587,481 active members*
3,188 visitors online*
Results 1 to 3 of 3
    Sep 2006
    11
    Driver Board from PMINMO
    greetings !
    I made exact copy of this driver board http://pminmo.com/3axis/3axis.htm
    only changes I made are instead of IRLZ 44 mosfet I used IRFZ 44
    I am using some small unipolar steppers-3.9 V,1.3 A ,12 V power supply and current limiters 5.6 ohm ,9W resistors.
    Now everything works fine,but resistors seem to heat pretty much,I can not touch them!
    mosfets are not heating at all,even without heat sinks
    Is this normal for current limiters to heat so much or I did something wrong here?
    Jun 2004
    463
    Yes it is normal for current limiting resistors to get very hot. With a 12v supply, those resistors will be dissipating nearly 11 watts which is all turned into heat. That is also higher than the power rating of the resistors. You generally want a safety margin for the resistors so you would want at least 15 watt resistors.
    You could eliminate the resistors and all the heat by building the chopper board at the bottom of that page.
    Sep 2007
    6
    the small unipolar steppers not muth with the driver try to change it with a small resistane stepper motor i have the same problem and i solvet
  1. single axis driver and a b.o.b.,or multi-axis driver board
    By .xXACEXx. in forum Stepper Motors / Drives
    Last Post: 07-03-2007, 05:13 AM
  2. PMinMo Driver and Interface Board
    By mymojo in forum CNC Machine Related Electronics
    Last Post: 04-26-2007, 07:14 AM
  3. Question PMinMo Breakout Board
    By huckshooter in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-21-2005, 03:46 PM
  4. New and need your help Please (driver board)
    By Oldmanandhistoy in forum CNC Machine Related Electronics
    Last Post: 06-12-2005, 10:48 PM
  5. driver board
    By mtaddei in forum Benchtop Machines
    Last Post: 11-19-2004, 09:13 PM
