587,529 active members*
3,145 visitors online*
Results 1 to 6 of 6
    Jan 2009
    30
    G78 threading cycle on Fanuc 0i-TD
    Hi
    I am trying to program the G78 threading cycle on a Fanuc 0i-TD without the proper Fanuc manual. I have the standard 0i-D manual which does not cover the G78.
    Please can someone who knows this control jot down a quick example for me, say an M8 x 1.25 external thread 20mm long, 5 rough passes, one finish pass and one spring cut.
    Thanks for your help
    2932
    If I'm not mistaken, the G78 cycle is programmed exactly like G76. The G76 is used in G-Code systems A and B, the G78 is used in G-Code system C. Have you tried the G76?
    In my experience, most Japanese/Taiwanese/Korean, etc. machines are set up to use G-Code system A. Some American-made machines were set up to use system C.
    Jan 2009
    30
    Quote Originally Posted by dcoupar View Post
    Hi - Yes it seems you are correct. The parameters for G76 seem the same. I have not tried G76, but I will now.
    Any idea what the difference is between G76 and G78?
    Many thanks
    2932
    No difference other than the G-Code system.
    harshal Guest
    Re: G78 threading cycle on Fanuc 0i-TD
    G78 FANUC THREADING CYCLE PROGRAM FOR LATHE CNC EXAMPLE - CNC PROGRAMMING TUTORIAL
    Friends , G76 and G78 are similar threading cycle in fanuc contol cnc . Sometimes some fanuc control cnc model working with G78 Cycle . Mostly used for threading cycle is G76 , behaves same as G78 threading cycle. Manin program will be same , change is only is place of G76 .
    N10 M06 T01 01 ;
    N20 M04 G97 S1000 ;
    N30 G00 X45 Z5 ;
    N40 G78 P020060 Q100 R50 ;
    N50 G78 X38.7 Z-50 P1227 Q100 F2 ;
    N60 G00 X45 Z5 ;
    N70 M05 M09 M30 ;
    DESCRIPTION OF MAIN PROGRAM :-
    N10- Tool change command , select tool no. 1
    N20- Spindle ON anti clockwise , constant spindle speed command , speed is 1000 rpm
    N30- Rapid action command where X45 and Z5 .
    N40- Threading cycle command , P020060
    ( P02 = No. of finished path
    00 = Chamfer amount at end
    60 = Angle of tool tip ) ,
    Q100 = Each cut is 0.1 mm ,
    R20 = finishing allowance 0.02mm
    N50- Threading cycle command , Minor dia X axis , threading along Z- axis up to -50 , Threading depth , Depth of finish cut 0.1 mm , pitch is 2 .
    : M40X2
    Major diameter is 40
    Pitch is 2
    Thread depth calculation = Pitch x 0.61363
    = 2 x 0.61363
    = 1.227 mm in micron is 1227
    Minor diameter = 40-1.23 = 38.7 mm
    N60- Rapid action command where X45 and Z5 .
    N70- Spindle off , coolant off , main program end .
    FOR MORE DETAILS VISIT WWW.HDKNOWLEDGE,COM
    Sep 2010
    1230
    Quote Originally Posted by harshal View Post
    An ancient Thread that was answered succinctly by dcoupar with "No difference other than the G-Code system."
    The G76 and G78 cycles are not only similar, but exact same with an alternate address. There are three different G Code Systems available with a Fanuc ontrol, A, B and C. A and B use G76 to execute the Multi-repetitive Threading Cycle, whilst the G Code C System uses G78.
    Regards,
    Bill
  1. g76 threading cycle
    By Readme00 in forum Mastercam
    Last Post: 06-17-2014, 07:59 PM
  2. Fanuc 6t threading cycle.
    By jetfuelgenius in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-14-2011, 06:50 PM
  3. fanuc threading cycle 4 a 21-t lathe
    By offset col in forum Fanuc
    Last Post: 07-14-2010, 03:49 AM
  4. Threading cycle
    By chrisryn in forum Parametric Programing
    Last Post: 06-12-2008, 09:04 PM
