587,770 active members*
3,092 visitors online*
Results 1 to 10 of 10
    Aug 2007
    95
    ROTARY TOOLPATH
    Attached is a part i'm trying to cut on our roatry using a fadal and mastercam 9.1. I'm not sure about the toolpath,I have heard of the rolldie c-hook,and also the multiaxis-swarf 5ax and msurf 5ax. Any advice????
    Attached Files Attached Files
    Apr 2003
    3578
    What part of it do you need help with the groove half way around?
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
    Aug 2007
    95
    Yes, the groove and the rads(around the groove and the lead in rads)
    Dpark,
    Is this what you are looking to do? I used multi-axis 4th axis rotary you can cut this the across or the along directions also surfaces work better for this in v-9.
    Steve Arteman
    www.cad2cam.blogspot.com
    www.cad2cam.net
    Programmer/ Certified Cam Instructor
    Aug 2007
    95
    Can you also use a rough toolpath with the rotary 4th toolpath?(to step down)
    Apr 2003
    3578
    dpark No there is not an option for step down in 4th rotary. I usually will do a Surface rough and index to a few postions then come back and do the rotary.
    Cadcam
    Aug 2007
    95
    Here is my toolpath but I cannot get the path to look right.Any advice?
    Nov 2007
    1702
    I'm a total nOOb at this stuff but it looks like you have the wrong 4th axis chosen. In MCX, the dialog for that operation has another option box for "4th Axis". You had the X-axis selected. I changed it to Z and it generated what I think you want (to rotate the die around as you cut the groove). I imagine that it's similar in MC9.
    That may not be correct for the machine but it fixed the toolpath problem. I think something different has to be done with your toolpath origin and orientation, then select the proper 4th axis direction.
    And thank you. By posting that, I was finally able to figure out if my license for MCX included the 4th axis as I was promised. I only got half of a 4th axis it seems (no solid simulation--wants another code).
    Greg
    Apr 2003
    3578
    that can be done in either in standard 4th axis rotary under the multi axis or do 3d surfacing and use rotary option and use 3axis or Multiaxis5 can be done to.
    I was working earlier a sample in V9 but had to run. wont be able to post till tomorrow.
    Cadcam
    Dpark,
    Go to Multi-axis parameter page the 4th axis button is about y, you have x. As far as roughing leave stock and do steps with multi axis 4 axis roughing leave a .25 then leave .125 and so on this works good.
    Steve
    [email protected]
    www.cad2cam.net
  1. Help with toolpath.
    By MagooT in forum Mastercam
    Last Post: 02-20-2010, 02:04 AM
  2. toolpath using rotary axis
    By dpark1 in forum Mastercam
    Last Post: 09-04-2007, 12:42 PM
  3. Toolpath set up?
    By Jessica in forum ArtCam Pro
    Last Post: 03-13-2007, 05:13 PM
  4. 3D toolpath help
    By Dfennell in forum BobCad-Cam
    Last Post: 02-03-2007, 08:13 AM
  5. How do you create this toolpath?
    By squarewave in forum Mastercam
    Last Post: 10-18-2006, 01:40 AM
