587,745 active members*
2,764 visitors online*
Results 1 to 12 of 12
    Oct 2004
    2
    Smile DSTV file format?
    Does anyone know what the DSTV file format is? I know that it is a standard format used by some commercial steel detailing software to go from a CAD drawing to your CNC machine. I am unclear as to whether it is the format approved by the German Steel Association & how widely it is used.
    I would really like to get hold of a copy of the format for this file type. Does anyone have one? (or a standard documentation for it; or the description of the fields?). Any help appreciated.
    Many thanks
    Jul 2007
    1
    Hi.
    I provide the DSTV file, to my client from SDS. The extension I have tof DSTV file it is "nc1".....for Ped1100 machine.... I don't know if I can help you...but I can try, even I am working with SDS2.
    Jan 2007
    14
    Quote Originally Posted by muntean mihalea View Post
    Hi.
    Dacă tu poţi acordă-mi mai mult informaţii I a putut probably ajutor tu. I a opera Peddinghaus machines.
    Translated using Intertran
    Apr 2008
    2
    DSTV file format
    I have a copy I got from a Google search on DSTV file format. It is about 15 pages and gives you all of the info you need if you can progam. It is getting to be the standard file that most machines can read. One file can go to multiple machines...
    Apr 2008
    2
    It is written in German
    Jul 2008
    1
    DSTV file format
    I have been searching online to find the DSTV file format but I had no luck.
    Can you please send me the document you mentioned in your post.
    Your help is highly appreciated.
    Regards,
    Shreef
    Aug 2008
    4
    The first 24 lines are confusing.
    Jan 2009
    5
    May 2013
    DSTV format is an industrial standard defined by the German Steel Construction Association (Deutsche Stahlbau-Verband).
    A DSTV file is a text file in ASCII format.
    May 2013
    May 2013
    The DSTV standard does not support curved beams, and therefore Tekla Structures does not create NC files for curved beams. Use polybeams instead of curved beams.
    Conveyor Bracket
  1. anyone have the DSTV file format?
    By ABC123 in forum Uncategorised CAM Discussion
    Last Post: 12-10-2019, 09:34 PM
  2. How do i get my autocad file onto mastercam?
    By EdE in forum Uncategorised CAM Discussion
    Last Post: 02-23-2011, 06:54 AM
  3. Emco Compact 5 PC...have ????
    By Double G in forum Mini Lathe
    Last Post: 08-23-2010, 12:26 AM
  4. Boot disk for EZ-Track DX, batch file?
    By mmm2003 in forum Bridgeport / Hardinge Mills
    Last Post: 01-31-2007, 06:47 PM
  5. Do me a favour ( DWG-DXF Conversion)
    By ynneb in forum G-Code Programing
    Last Post: 04-07-2005, 02:04 PM
