587,089 active members*
2,895 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > losing work coordinates at power off
Results 1 to 14 of 14
    Jul 2007
    19
    Question losing work coordinates at power off
    I've been working on a machine with a fanuc o-m controller for about a week trying to get it up and running. We got this machine from another plant in our corporation, and nobody in house really knew a whole lot about it. With the help of some members here, and a whole lot of reading in the archives, I have almost all of the issues ironed out.
    One thing I haven't yet figured out is that when we power down the machine, and then power it back up, it loses its work coordinate settings. They don't go to zero, they just seem to randomly change. Tool length settings are fine, it's just the work coordinates.
    Does anyone know how to correct this? I suspect there may be a parameter that needs to be set, but I don't know what it is.
    Nov 2006
    174
    Work coordinates.
    Do you mean work offsets? Which page are you viewing to see your "work coordinates"
    If you are viewing the "Relative" page then yes these will not be stored at power off.
    You should have your "work coordinates" set in the Offset page
    eg.
    SHIFT(00) G55(02)
    X.............X.........
    Y.............Y.........
    Z.............Z.........
    G54(01) G56(03)
    HTH
    Jul 2007
    19
    no, I'm losing my g54 absolute coordinates
    Jan 2006
    4396
    Quote Originally Posted by jlong58 View Post
    That is what he meant.
    Have you checked the Memory Battery Yet?
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Jul 2007
    19
    yes I have replaced the batteries. It didn't make a difference.
    Jan 2006
    4396
    Do you have the Machine Tool and Control Manual?
    There is a Diagnose Page where you will have to read the bits. If you can find that Parameter then write down the Bits after setting the G54, Kill the Power to see what changed.
    This is most likely a question for Al_The_Man, he would know.
    Sorry I can't be of better help.
    Toby D.
    Schwarzwald
    Jun 2005
    232
    Are you using g92 g54 x0y0 to set your coordinate.
    If you are using the g92 preset it is cancled after power down thus losing your position.
    Tim
    Oct 2004
    8
    We are using G10 command in start of every program. It sets work coordinates every program run.
    G90G10L2P1X....Y....Z..... for G54
    G90G10L2P2X....Y....Z..... for G55
    G90G10L2P6X....Y....Z..... for G59
    BR
    Sauli
    Dec 2003
    24223
    I am not sure I am understanding this, if you reference the machine at start up and you are registering a G10 position for the work coordinates in the program , what is missing?
    As you should be automatically re-registering the work co-ordinates when you run the program.
    Al.
    Albert E.
    Oct 2004
    8
    Different pieces have different fixtures or different place in fixture (vise), so the work coordinates (offset from reference point) are different also. That’s why we are setting the work coordinates in the program. There is no matter, what happens: electrical interrupts, shutdown, do other job, push wrong button… whatever. If you have a right program for current job, you always have right offsets.
    We have several CNC machines (Fanuc and Siemens) and we have used this method in all of them for many years.
    Dec 2003
    24223
    Quote Originally Posted by saulij View Post
    Different pieces have different fixtures or different place in fixture (vise), so the work coordinates (offset from reference point) are different also. .
    Sorry, I was getting you mixed up with the original poster and thought he was using your method and it was not working.
    I agree this should be the way to go.
    Al.
    Albert E.
    Jul 2007
    19
    I think Timlkallam may have answered my question. I am setting the work offset by moving to the location, and then going to MDI and typing G92 x0yo. If I understand correctly, that method will be cancelled at power off. Is this correct? If so, I will simply set the offsets manually.
    Jan 2006
    4396
    This is what needs to be done with a Yasnac MX2 Control at Morning Start Up.
    O0099
    (MATSUURA YASNAC MX2)
    (SEND MATSUURA CNC HOME)
    (SET RAPID AT 25 PERCENT)
    (PRESS CYCLE START)
    (AFTER HOME POSITION)
    (G92 X0 Y0 Z0 IS SET)
    (CHECK POINT G55 CENTER)
    (RE-CHECK BACK HOME)
    (RUNS WARMUP PGM)
    (RUN ONE TIME = 10 MINUTES)
    G0G17G40G49G80G90M5
    G91G28Z0M9
    G91G28Y0
    G91G28X0
    G92X0Y0Z0
    G90G55G0X0Y0
    G91G28Z0
    G91G28Y0
    G91G28X0
    M98P9999
    M30
    Toby D.
    Schwarzwald
    Jun 2005
    232
    Yep G92 works great untill you cut the machine off.
    On my control witch is a Fanuc oi mate . When I cut it on I home it then jog the X and Y where i need it to be , Then go to the work coordinate page highlight say G54 and type in x0 then press the measure key and the value is stored even if the power to the machine is cut off.
    Tim
  1. How does a power supply work.
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 07-27-2011, 03:40 PM
  2. Will this power supply work?
    By dneisler in forum Gecko Drives
    Last Post: 05-04-2007, 06:34 PM
  3. Compaq Power Supply.. Anyone get one to work?
    By EGropp in forum CNC Machine Related Electronics
    Last Post: 02-26-2007, 11:52 PM
  4. Could this work as a cheap power supply?
    By phantomcow2 in forum CNC Machine Related Electronics
    Last Post: 03-05-2006, 11:10 PM
  5. Okuma Work Coordinates
    By firedog in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-10-2005, 12:43 AM
