587,744 active members*
2,823 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Taig Mills / Lathes > My Initial Setup-Taig/Xylotex/Mach 3/DeskProto
Results 1 to 3 of 3
    Hello, all.
    Just wanted to show off my set-up in its first iteration.
    http://johnbearross.com/prototyper.html
    Of special note is the high-speed spindle I fabbed up from some HDPE and a Bosch Colt palm router.
    Thanks to Nick Carter of www.cartertools.com for his assistance and great customer support.
    Best,
    John Bear Ross
    www.johnbearross.com
    Aug 2006
    231
    taig setup
    very cool.
    So you said Mech's and tanks. Stuff for GW or some other. I would be interested in seeing your work. Are you cutting directly into white metal?
    I have a taig myself as well and cut directly in white metal.
    Quote Originally Posted by under-dog View Post
    very cool.
    I'd love to know your speeds and feeds for working white metal, as well as which cutters you're using. I'm experimenting right now with Blue Machineable wax, Nylon 6/6, Delrin, and UHMW PE.
    I did a number of builds for Reaper Miniatures' game, Combat Assault Vehicle, or CAV. Most were done on a Modelmaster II 3D printer, lost-waxed into silver, and then vulcanized normally.
    Link on my page is http://www.johnbearross.com/reaper.htm
    I've also done a number of starships for Cold Navy, and a few builds for Wizkids' latter-day version of Battletech called Mechwarrior.
    Best,
    John Bear Ross
  1. Taig + Xylotex and I want to try EMC2
    By 725franky in forum LinuxCNC (formerly EMC2)
    Last Post: 08-06-2007, 07:38 PM
  2. HELP ME- taig and mach 3 setup
    By hollyfeneht in forum Taig Mills / Lathes
    Last Post: 02-05-2007, 07:57 PM
  3. xylotex setup
    By johnm99 in forum Xylotex
    Last Post: 08-03-2006, 06:37 AM
  4. Xylotex setup file
    By anoah in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-09-2004, 04:36 AM
