Thanks Ian & Neil.
Ian,
Could give some indicative dimensions. Say the lengtj across the flat back, the length of the sides the length to the flat on the front, the flat on the front and the distance between the flats, I guess the bearings could be 22mm skate bearings. From these measurements I will be able to draw the shape in Autocad.
Thanks again,
