587,753 active members*
3,037 visitors online*
Page 1 of 3 123
Results 1 to 20 of 43
    Jan 2009
    23
    ZAY7045 + Gecko G540?
    Hi folks!
    I'm very new here, but have spent the last few months reading the forums and doing some research on a CNC mill. The general advice on machines was bigger is better, so I jumped on a deal for a ZAY7045. The machine is set up in the shop and has made some manual chips, but now it is time to make the machine sing. The G540 driver seems like a fantastic bargain, but I am wondering if it is too small for this mill? I don't need super fast rapids, so 1200 oz-in steppers seem overkill. I am mainly making small aluminum parts right now that have less than a 4" x 4" x 2" envelope.
    In your experience, what size stepper motors do I really need?
    It seems that any motor over 480 oz-in would be fine with reasonable travel speed.
    homeshopcnc.com sells a RS23-570 @ 570oz-in that seems like it would work with the G540 (inductance is right, but it can take more current than a G540 can provide) = lower torque if only driven with 3.5A?
    kelinginc.net has a KL23H2100-30-4BM @ 495oz-in, but the inductance is ~7mH which is more than the specs for G540
    Are there any other steppers out there that would match up better?
    Budget for the electronics (3 motors, drivers, BOB) is <$800 and simple is better. Am I asking too much out of the G540? Should I step up to G203s and NEMA 34 motors?
    Thanks for your help!
    -Chris
    Feb 2007
    4553
    Smile
    Chris,
    Go with the Gecko G203.
    The Zay 7045 Z axis weighs about 200 lbs, it really requires a nema 34.
    Where did you pick the Zay 7045 up at?
    Jeff...
    Jan 2009
    23
    Thanks for the advice Jeff!
    With a counterweight or strut system, it seems that the Z weight problem could be minimized. It won't kill me to spend the extra on a G203V / NEMA 34 system, but at ~ double the price of a G540 system... it is a hard sell.
    + at the ~$1000 for the 3 axis set of NEMA34, why not just go servo? Price diff is close to 0.
    The Mill came from LatheMaster. I looked at craigslist and ebay for a month. Considered the X3s. But after seeing the ZAY still on sale at Bob's website it just looked right. Bob has been great to deal with and the mill arrived in the same week that I ordered it. IH would have been a no brainer, if not for the over $1000 premium. (my wife already balks at this hobby. no need to send her on the warpath)
    So here is the confusing part... 500 oz-in is plenty to turn the ballscrews at 1:1 ratio (overcome gib friction + force to push cutter into material). What does a larger motor buy me? More acceleration?
    Feb 2007
    4553
    Testing the performance of the G540 and NEMA 23 motors on a RF45 mill
    Chris,
    Overcoming the heavy moving weight coupled with rapid inertia is a concern.
    The NEMA 34 motors and G203 drives would produce double or even triple the torque and holding power.
    On the other hand it would be interesting to see the performance of the G540 and NEMA 23 motors on a RF45 style mill, it may work just fine.
    If it works well you would not only save yourself some cash, a lot of Zone members would benefit with the knowledge.
    Worst case scenario you could always sell the Nema 23 motors and G540.
    There is a big demand for them here on the Zone.
    Please keep us posted.
    Jeff...
    May 2005
    2502
    Sometimes really big steppers can be a disadvantage, as they can't produce much torque at higher rpms.
    One way to look at your sizing problem is to try comparing to other commercial machines.
    Tormach is in the same category size-wise as your ZAY and is well regarded, what size steppers do they run on their direct drive? I have a vague recollection it was on the order of 650 oz in, but someone will know for sure.
    Industrial Hobbies runs 410 oz in servos, but they are not direct drive, they have a 4:1 ratio, so you'd need 1600 oz in on a direct drive to match. That's almost certainly radical overkill, so somewhere between 410 and 1000 may be about right.
    I have 850 oz in HomeShopCNC servos on my IH mill with a 2.8:1 reduction on X and Y, so that's still a whole lot of oz inches! Is it needed? Hard to say it was really necessary. I was playing with tuning the servos the other day and had the table flying around at 180 IPM. Mind you, I was just playing and made no cuts, that is likely not a workable speed for production!
    I do think I'd opt for NEMA 34 frame steppers as these are heavy machines. At the least, if you really want smaller motors, you could consider NEMA 34 for the Z-axis only. It's very heavy as was mentioned.
    Lastly, don't scrimp on the voltage to the motors. Read the articles available on running pretty high voltages relative to the motor's continuous rated voltage with the Gecko current limiting to keep things from melting down. That voltage really helps your acceleration.
    Should be a fascinating project that'll leave you with a very capable machine.
    Cheers,
    BW
    Jan 2009
    23
    Thanks to both of you for the insight and encouragement. I dusted off some of the old physics books last night and started to do the calculations to really find out where the limitations were. The conversion factors were a bear, so I did a little more searching online and found http://www.linearmotioneering.com/
    W00t! all the hard stuff is computed.
