587,495 active members*
3,608 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Are Ballscrews Hardened Steel or not????
Results 1 to 10 of 10
    Dec 2005
    141
    I ordered ball screws from Roton from the link on hosses website (http://www.roton.com/Mating_Componen...family=7059321) are they hardened steel??? i am looking for a place to turn them down and some of them are telling me they cant due to not having carbit tooling
    thanks mike
    Dec 2005
    430
    they are cold rolled steel, so about 0.070" in is pretty hard. you will need carbide tooling to cut this hard outer case, it will eat HSS for breakfast. they are not hard like a bearing though, but you will have to turn them on a strong lathe.
    103
    Yes, they are hardened.
    Dec 2005
    141
    thanks guys thats what i thought
    Aug 2005
    191
    I used a surface grinder to grind the spots where the bearings press fits on. A surface grinder does not care if the shaft is soft steel or hard as a bearing race. I also just had to shorten a THK shaft which uses a recirculating ball screw. Had to cut it while on the machine; used a hacksaw with a bimetal blade and it came off in about 5 minutes using a single blade. So it can be done in some cases if the shaft is not too hard. Run a file over the end; if it bites you can probably cut it.
    Aug 2004
    2849
    I heat the area that I need to turn to an orange red....then let it slowly cool....use carbide tooling and they are easy to machine...the hardest part is indicating them in the chuck.
    I also use an abrasive cut-off saw to cut them to size.
    Jun 2004
    822
    Quote Originally Posted by ViperTX View Post
    This is the way to do it. I ruined several cheap carbide inserts and a couple good ones before I decided to anneal mine. Once annealed, they cut like butter. If you heat it too fast, it will warp though so do it slowly. Also, stick the portion that you aren't annealing under water.
    Jul 2005
    969
    i turned my 5/8 roton on my 11x26 lather and all went fine i did ude some cutting oil with my carbide tool to do it
    The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
    When I cut mine I wrapped a large wet towel around it and cut it slowly using an abrasive saw. Then heated the very ends where the bearings would be going to cherry red and placed them in a bucket filled with sand to make sure they cooled evenly and slowly. I have used this with ballscrews from small and cheap to 2 1/2" high end ground ballscrews. Nothing screws up your day like having to buy another 10k ballscrew.
    Jan 2005
    2010
    A tool post grinder will allow any lathe into which the screw can be chucked to cut the landings and the chuck makes a pretty effective heat sink.
    “ In questions of power, let no more be heard of confidence in man, but bind him down from mischief by the chains of the Constitution.” Thomas Jefferson
  1. cutting 10mm hardened steel shaft?
    By andy_ck87028 in forum Mechanical Calculations/Engineering Design
    Last Post: 06-25-2007, 02:12 AM
  2. Spot drilling case hardened steel
    By Zumba in forum MetalWork Discussion
    Last Post: 03-04-2007, 08:32 PM
  3. Machining Hardened Steel Shaft
    By jimbobbus3 in forum MetalWork Discussion
    Last Post: 11-10-2006, 04:41 AM
  4. Cutting Hardened Steel
    By Smackre in forum Waterjet General Topics
    Last Post: 02-08-2006, 08:12 PM
  5. Drilling hardened steel shaft
    By Zephrant in forum Uncategorised MetalWorking Machines
    Last Post: 06-13-2003, 09:42 PM
