I'm looking for ways to cut aluminium and plastic on my wood router machine. I've managed to do some aluminium with poor results (works, but with very rough vertical surfaces and very shallow cuts). I'm thinking my two biggest problems are runout on the wood router and spindle speed.
The slowest I can get the router is 10K RPM. While you can cut aluminium and plastic in that range, you really have to be moving fast in order to not melt the workpiece. Of course, once I start moving fast the lack of stiffness in the machine results in horrible chatter.
I was thinking of buying a Sherline milling headstock & motor combo (PN# 6514) and mounting that for these materials. This way I could run at much lower spindle speeds and not be forced into using high IPM settings.
I wouldn't expect to get the same cutting speeds/depths of cut as a sherline mill since the wood router table is still nowhere near as stiff as a Sherline.
What do you think, would this be worth doing?
