587,328 active members*
3,498 visitors online*
Results 1 to 7 of 7
    Nov 2004
    141
    TNC145 homing problem
    I have an interesting problem on Beaver mill with a TNC145 control. If you try to reference the Z axis it runs to the home switch, reverses and finds the index as it should. Once it finds the index it then runs away at full speed and trips out a gross positioning error. The same happens with the Y axis but not X.
    I swapped Z and X encoders with no effect. I have also swapped the axis drive boards. Anyone seen this before?
    Jan 2005
    1121
    re
    not enough info
    back story please
    has the machine ever run?
    sounds like the parameters for counting direction are wrong
    Nov 2004
    141
    The machine was running fine then the Y axis ran away and tripped with a 'gross positioning error' halfway through a job. Now whenever you try to reference it runs away then faults immediately after referencing. I can't see it being a drive problem as it is perfectly controlled while referencing. Once it has faulted out, if you manually move the Z axis you can see the Z position display changing so the encoder appears to be working.
    Nov 2004
    3028
    Bad velocity loop (tach)?
    George
    Nov 2004
    141
    I'm not convinced. While homing the movement is smooth and stable. It is only once the index is found that it goes wild.
    Nov 2006
    925
    Had it on the X axis on a V5 with Siemens axis drive.Can`t remember the cause now.What model have you got?
    Nov 2004
    141
    It is using Siemens drives but I am not sure what model. I can't get to the machine at the moment to check.
  1. Z axis homing problem
    By BillTodd in forum LinuxCNC (formerly EMC2)
    Last Post: 08-26-2008, 08:55 PM
  2. EZ-TRAK SX II homing problem HELP!
    By guitarist1904sd in forum Bridgeport / Hardinge Mills
    Last Post: 08-05-2008, 03:08 AM
  3. Just another homing problem
    By jeffrey001 in forum DIY CNC Router Table Machines
    Last Post: 06-01-2008, 01:18 AM
  4. Problem With Homing X Axis
    By elalto in forum Mach Software (ArtSoft software)
    Last Post: 09-16-2006, 01:28 AM
  5. Homing Problem V4.0.1
    By BMaynard in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-13-2006, 07:22 AM
