I'm looking for a good source of spindle bearings, 15 Degree Angular contact ABEC7 medium preload, 7207 I believe..... Not necessarily a set specifically for a Bridgeport but some the right size. Oh and it's for a series 1
thanks
thanks
Hi:
Your local bearing shop will be able to provide you with whatever specifications you can find in the catalogue. the type of bearings you are looking for are typically referred to as spindle bearings. All of the bearing manufacturers can supply you with that type of bearing. Be prepared to pay big $$$, as the spindle bearing is the heart of the machine.
regards
I had good luck with these.
http://www.p4bearings.com/servlet/th...C-P4DUL/Detail
