I have recently accuired a Hurco SM-1 knee mill and was considering a retrofit with an Ajax controller. Has this been done in the past? Would I be able to keep the servo motors?
Tom
Tom
If your servo motors are dc brushed the Ajax retrofit should be compatible. Check with Matt at Ajax for specifics. He is really helpful. I am finishing a lathe retrofit with Ajax and will soon have final comments.
jh
jh,
it was Matt that I talked to and he indicated that he needed this info to be able to know whether I could use these servos.
Tom
Hi
I am undergoing through the same problem.
==> After M19, my spindle orients properly but it jerks suddenly
==> Also if i rotate the Clamped spindle by hand it moves 2 to 3 degrees & again tries to restore its original position.
I think i should increase the clamping force on spindle after M19 - BUT
1. Is it possible to change through Parameter Setting ?
2. What is the recommeded force ?
3. What is maximum force & need to know if any consequences are there if the force exceeds maximum limit ?
Thanks...Need Help Urgently.
Ash
Ashih
I think this post on the Ajax will help answer your questions:
http://www.ajaxcnc.com/ajaxbb/viewto...=35&p=124#p124
Hi
Thanks for your Reply. Your post was the one for which i was looking since long.
As mentioned previously, I think that my spindle oscillates after M19 command. It doesn't happen everytime but sometimes it happens.
Can u recomend the best value for GAIN, to skip this oscillation on my spindle. ?
Also can u recommend the best value for Tolerance Window to allow high accuracy spindle positioning. ?
Need Help !
Ash
When homing, M92 P11 Q12 R3, first axis zeroes and then machine stops. I get no movement from y or z. Also M92 P12, or M92 P3 gets no movement either. Is this a brain problem, or M92 Macro?
Thank you