    From what I understand now, a 100lb x axis with a 5tpi screw, 120ipm rapid, .1m/s2 acceleration and direct drive will require 80Ncm @ 600rpm
    The stepper motor torque curves from Keling show that there are NEMA23s that will do this. The big problem is the mill head because not only do you have inertia, you have to overcome gravity. Here you would need roughly 1Nm @ 600rpm. That is NEMA 34 territory, but adding gas struts or counterbalance could reduce the torque needs.
    So, the main reason to go to a larger motor is acceleration and faster rapids. The faster you want to get the axis moving, the more oomph you need from the motor. And since the steppers drop off in torque very quickly, you run out of oomph to keep accelerating.
    Can these limitations be overcome? I think so... I'm looking at using Mach 3 and I think that it has acceleration settings. If I limited the acceleration or maybe used some of the anti-jerk settings in Quantum, the motor system may not have to be as over engineered as it was in the past.
    Hmm, cost of tinkering time + risk of being wrong + cost of head strut parts is > the ~$500 premium to go to NEMA34 setup
    Feb 2006
    7063
    Quote Originally Posted by clocker View Post
    Keep in mind those calculations are probably neglecting friction, which you can't do. So don't forget to "pad" them, especially if you operate in the winter in a cold shop. You'd be amazed what a difference temperature makes.
    Regards,
    Ray L.
    May 2007
    715
    I'm not a physics guy and can barely do math. But I can tell you that I had the smaller Super X3 mill and I tried to do the Nema23 motors all around on it.
    The X and Y worked fine with the Nema23s on Gecko 203v. The Z axis eventually snapped the shaft on the motor after about 3 months from fatigue. Luckily, I wasn't cutting anything at the time and the head didn't fall due to the way the belt works on my Super X3.
    Don't skimp, you will pay for it one way or the other.
    May 2005
    2502
    Quote Originally Posted by cjdavis618 View Post
    May 2007
    715
    Exactly. I started off using the Xylotex controller and a counterweight setup. I would get around 10ipm for Z speed and no more than 30 with X and Y.
    I then upgraded to the 203Vs, C11G Breakout board and a 12amp 72 volt PS. I was then able to get about 60ipm all around and even rapid at 120 on X and y. Using the 425oz nema 23 motors that came from my xylotex kit. The motor wasn't able to run the 100lb load without loosing steps. I put the Counterweight back on which was a 1:1 weight ratio and was able to keep up with the X and Y in speed. After a while though, the shaft snapped right at the motor shaft base. It was a clean twisted snap. I was in the process of setting up a new part and it snapped on the Z axis offset measuring. There was no force on the head at the time.
    There is a good reason for the Nema 34 motors having a 1/2" shaft.
    The 1/4" shaft of the Nema23s just isn't a good fit for a large mill. I would rather put larger motors in with direct connections. Even with gear reduction or pulleys to increase the ratio, I don't know that you will gain anything by reducing speed to get torque. Especially on an RF45
    May 2004
    600
    I am also the proud owner of a ZAY 7045 although I don't have the money at this point in time to get it going with tooling, etc. and much less so with a cnc conversion. Speaking of being low on money, I still owe €200 more to my friend that I bought it off. I did do some searches a couple of months ago to look for ZAY 7045 cnc conversions but don't remember finding anything. This thread is in fact the first log I've seen of such a conversion. With that in mind I'll be looking in from time to time to see how it's going for you so "good luck with it".
    Jan 2009
    23
    Thanks for sharing your experience. I sure don't want that to happen with this beast
    I totally agree with the penny wise pound foolish thought especially with these heavy machines. The one thought that keeps coming back though is that 100W is a huge amount of energy. It seems that the vendors are finally supplying motors that work within the recommended specs for the G250 drivers, so maybe it will work. Worst case I can transfer the setup over to the 11x26 lathe and get that running
    Nov 2005
    334
    First things FIRST
    HI,
    Have checked the LATHEMASTER Site and found the exploded view
    of the ZAY 7045FG. If you are going for a retrofit, I suggest you
    address the Cross Slide Leadscrew / Bearing problem first. Then you
    can concentrate on Motors, Drives & Power supply.
    The X axis appears to have 2 bearings on the front of the screw,
    none on the rear. The Y axis is not supported with a bearing on the rear.
    The LS Nuts may be cast iron, if so not good! Hopefully the Screws are
    high quality Acme screws, if so you can buy Delrin Nuts.
    See: roton.com
    all you need to know about lead screw design.
    I am in the process of upgrading two Enco Cross Slides. They are
    a high quality product made in Taiwan, but they have some of the same
    shortcomings as your Mill.. As retrofitted they will perform in a
    smooth & efficient manner under power.
    Since the 7045 has 5”quill travel, seems logical to drive it…Would
    only require a low powered size 23 Motor and wouldn’t effect the
    17” adjustable clearance under the Head.
    Take Care….W. Smith
    Jul 2005
    2415
    Contact Rick at HomeShopCNC. I worked with him to have some custom motors designed that match up to the Gecko's perfectly. Series mode they spec out at 3.5A and 620 oz-in. 3/8" shafts make them a little more hardy than the 1/4" ones. We use those motors with the G250 based box we sell (same drives as the G540) and guys are building 4 X 4 and even 4 X 8 plasma tables that have excellent performance. They are the same size as the 570's but better matched.
