587,486 active members*
3,482 visitors online*
Page 1 of 2 12
Results 1 to 20 of 26
    Oct 2005
    3
    Russian UHU by Hudognik
    Let's see that project and discuss it
    Attached Files Attached Files
    Jan 2005
    1050
    does this use the UHU chip , I think not - U have your own program to run it and the schematic is to run it of direct 110V AC / 220v AC right?
    impressive, tell us more
    Oct 2005
    3
    That is chan modificated servo DC , SAME AS UHU
    ((( DC ))) servo
    and it works!!!
    Jan 2005
    1050
    any pictures?
    Nov 2006
    70
    How about current limit? ...
    Jul 2003
    1758
    None that I see.
    Quote Originally Posted by HJozsi View Post
    Jan 2005
    1050
    oh i think "my own" doesn't want to discuss this!
    Jul 2004
    13
    Hi.... my own
    your circuit and ATmega8 code is all test OK
    thank .....
    Aug 2003
    9
    Smile Russian translating?
    Hi myown!
    Are you involved in this project, if so could you translate the tuningsoftware to english. I am not so good with russian,(not english either), and the project look interesting.
    Gunnar
    Feb 2007
    13
    Smile
    Very nice to see code and schematic
    Thanks a lot for share
    Let us know for new versions v0.3 ...
    Apr 2005
    26
    Please provide the Web address
    Jun 2008
    66
    This not compatible with UHU controller. This improvement servodrive Elm Chan http://elm-chan.org/works/smc/report_e.html. Discussing the improvement goes in russian forum http://forum.rcdesign.ru/index.php?showtopic=40981.
    Apropos on scheme there is errors ( HL1,H2 - LED, Anode VD16, VD19 to Gnd). The New variant of the scheme with checking the current and external amplifier photointerrupter here.
    Excuse me for my bad English.
    Jul 2004
    13
    arisov77
    Thanks a lot for share........
    Apr 2005
    26
    Can't log on elm-chan.org
    Can translate that the ServoTuning.exe becomes English?
    Jun 2008
    66
    That who produces itself(himself) for author ServoTunning – Hudognik does not answer, therefore the source code is not present. I only upgraded the scheme and a code under ATmega8. I send translation ServoTunnig (ScreenShot)
    Aug 2003
    9
    Smile
    Hi arisov77!
    Thank's for translating the software, and for helping with other translation. Your english is better then mine so i dont think you need to excuse for that. Try to find someone in outside your contry that speek and write your language.
    Gunnar
    Jun 2008
    66
    My version of PCB and PhotoPCB (without the protection of current site).
    Moderator You can move the topic in the branch where discussing Elm Dc Servo Controller, for example, here http://www.cnczone.com/forums/forumdisplay.php?f=177? And change name of the subject, for example, «Russian variant Elm Dc Servo Controller». It is not UHU controller.
    Jun 2008
    66
    To me here already in private message have entered some questions about functioning(working) the servodrive.
    I tried to practically use this version but every time i tried to set the parameters the atmega8 become dead after some time. Have you practically used this version ?
    I will write here for all.
    For me and for some other people too the such occurred. I described it at Russian forum, I will short describe here.
    Necessarily program EEPROM - differently will not earn.
    Failure in operation of the servodrive with code Servo_mega8_int.hex and Servo_mega8_int.eep from the Artist (so is translated - Hudognik) which spread myown occurs to because of change EEPROM. Therefore necessarily in AtMega8 it is necessary to program Fuse Byte BODLEVEL.=0 (Reset under 4V). Paths of reduction of probability of reset EEPROM the following:
    1. Full opto uncoupling MC and Motor and Input
    2. Brown-detector (internal or external)
    3. In Programm Code - change the address EEPROM after writing and sensing, on address not containing data, duplication cell EEPROM, following their comparison and choice of the most frequent importance (program majorization).
    Also there is other reliable way is absolutely to refuse a data storage in EEPROM that I have made. Though there is metod in this way inconvenience of the adjustment, but reliability - better.
    Though For this I have entered as follows: first in AtMega8 write the code from Artist , I used servo_mega8_int.hex (Flash) and servo_mega8_int.eep (EEPROM). Then in ServoTuning change slider, change PID-factors and write them on paper. Afterwards got decimal importances translate in hexadecimal (on 2 bytes). These hex in AVRStudio with my Code ServoFinishArtistInt.asm write in subroutine LoadPIDParamRAM (there there are a few English comments), shall compile and already final (finish) hex-file programme in AtMega8.
    Above specified by .asm files I have saved - from the whole spare - from EEPROM, relationship with on RS-232. With these code servodrive can only work with Step&Dir. That only me and it is necessary.
    For that, to whom it is necessary relationship on RS-232 has done ServoUART.hex - her(its) also possible use for selecting PID-factor, adjust in ServoTuning, only it is impossible will write PID-factor in EEPROM. At autonomous inclusions at once passes to servomode on Step&Dir.
    By the way, device power supply (on LNK520) can be made from 16 to 350DCV (at appropriate replacement С3). I have tested the Power supply on many constructions.
    Aug 2003
    9
    Hi!
    I have now tryed the software on the orignial ELM driver but can't get it to work with that controller.
    Is ther any output from the controller that give a signal if somthing is wrong with the system, like ELM does? Will it stop if it loos control of counting and simelar problem. Is there anybody that have tryed this??
    Jun 2008
    66
    During the experiments showed that if the chain to change the current shutdown protection (not to SD in on IR2184, but IN) that VT3-VT6 overload will bask significantly less. Has Installed IRFP260.
    At Russian forum prompted me to my errors - for better reliability set: R8 = 330 - 1 kOm, C12-C13 is not 220mFx25V, a ceramic 0,22 mF-1mF. But even with those errors servocontroller works.
    Code also remade by AtMega88. Tested only on AtMega88, but easily rebuilt under AtMega48/168.
    In Private Messages me asked about transformer T1. It made me at the Russian ferrite ring cores M2500HMC1 K16x8x6. Approximate analog B64290-K45-N72 (R16) (Epcos). Ring cores break and then glue with 1 gasket 0, 07mm. W1 = diameter 36AWG (0,15 mm), N = 70; W2 = diameter 32 AWG (0,25 mm), N = 13. Primary Inductance = 2,5 – 3,5 mH.
Page 1 of 2 12
  1. Modernization of the Elm Dc Servo Controller (Russian UHU by Hudognik)
    By arisov77 in forum Open Source Controller Boards
    Last Post: 01-17-2024, 06:13 PM
  2. Documentation for Mach3mill in Russian
    By makathid in forum Milltronics
    Last Post: 04-30-2014, 01:00 PM
  3. Russian CAM software
    By motordude in forum Uncategorised CAM Discussion
    Last Post: 01-31-2004, 10:39 AM
  4. Sorry, russian link!
    Last Post: 01-29-2004, 10:53 AM
