I own a Taig Mill, I would like too know where I can plug the backlash into EMC for compensation?
Anyone?
-Jason
Anyone?
-Jason
The backlash settings are found in the ini file under each individual axis, AXIS_0, AXIS_1, etc.
The backlash lines may not appear in a stepconf generated ini file. Should be okay to edit them in afaik. Look at the generic stepper_inch.ini file for an example of where to add these lines.
Anyone who says "It only goes together one way" has no imagination.
Ok, thanks cycle. If I have any problems, I will be sure too ask
-Jason
Here is a link to the manual page
http://www.linuxcnc.org/docview/html...XIS%5D-Section
John
Yes, that's exactly how to do it. I had to add my own backlash settings a few weeks ago when I switched to EMC.
How is working out for you?
-Jason
The backlash settings, or EMC in general? The backlash is fine, EMC's compensation works well. I had an early problem with it, but I'd caused it myself by messing with the setup and setting the axis' acceleration slower than allowed.
EMC2 works fine as well, I'm a lot happier with it than I was with the windows-based program I was using previously. It's been well worth the format and installation of Linux, in my opinion.
Just a bit of info on using Backlash here
http://www.linuxcnc.org/docs/devel/h...nfig.html#sub:[AXIS]-section
If you get following errors read the backlash section of the above link for the 2.3 docs
John
Wow the backlash compensation worked so easily and nicely! Very impressed and very happy that I have finally input the code into the file. Very happy.
-Jason