    TOM CAUDLE
    www.CandCNC.com
    Totally Modular CNC Electronics.
    Nov 2005
    334
    Whats next Torchhead?
    Tom,
    How about a Dual Stepper Interface Card for the G251?
    I've used several DS I/face cards for the G203V!
    Looks like you could also make a Dual Interface Servo Card for the new G351?
    Could you integrate them on a BOB?
    Thanks.....W. Smith
    Jan 2009
    23
    Thanks Tom! Just sent Rick an e-mail. We'll see if he has 'em in stock. Price for a DIY conversion hurts, but doing it with the G540 makes it a little better
    Got my fingers crossed that everything is in stock. Then just have to plan some long weekends (vacation days) and get to work. Hopefully this experiment works out!
    Jun 2007
    3891
    if you use a 2 or even 3:1 belt drive on the ballscrews you might be able to get away with nema23 while sacrificing top speed (whch you wont see anyway). thing is, all that extra work and parts will probably cost more han just buying the recomended motors and drives.
    Apr 2007
    2580
    ZAY7045l conversion....
    I too have the Lathemaster milling machine altho mine is quite different from the one he is selling now. I got mine about eight years ago and it is working very well for me. I am currently working on my cnc conversion and I gotta tell you that it is not a simple thing to do and not cheap to do but I am very excited about it. I also have to mimic the idea that the millhead is VERY heavy and you should try to buy the best and most powerful drive system your money can buy. I am using some 1125 oz in. servo motors and a 3-1 drive ratio on the three axes. Probably way overkill but I got the motors brand new for a great deal so I went for it. The steppers could certainly run this machine and I know a fellow that I shoot airguns with that actually owns one that was converted with some large steppers direct drive. Apparently even the Z axis is direct drive altho he told me that he removed much of the quill drive apparatus and the drill press handle assembly from the millhead since it is strictly a cnc machine. Apparently he just jogs the machine to the part and then loosens the quill lock and lowers the spindle to the work by hand to zero out and then locks it down and runs the program. He said that it actually removed quite a bit of weight from the head. I would strongly recommend going with a servo drive system of reasonable power. These mills are pretty good machines and heavy enough to move some decent metal. For a good idea of what a similar machine is capable of go to the industrial hobbies website and watch some of their videos. Pretty amazing feedrates and cut depths for a benchtop machine I tell ya. Now understand that the IH is a heavier and larger machine but it is not that much larger so you can expect performance at least in the realm of what that machine can do if you build the machine properly. Definitely get ballscrews and do the conversion and go with the G320 or G340 servo drives. Anther thing to consider is that you need to install a one shot oiler setup to help keep that machine running smooth. I just bought a bijur type oiler from Ebay and some leger ? fittings so I can do my setup. This is really not too expensive as I had at first thought. I think I will have less than a hundred dollars into the oiler system when I am done. These machines are quite capable and can be made to be very useful and accurate under cnc control if you do not scrimp on these things. I have found that it is taking me long enough to build the machine that I can kinda work out the purchases for each part until I am ready for them making it not seem so expensive. Besides once the machine is running right you should be able to easily make some money back with it doing the odd machine job for your buddies like I have been doing. Good luck and if you want to watch my progress I am in the thread " Finally getting started" peace....
    Jan 2009
    23
    Glad to hear that there are other ZAY owners doing conversions. Lots of opportunities to learn from each other. I went ahead and purchased the G540 system + all the other stuff for the conversion today. I was worried about the Z axis, so stepped up to a 203V and 1200 oz-in stepper. From the calcs that I did earlier, this should work out well. The end blocks are crazy expensive, so I picked up a few of these: http://bearingsdirect.com/store/inde...t_detail&p=605. At least the mechanical systems will be overkill.
    Time to start drawing out the schematics and getting the mill prepped.
    Apr 2007
    2580
    Clocker... so what are ya gonna do....
    About your ballscrews and mounts? I suppose with a direct drive mount you could make a simple plate with standoffs that houses the angular contact bearings and then do like I did and bore the floating end factory mount for a simple bearing. The X is the hardest part since it has to be free from binding down the length of the tables travel. The Z axis is floating on one end as is the Y axis so they are not so critical. When you get going on it be sure to post some pictures of the machine and your build as well as the obligatory video of it running at the end!!! peace....
Page 1 of 3 123
  1. Gecko G540 on a minitech minimill 2
    By Fixittt in forum Benchtop Machines
    Last Post: 06-07-2009, 05:31 PM
  2. New stepper for Gecko G540
    By automationtechinc in forum News Announcements
    Last Post: 01-29-2009, 05:18 PM
  3. Gecko G540 from Xylotex
    By gadman58 in forum Gecko Drives
    Last Post: 01-19-2009, 07:37 AM
  4. Gecko G540 and 2 powersupplys possible ?
    By isvflorin in forum Gecko Drives
    Last Post: 12-20-2008, 02:50 PM
  5. Gecko G540 and Motor mH rating
    By ronateah in forum Gecko Drives
    Last Post: 11-18-2008, 05:05 PM
