587,499 active members*
5,104 visitors online*
Page 1 of 5 123
Results 1 to 20 of 98
    Nov 2005
    152
    My 4X4 table build
    After many months or reading and researching I am finally ready to start building a plasma table. So here are the specs.
    48.5"X48.5" travel
    water tank
    369oz steppers
    dual drives on the y
    Gecko 201 stepper controllers
    20 degree 20 pitch rack and pinion
    3.75:1 gear reduction
    Hiwin 15mm LG rails on the Y and Z
    THK HSR25mm rail on the x
    CandCNC Digital THC
    Mach 3 control.
    Hypertherm 1000
    The Table will be made from 3x3x.125 square tube so I started milling the cross pieces for the table square and held .001 on length.
    Then I started drilling and tapping the holes for the 25mm rail for the gantry.
    Next I started on the Z. The Z is .188 HR plate and 15mm Hiwin rails. It will have 6" of travel. The single rail will be used for the floating head for the torch.
    Jan 2008
    26
    Looking good so far. Thanks for taking us along for your build.
    DRL
    Feb 2006
    1260
    Welcome to the journey. Judging by your having access to a horizontal boring mill. I'd suspect you have access to all the other machine tools, Lathe(s), Milling machine(s), etc to produce a very fine & detailed Plasma table.
    Why the small size?
    If it works.....Don't fix it!
    Nov 2005
    152
    Quote Originally Posted by millman52 View Post
    Why the small size?
    I was going to build a 4x8 but I just don't have the shop space and I don't really need anything bigger right now. I know I will kick myself later when I need bigger, but I will build another if it comes down to it.
    Oh, I am a Manual machinist in a huge machine shop, so I have access to all the cool machines.
    Feb 2006
    1260
    I sort of figured space must be an issue. Other than that it just doesn't cost that much more to go bigger. You might want to try & leave 1 end of the table bolt together. That way if you later want to expand to 8' or even longer length it can easily be done.
    It sucks not to have enough room for at least a 4 X 8. That way sheets od stock are economical & you don't first either have to have them sheared in 1/2 or cut them down yourself first.
    Apr 2007
    641
    Good to have a new build again!!! Fine start too, paint it while building , after done you´ll not want to take it appart ....
    Feb 2006
    1260
    Hey Lamicron, Hows your machine running? Sold it yet? Building another?
    Apr 2007
    641
    Hi Rich! Yes I sold it!!! And sold another 2!! Now Im building two 4x8 and one 4x4 for me, and also one router 4x4, i´m waiting to have the material tomorrow. MAybe start a thread with one of those...´One will be a water table for plasma and a router, i ´ll build it with a rapid table change.
    Luis
    Apr 2007
    641
    Rich, where did you buy your pulleys? I need 3:1 pack. and belts. Can you help me with part numbers?
    Luis
    Feb 2006
    1260
    Quote Originally Posted by lamicron View Post
    Luis
    Luis rather than keeping Bigtoy's thread hijacked. Start a build log in: Plasma, EDM and other similar machine Project Log & pm me the link to it or I'll find as I'm on practically every day. I'll look for the information & get back to you there later.
    Neil
    Apr 2007
    641
    Sorry for that, you are rigth.
    Luis
    Nov 2005
    152
    I got a little bit more done today. I got the Y rail holes drilled and tapped, then I welded the frame all together. I still need to weld a sheet on the bottom to form the water tank.
    the welds
    holes for the rails.
    Feb 2008
    2
    Bigtoy,
    I recently came across this site. WOW! I have wanted, but could not justify a toy this expensive for a couple years. The prospect of making a plasma table myself has consumed my spare time. Like you, I am reading everything I can find on the subject. I am working out the details now. I plan on starting the build by early summer ('08). I look forward to your updates. I am a fairly accomplished welder myself and I would like to say your welds are impeccable. It looks like we are neighbors too, as I live in southern Oregon.
    ---Bob
    Jan 2008
    4
    Beautiful welds
    Feb 2006
    1260
    Quote Originally Posted by xtremehobbyist View Post
    Bigtoy,
    ---Bob
    The fun really begins when you start a build.
    I was a total greenhorn when I began. I made up some CAD drawings mainly to keep some of my ideas straight. I was lost for quite some time. I really wanted to have most all my parts gathered up before I started.
    There are so many things that depends on the part next to it. What do I need to buy so I don't build myself into a corner? Is this heavy enough, Is that strong enough? If I buy this rack & pinion, What belt reduction ratio do I need. Darn I actually would like to have my motors in hand so I can build the drives as small as practical yet rugged & strong.
    All these things & trying to think things through to the end took many hours of head scratching & decision making. The time thinking paid off though in not having to un-do progress already made.
    Looking back I could easily build a second table. Mine has worked out great so far. If I were to start over there is a few things I'd do different but not many.
    Nov 2005
    152
    I made some caps for the legs so I could screw so adjustable roller feet in them.
    Then I got the bottom of the table sealed off with a piece of 16 gauge. I welded
    small beads all the way around and let each one cool to try and reduce warping.
    Here are my gantry side plates all cut out.
    I then started working on the Z axis acme screw. The bearing blocks where machined for a 608 bearing. The acme screw is a 1/2-10 single single start screw. The nut is a delrin nut from Dumpster CNC.
    Nov 2005
    152
    Today I had to straighten the table. It had warped about .125 all the way around in the center of the tubes. I did the old heat and quench trick to shrink the top back down. This method worked really good.
    Then I mounted the rails and welded the gantry tube to the side plates.
    Now after I had the gantry all welded together I totally understand what racking is. I am sure glad I didn't cheap out and not buy a extra motor to dual drive the Y.
    Feb 2006
    1260
    Quote Originally Posted by Bigtoy302 View Post
    Have no fear the dual slaved drive will completely eliminate the racking. Mine seemed limp as a noodle. everyone that saw it said it would never work. When you get everything hooked up & power on the motors you'll be amazed how solid it becomes.
    Neil
    Nov 2005
    152
    So, today I got the belt drives, racks and the Z mounted. I Also tested the water tank to make sure I had no leaks. I added some tubes on the bottoms of the legs for more support. With nothing there the table was just to shaky. I still have some finish weld and I still need to make the slat holders, but other wiring and paint it's almost done.
    Feb 2008
    2
    Z Axis
    Bigtoy,
    I don't understand your Z axis. It appears to have 2 slide systems and only one of them is powered. Does the other float? Will it eventually be powered? Your table looks great! One last question, do you know how much the gantry assembly weighs?
    Thanks,
    Bob
Page 1 of 5 123
  1. Newbie - To build or not to build Router/Plasma Table
    By dfranks in forum Waterjet General Topics
    Last Post: 04-08-2011, 05:16 AM
  2. New Large Table Build in Houston, TX (Build Log)
    By anitel in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 12-30-2008, 09:45 AM
  3. Does anyone here build their own table saw?
    By starCNC in forum WoodWorking Topics
    Last Post: 02-11-2008, 02:29 AM
  4. nub wants to build cnc table
    By monte55 in forum Waterjet General Topics
    Last Post: 08-06-2006, 12:39 AM
