587,462 active members*
3,089 visitors online*
Results 1 to 3 of 3
    May 2007
    1026
    Cutting fabric?
    I'm looking at building a machine to cut fabric--small to start but eventually I'm looking for an envelope up to say 36x60". From my research so far, I think the first approach to try is to use a rotary cutter (similar to a pizza cutter) driven like a tangent knife.
    What I need is software that can generate appropriate g-codes to rotate the cutter and also to calculate lead-in and lead-out cuts, starting from something like a DXF. Vinyl cutting seems to be the most closely related activity, so I figured this would be a good place to start asking questions.
    Sep 2005
    1
    Hello Sansbury,
    Any updates on your project?
    I am also interested in this type of Project.
    Gkunzig
    Sep 2003
    1113
    You might get some good ideas from this site:
    http://www.carlsondesign.com/
    I seem to recall the cutter rotates about the vertical axis - and if the wheel is small enough maybe no lead in/out required?
    Neat project - what do you plan on cutting/making?
    :cheers: Jim
    Oops! Just noticed on the shareware page:
    http://www.carlsondesign.com/#Professional_Shareware
    about 1/2 way down a good shot of the mount for the cutter - its directly mounted to a stepper! (well it sure looks like it anyway). That should take care of lead in/out - the blade would always be tangent to cutting line - an interesting 4th axis to solve! -- Jim
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
  1. laser cut and burnout on fabric
    By goddessofchaos in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-12-2011, 02:42 AM
  2. Fabric laser cutters
    By mdiaconu in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-18-2006, 09:03 AM
  3. Fabric cutting control software question
    By krumly in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-21-2006, 06:36 PM
  4. I need help about cutting heads which apply to apparel pattern cutting machine
    By sheepgrass in forum Mechanical Calculations/Engineering Design
    Last Post: 05-12-2006, 07:09 PM
  5. Building Fabric Cutter with blade
    By handrade in forum Community Club House
    Last Post: 08-29-2005, 11:30 PM
