587,925 active members*
3,496 visitors online*
Results 1 to 5 of 5
    Jan 2007
    129
    V2XT 19" lcd & Stainless panel
    Hey gang, here's a picture of my 19" lcd retro fit to my V2XT. I just finished cutting out the stainless panel. Did all the lettering on the mill as well. Too bad I didn't think to do the "start" "enable" etc etc lettering too.........
    (chair)
    Peace
    9 1/2
    B.C.I.T. Machinist CNC
    Mar 2008
    17
    nice
    Dec 2003
    24220
    Nice Job:rainfro:
    BTW, did you put any protective shield over the LCD?
    Al.
    Albert E.
    Jan 2007
    129
    Thanks guys. I'm probably going to pull it off and put the other lettering on it. The felt pen is sort of an eye sore.
    Al, i didn't put any cover over the LCD. At this point, there is no coolant or other issues getting over there. What do you recommend? Do you think "window film" would work? You know like the oil change stickers?
    Owen
    9 1/2
    Dec 2003
    24220
    I use a material recommended for use with shop LCD's it is Acrylite FF P-99 anti-glare finish.
    I usually buy it by the 1/2 sheet, but a local plastic supplier may oblige with a smaller piece.
    Al.
    Albert E.
  1. I NEED a V2XT DX-32 " User Manual " BAD!!!
    By v488 in forum Bridgeport / Hardinge Mills
    Last Post: 03-17-2008, 11:53 AM
  2. V2XT error message "DRIVE FAULT detected (0,z,y,x) check log"
    By rfdoyle in forum Bridgeport / Hardinge Mills
    Last Post: 10-08-2007, 09:35 PM
  3. Replies: 5
    Last Post: 03-24-2007, 03:40 PM
  4. V2XT Control Panel Updates
    By NEATman in forum Bridgeport / Hardinge Mills
    Last Post: 10-06-2006, 05:32 AM
  5. Wanted; V2XT way wiper " the rubber one"
    Last Post: 02-12-2006, 07:05 AM
