587,104 active members*
4,334 visitors online*
Results 1 to 16 of 16
    Sep 2007
    27
    Fanuc o-t parts counter
    Purchased another used Hardinge, same control as another we have. Noticed on position page it has a working parts counter and cycle time. Anyone know how to zero out the parts counter? Don't tell me it's a parameter. Hardinge tells me there is an entire page for just the counter, I can select the number of pieces and the machine will stop cycling? Can't find anything to that effect.
    May 2006
    265
    I think you got to go offsetkey a couple of times and when you get to the PWE screen, press arrow down 1-2 times and you will get the part required and machined parts pages. MUst be in MDi to set new numbers here.
    Jun 2007
    119
    Quote Originally Posted by steer View Post
    To zero out the parts counter (on position page) press "P" and then press "Can"
    To zero out cycle time(Run Time) on position page press "R" and then press"Can"
    Sep 2007
    27
    Pressing "P" then "CAN" works like a charm, thanks.
    Couldn't get to the PWE page by hitting offset button. Hardinge tek said the same thing, maybe I'm doing something wrong but I don't see the PWE page.
    Jun 2007
    119
    Quote Originally Posted by M-man View Post
    Yes for Fanuc 21,18
    But on Fanuc O-T for enable PWE press "Param/Diag" and with "Page up" or "Page Dw." go to SETING 2 screen (in MDI mode) and set PWE to 1
    Prameter no.600 is to set Number of Required Parts
    Sep 2007
    27
    Works great, thanks. no need to go to parameter 600, can change it right on the PWE page.
    Sep 2007
    27
    Is a big deal to turn this feature ON in my other machine?
    Jun 2007
    119
    Param. 907 bit 4 for run time and parts count display.
    Sep 2007
    27
    parameter 907 on machine with parts counter read "01011010" on the other machine with no counter it reads "01001000" , so 2 bits are changed?
    It's been awhile, also forgot how to enable PWE to change paramter.
    Jun 2007
    119
    No
    On Fanuc O-T for enable PWE press "Param/Diag" and with "Page up" or "Page Dw." go to SETING 2 screen (in MDI mode) and set PWE to 1
    param. 907 bit #7 #6 #5 #4 #3 #2 #1 #0
    bit#4 For Run Time and Parts Count Display set param 907 bit 4 to 1
    bit#1 is for 2nd Aux. function
    Sep 2007
    27
    Works great! Seems like it's always been working, just not displayed. Parts counter was at 480,380.
    What do you think the aux. function is?
    Mar 2010
    1
    This did the trick for me, had to be in MDI mode. Thanks!
    Nov 2011
    39
    Re: Fanuc o-t parts counter
    Steer,
    My X axis died and can't read the ac motor numbers can you help ?
    CHNC I OT control
    wiring diagram A13B-0139-8540
    GEF OTB
    CN-3085-T
    Thanks in advance
    Edwin Murch
    [email protected]
    Apr 2020
    2
    Pdf on ot parameter
    Dec 2009
    967
    Quote Originally Posted by viorel26 View Post
    No
    Domnule Viorel
    daca nu stiati va amintesc eu ca indicarea parametrilor speciali ca de exemplu 907.4 catre terte persoane se face doar in privat si nu public
    daca continuati veti fi inlaturat din forum
    adaca doriti sa ajutati pe cineva cu modificarea parametrilor speciali din seria 900 la orice controller, va rog sa o faceti privat.
    Sper ca ati inteles.
    Numai bine
    @Everyone
    If you want to help somebody by modifying the special paameters from 900 series to any controller ,please do it privatly with the user you help
    Do not post this public as you will be removed from forum.
    Thank you.
    Jan 2019
    2
    Hi everybody
    I need help for fanuc o-t. we purchased a lathe with fanuc o-t controller but there is no document with machine. If any body has any documents please send me.
    my email: [email protected]
    Thanks.
  1. Replies: 1
    Last Post: 06-11-2014, 02:53 AM
  2. parts counter
    By r0dman3 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-16-2012, 07:15 AM
  3. parts counter
    By r0dman3 in forum Controller & Computer Solutions
    Last Post: 02-13-2012, 01:39 AM
  4. fanuc ot parts counter
    By bala955 in forum Fanuc
    Last Post: 02-12-2012, 03:40 AM
  5. Fanuc parts counter
    By scubanick in forum Fanuc
    Last Post: 07-12-2006, 07:16 PM
