything is working good. The only thing I would change is make it 5x10. My next table will be 5x10. Cutting sheets in half is a pain and sheets selections is better and cheaper for 5x10. The cable carriers came from Mcmaster carr.
  12. #92
    Jul 2009
    3
    Very nice
    Very nice. Do you have blueprints (dxf or so)
    http://www.plasma777.com
  13. #93
    Nov 2005
    152
    Quote Originally Posted by plasma777 View Post
    No I do not.
  14. #94
    Feb 2009
    11
    Nice table, I recognize your pictures from Pirate.
    How do you do holes like that? I thought you have to do edge starts. I haven't finished my CNC table yet, but when I'm cutting by hand, if I ever start in the middle of the panel, I have molten metal shoot back at me and mess up my torch's head. Well I get that problem for anything over 1/8" at least. Also, do you mean a 5x10' table to fit 4x8' sheets on or making a.. say 5.5x11' table to hold 5x10' sheets? I haven't bought large piece of sheet metal yet, but I thought the average size is 4x8'. If the sheets are really 5x10' I'm going to have to completely redesign my table damn lol.
    Anyways, thanks for posting your build up, was a cool read.
  15. #95
    Dec 2004
    312
    4x8 is most common size to purchase for sheet metal but 5x10 is very common sheet.. and for table size it all depends on the travels of the bearing..
    for my big cnc table the table is actually 7 foot 6 inch by 12 foot but the travels of the bearing is only 5 foot n 6 inch by 10 foot n 6 inch
  16. #96
    Nov 2005
    152
    Quote Originally Posted by finaltheorem47 View Post
    With CNC cutting you pierce around 2x as high as your cut hieght to prevent molten metal from blowing back into the torch. On my Powermax45 I pierce 1/4" at .150 height.
    On the sheet size the table would be a little bigger then the sheet you are cutting. So for 5x10 you would make the cutting area a little bigger then the plate. My next table will be a 5x10 so it will actually have about 61"x121" of travlel. 4x8 is the most common size but 5x10, 4x10, 4x12 and 5x12 is also really common around my area. I hate buying a big sheet and cutting it down to 4x4.
  17. #97
    Feb 2006
    1260
    Quote Originally Posted by Bigtoy302 View Post
    I built my table 61 X 121 Apx. Hadn't been running anytime till I needed 5' X 12' Wish I had gone with that to start with.
    If it works.....Don't fix it!
  18. #98
    Nov 2005
    152
    I got my Powermax65 last week and got around to hooking it up and doing a few test cuts. Cuts are on par with the 45 but I can go a lot faster now. 3/8" and 1/2" are much better with the 65.
    Hooking up the arc volt wires.
    I added two pins on the cpc port for the arc volt wires.
    Cuts made with 65 amps. 3/16",1/4",3/8" and 1/2". Two sides have no bevel but the other two have a few degrees of bevel.
Page 5 of 5 345
  1. Newbie - To build or not to build Router/Plasma Table
    By dfranks in forum Waterjet General Topics
    Last Post: 04-08-2011, 05:16 AM
  2. New Large Table Build in Houston, TX (Build Log)
    By anitel in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 12-30-2008, 09:45 AM
  3. Does anyone here build their own table saw?
    By starCNC in forum WoodWorking Topics
    Last Post: 02-11-2008, 02:29 AM
  4. nub wants to build cnc table
    By monte55 in forum Waterjet General Topics
    Last Post: 08-06-2006, 12:39 AM
