587,129 active members*
3,042 visitors online*
Results 1 to 10 of 10
    Jun 2004
    44
    construction started with the Z axis last night
    Well I started with the z axis last night
    after making a find at princess auto
    and a stop at the local plastics shop
    for some off cuts to play with
    the large pic is realy big be careful
    http://www.bobcat.ca/stuff/cnc/DSCF0001.JPG
    ans here is some more
    I haven't remove the paper from the acric yet but I was pretty happy the the burnishing cam out one of the pics you can see the treads I cut in
    Apr 2003
    1079
    Wowsers that's a biggun! I didin't wait for ti to load, but it is waaay off of my screen, any chance you could re-size it a bit!
    For those playing with a 56K handicap this is a resized pic...
    Jun 2004
    44
    IE will resize them once they are down loaded but the are just over a meg
    I have my bandwidth kinda maxed right now try again in about a hour
    sorry I'll resize some more later
    I don't like to waste the goodness my camera produces
    Is that Lexan you are using?
    Jun 2004
    44
    no it is acrilic I wish lexan was as easy to find
    not super strong but I had to start building it was a scrap I grabbed
    while I was at the plastics shop
    I was at the welling shopp looks like I may have some scrap aluminum for this piece next week and I have my 1" round bar and my 1" angle for my x and y
    but I scored thoose rails and wanted to see how sturdy they would be with something mounted up
    here is the pic that shows the threads
    there a a bigger on that show it better on the site in the first post
    well I burnished the edges just for the sake of making look perty until it gets used the first time
    Apr 2003
    1079
    Acrylic eh? I take it you will be cutting balsa or light ply with your machine. I guess it will suffice for that, but if you crash the router into a fixture, then you could have a loaded router jumping around the bench, spinning at 30000rpm. I am not trying to put you off, but please be aware of the dangers if the acrylic should snap. Keep postin' them pictures though
    Jun 2004
    44
    I know the dangers and I plan on replacing it with something more sturdy
    down the road I just happen to have a piece of acrilic the right size just needed holes drilled
    Broncosis, have you made any more prgress on your prjoect?
    Jun 2004
    44
    not Really
    No I just started work at a plce that build CNC machines making prosteics
    so my new parts availabillity has thrown me back in to the design phaze
    and when I get these next 2 machine done at work they I willl have a couple of Minutes to think about it
    but the z axis is going to grow some what useing some left over thompson
    berrings that we are no longer using and I plan on using a THK knock off type bearing made by INA and maybe even some real nice ball screws
  1. 4020 4th axis problems
    By little bubba in forum Fadal
    Last Post: 06-14-2005, 03:08 AM
  2. Lets get started; new mill
    By Stevie in forum Vertical Mill, Lathe Project Log
    Last Post: 05-20-2005, 03:09 AM
  3. No Encoder Counts On X Axis. Y=OK
    By murphy625 in forum CamSoft Products
    Last Post: 03-09-2005, 03:20 AM
  4. 2 axis to 3 axis conversion
    By drembedded in forum Bridgeport / Hardinge Mills
    Last Post: 10-27-2004, 05:32 PM
  5. 2.5-Axis vs 3-Axis
    By JamesBond in forum Uncategorised MetalWorking Machines
    Last Post: 07-27-2003, 01:09 AM
