587,726 active members*
3,486 visitors online*
Results 1 to 5 of 5
    May 2003
    792
    Wire&Connector Checklist
    Hi Folks, I'm about to start building my servo box and want to get your opinion on connectors, fuses, wire size etc.
    the system:
    power supply - 1.5KVA, 170VDC, 9A
    AC drives - 1kW, 12.5A
    AC motors - 1kW, 11.7A, 100V
    8 wire quadrature encoder
    motor brake 24V
    motor/encoder cable length 15ft
    jog pendant cable length 15ft
    Checklist will include:
    1. encoder wire, connectors
    2. motor wire, connectors
    3. fuses on AC line, DC logic and drive power
    4. pendant wiring & switches
    5. limits & wiring
    6. other
    Here are my choices for encoder wire:
    Belden 9538, 24AWG strand (7X32), 8 conductor
    (aluminum-polyester shield with stranded tinned copper drain wire)
    and encoder connectors:
    Tyco AMP CPC type http://www.action-electronics.com/ampcpc.htm
    I can't seem to come up with anything for motor power. What do you think about this one?
    It's a 14AWG 4 conductor HOSA speaker wire with Speakon connector that locks into place via a latch-type lock, available at local stores for approx $50/25ft. Would this be enough for my servos?
    Your help and comments will be appreciated.
    _
    Jul 2006
    1256
    Walter here are some specs on the speakon connectors.
    Model#NL-4
    current 30 amp per contact
    Voltage 250
    Wire size up to 12AWG
    Steppers need shield cable,I don't know about servos,you should check.
    I am guessing,but I imagine servo drives are PWM which would require shield cable.
    Larry
    L GALILEO THE EPOXY SURFACE PLATE IS FLAT
    Jul 2006
    1256
    Walter,
    Here is wire the boys from Oz recommend.
    Braided shield has more flex.
    Larry http://www.lappusa.com/Spec_Template.asp?nGroupID=10114
    May 2003
    792
    Thanks Larry.
    I found them in my Allied Electronics catalog, next to the Igus chainflex which also looks decent. Good find.
    Nov 2004
    61
    I used similar wire with
    the molex connectors for the power
    but seem to be having trouble with the connectors at times
    if you come up with good connectors let me know
    at this point I am thinking of using regular
    extension cord connectors I can get them close by
    and they seem to stay connected pretty well
    dependable would be nice
  1. Need help locating a connector
    By DennisCNC in forum CNC Machine Related Electronics
    Last Post: 06-08-2006, 02:07 AM
  2. Need connector
    By cncadmin in forum CNC Machine Related Electronics
    Last Post: 03-17-2005, 07:26 PM
  3. 25 pin connector
    By polyhedron12 in forum CNC Machine Related Electronics
    Last Post: 02-23-2005, 11:40 PM
  4. Conversion Checklist
    By DAB_Design in forum Benchtop Machines
    Last Post: 07-01-2004, 06:05 AM
  5. Reality check, materials checklist for electronics
    By Darren_T in forum DIY CNC Router Table Machines
    Last Post: 12-05-2003, 03:36 AM
