587,486 active members*
3,888 visitors online*
Thread: Mill project
Page 2 of 3 123
Results 21 to 40 of 52
  1. #21
    Jun 2004
    6618
    There are at least two candidate there.
    Here is one I bought to run a different motor.
    http://www.surpluscenter.com/item.as...tname=electric
    Here is another.
    The motor I bought but have yet to use is here.
    http://cgi.ebay.com/Diamond-Back-Tre...QQcmdZViewItem
    It is a nice motor and has a big fan on it already. Some of those at Surplus center need the fan bought extra.
    Lee
  2. #22
    Nov 2007
    479
    Wow, looks like a nice "Rigid" machine you got there.
  3. #23
    Feb 2006
    1187
    Hey Jester any update? I was taking another look at your machine and was thinking man that looks like a prime candidate for a polymer concrete base. Keep us posted!!!
  4. #24
    May 2003
    792
    Did someone say polymer concrete?
  5. #25
    Jul 2006
    23
    Sorry, no updates yet.
    I will look into polymer concrete some more, it may be the perfect solution for my base and I hadn't even thought about it. Thanks!
  6. #26
    Sep 2006
    1738
    Whatever happened with this, looking into building a mill one day and looking at all designs!
    Updates please!!!!!
    -Jason
  7. #27
    Feb 2006
    1187
    Yeah whats up Jester? This was one of my fav designs and would love to see the end result!!!!!!!!!!!
  8. #28
    Mar 2005
    306
    Quote Originally Posted by Jester966 View Post
    This weekend I finally got around to taking a few pictures of my current project, so I thought I'd post a few. I've built everything myself except for the spindle and gear box, which is from an X2. The head can be tilted 45 and 90 degrees either way, if ever necessary. Travel is 20" on X, 11" on Y, and 14" on Z.
    There's still a lot to do, but at least all the "big" stuff is done, and it kinda almost looks like a mill now! Left to do: top plate for column and end plates for X and Y, lead screws (screws, bearings, nuts, and handwheels), find and install a motor, and figure out what I'm doing for the base. I will hopefully add stepper motors or servos and CNC it after I have it working manually.
    All that will have to wait though, as the whole thing is now packed up in the corner of my garage so I can get my car in and out for the winter... at least it will give me some time to save up for some nice ballscrews!
    great pic, are you test run?
  9. #29
    Nov 2007
    118
    Hi tivoidethuong.
    Very nicework. Alot of man hours.
    So what are you thinking about using for a motor? Treadmill?
    Belt drive or gear?
  10. #30
    Dec 2006
    839
    WHat ever you do , don tlet it set there until it starts rusting.
    The PC would make a great base, or even one of those cheap Chinia Granite surface plates. That would make a great base and easy/quick to make happen. It could even be easy to change out latter if you did build a different base later. Plus there already pretty darn flat, even the cheap ones. Drill it and put inserts in it to bolt the mill parts down to.
    I seen a high dollar factory built setup ( assembly machine that did only one thing,was about &200,000.00) that came with a high quality granite plate for the base of the machine. It had rails & blocks just like yours bolted down on it and then the whole thing was set down in a inclosure. It was intended to be very acurate and the granite block was used because of no changing in size through different temps. This thing had to operate in some tight tolerances and theh granite base is part of what helped it hold them.
    I will one day build a setup much like yours and use the granite block base setup. I believe you can get a 24' X 36" for around $150.00 at Grizzly. This one would weight about 400lbs so it would be a very sturdy setup. Plus for $79.00 you can even get a stand for it, but I dont know how sturdy the stands are.
    If I was going to use one I dont know about bolting the column down to it, although I have seen things bolted like this that gave no problem. But my thoughts was to bolt a 1" steel plate down to the granite and then bolt down to the steel plate. This would allow for grinding flat if need be plus be alittle stronger hold on the column part.
    Jess
  11. #31
    Jan 2009
    82
    Wow! think we all want an update on this one.
