587,920 active members*
3,615 visitors online*
Results 1 to 3 of 3
    Sep 2007
    34
    x axis slipping
    Hi we have a fadal 15xt we are taking heavy cuts on the x axis,
    it seems like the x axis slipped about 1.25 inches.
    I sent the machine to the home position and checked the alignment marks and they were off about 1.25 inches.
    we took off the cover and checked the coupler between the motor and ball screw and both set screws were tight and had not slipped.
    does anyone have any suggestions?
    Thanks in advance
    Erich
    900
    I would have to believe that the coupler has slipped. On the couplers that are not keyed, if you over tighten the clamp screw you distort the hole and reduce the holding power and slippage can occur.
    Can you jog the machine back to the C/S makers and do a cold start and have the makers aligned correctly? If so then the couplers did not slip.
    Alternatives would be the motor resolver is loose and rotated (doubtful) or that you experienced an electronic issue.
    Neal
    Feb 2006
    60
    That apears once on my 3016. But i think, that i forget to pres cs bevore i start milling. Location of spindel was off the mark and also null position for the program.
  1. Fadal Low Speed Belt Slipping
    By BAD DOG in forum Fadal
    Last Post: 05-18-2014, 11:34 PM
  2. Y Axis Slipping ??
    By twocik in forum Benchtop Machines
    Last Post: 12-12-2007, 12:11 AM
  3. stepper motor internals and drive slipping help
    By rally.sport in forum Stepper Motors / Drives
    Last Post: 01-03-2007, 10:30 PM
  4. EZTRAK Y axis loosing position, "slipping"
    By melamark in forum Bridgeport / Hardinge Mills
    Last Post: 12-18-2005, 08:23 PM
  5. Boss z-axis belt slipping
    By jderou in forum Bridgeport / Hardinge Mills
    Last Post: 06-01-2005, 07:08 PM
