587,827 active members*
2,825 visitors online*
Results 1 to 6 of 6
    Jun 2004
    26
    Power Supply Question
    If I was using 3 servo motors that at stall draw 44 amps each with Gecko 320's which allow a maximum current of 20 amps with fuses to prevent to much power to the motors, would I need a power supply capable of providing 60 amps? Where can I get transformers that could provide 60 amps? Also, how is that VA rating for transformers calculated?
    Feb 2004
    2337
    What is the continuous running rating of your servos? Amps?
    VA means Volts X Amps. So if a tranny has 10 Volts and can deliver a constant 10 amps, it means it has a 100VA rating.
    If you are looking for a transformer with high amps, you are probably better off getting one made up for you. Just shop around with the quotes before hand though.
    Being outside the square !!!
    Jun 2004
    26
    They have a nominal voltage rating of 60V and a maximum continuous current rating of 8.9A.
    Apr 2004
    439
    Feb 2004
    2337
    Then I guess you will need a transformer that has about 42 Volts AC output and 30 Amps rating. Once you rectify the 42Volts AC it will become 60 volts DC.
    The transformer will be 42V x 30A=1260 VA
    This will be suitable for you setup I think. If you are in any doubt you can always beef up the amperage just to make sure. Dont however beef up the voltage because this will damage your servos.
    Oct 2003
    399
    A 42 VAC, 30 A transformer would give you about 58 VDC, 21 A continous output. If you want 30 A out, you need to use a transformer rated for 42 A.
    UDC = UAC * sqrt(2)
    IDC = IAC / sqrt(2)
    You cannot get 58 VDC * 30 A = 1740 W DC out with only 42 VAC * 30 A = 1260 VA input.
    Arvid
  1. Power Supply Question
    By BobLWeiss in forum Stepper Motors / Drives
    Last Post: 04-17-2005, 08:27 PM
  2. Power Supply ground question
    By chas in forum Gecko Drives
    Last Post: 04-16-2005, 12:48 PM
  3. FNG Power Supply Question
    By SteinAir in forum DIY CNC Router Table Machines
    Last Post: 01-01-2005, 04:31 AM
  4. Yet another power supply question!!
    By chas in forum CNC Machine Related Electronics
    Last Post: 09-17-2004, 05:49 AM
  5. i got a power supply question
    By ljoe1969 in forum CNC Machine Related Electronics
    Last Post: 01-12-2004, 06:19 AM