  12. #32
    Jan 2009
    82
    What size steeper motors would be good on this?
  13. #33
    Jun 2004
    6618
    Looking great!
    I would say that it depends on your screws and if you are going to use timing belts, but I used Keling 495's on my mill. I run them direct drive on X and Y, but I had to use a belt on Z. I can rapid @ 300 IPM with no issues, but I don't run it that fast. I use about 200 IPM on Z and maybe 240 on X and Y.
    I am also using Gecko 203V's and a Keling 72 VDC 12 A power supply.
    This size or larger should satisfy your needs fine I think.
    I think you may need a smaller vehicle so you can have ongoing projects and still park inside. You full size vehicle is keeping us from seeing this things do it's thing.
    Lee
  14. #34
    Jul 2006
    23
    progress...
    Well due to a series of job changes, a lack of funds, a move to a house with no garage (), and the fact that I no longer have access to the shop in which I started this build, it has been a long time since I have been able to work on this project. However, I have finally had a chance to make a small amount of progress!
    It's not much, but I've now got an ACME lead screw installed for the Y-axis. Eventually I would still like to convert the machine CNC, but since I'm too broke to buy ballscrews and servos, for now I am working on installing ACME screws to get it working manually.
    The screw, nut, bearings, and handle were pulled from an old piece of equipment that I got from work for free. To install the screw, all I had to make was a new block to hold the nut, and the front plate to screw the front bearing "block" to. I also had to drill/counterbore four new holes in the saddle plate in order to move the nut foreward because my original design had the nut positioned in the center, and this screw is already a bit too short. Because the screw is too short, I have had to sacrifice about 2" of travel on my Y axis. I still have 8" of travel though, and I think that will be plenty until I (eventually) replace it with a longer screw.
    The huge block on the front (which houses the bearings) looks very crude. This was also pulled from the equipment and, because I was working with only basic tools available, it was much easier to use it as-is. I will eventually come back to this and tidy it up with a new plate that houses the bearings itself, rather than just bolting a bearing "block" to the plate. For now though, it gets my Y-axis moving and allows me to move on to the next step.
    Currently there is no indication of measurment along the Y-axis. I think this is a minor problem though because there are other ways to make accurate movements for finish cuts, like using indicators. Regardless, I will address this after the major components of the machine are finished. Since I will later replace all the hand wheels with my own (matching) wheels anyway, I will make dials at the same time. Eventually I would also like to install scales and a DRO anyway.
    Here's a better picture of the whole (what's done so far) table:
    On the bench just behind the table you can see a 3/4"-8 ACME screw that is a spare lead screw for an Atlas 10"x36" lathe. This is what I am planning on using for the X-axis (because, like the Y-axis screw, it is also free!).
    Although it is only a small step, getting the Y-axis working is very motivating. I now have some limited access to the manual machines at work, so when I can find time I will work on the parts to get the X-axis functional.
  15. #35
    May 2005
    89
    Wow! Its nice to have you back!
  16. #36
    Sep 2006
    1738
    Man, Can you imahine this machine with ballscrews, CNC'd and a really nice heavy steel base plate to attach eveything? You would be set!
    Wish there were updates, I hope to use this design one day.
    -Jason
  17. #37
    Jul 2006
    23
    Quick update:
    Due to a position change at work, I've now got access to manual mills and lathes (and a surface grinder) again. So this week I'm working on getting the X-Axis working. I'm still using acme screws, but it will be relatively easy to swap them out for ballscrews in the future when I get into the CNC conversion.
  18. #38
    Sep 2006
    1738
    Omg yes! Been waiting for this!!!!!
  19. #39
    Jul 2008
    922
    hope you got your essentials sorted m8
  20. #40
    Feb 2007
    24
    Hello,
    I like the style of your machine. Which kind of axiscovers are you planning?
    Greetings,
    Rene
Page 2 of 3 123
