587,147 active members*
5,690 visitors online*
Results 1 to 7 of 7
    May 2003
    325
    Question Hi Temp Antisieze ?
    I was looking through a jet engine overhaul manual recently and ran across this strange (to me) procedure.
    When replacing the main burner and afterburner igniter plugs they say to coat the threads with milk of magnesia !
    Anybody have any clue as to what purpose this serves?
    I thought it was as antisieze but in other procedures in the same area they specify an antisieze compound. So, I'm confused (again).
    robotic regards,
    Tom
    Apr 2003
    1873
    Maybe because it will dry powdery thus reducing or eliminating Galling?
    Apr 2004
    59
    Re: Hi Temp Antisieze ?
    robotic regards,
    Tom
    I work on large, powerful GE turbines every day. Yes, it is an anitseize trick. Milk of Magnesia dries to a fine powder. This powder will not deteriorate with heat. Normal antiseize will deteriorate and dissapear with time during extreme heat cycles. M.O.M. will leave an even coat that works like nothing else.
    Dave:banana:
    Apr 2004
    678
    Does it work well on bolts/nuts in car turbo manifold systems?
    And where do you get it (manufacturer)?
    I don't think we have any magnesia cows around here. ;-)
    Apr 2004
    59
    Don't know. I've only used in on HPT assemblies (high pressure turbine). Sorry buddy.
    May 2003
    325
    Thanks C131fr
    That cleared the murk a lot.
    MoM (milk of magnesia) is a remedy for acid stomach and diarrhea. Buy it at your local drug store (chemist-, apothecary-shop?).
    Philips is a popular brand in the US.
    robotic regards,
    Tom
    It is good to have an end to journey toward; but it is the journey that matters, in the end.
    - - Ursula K. LeGuin
    edit:
    oops! It's NOT for diarrhea, it's a laxative.
    Seems I suffered a little mental constipation when I wrote that
    Dec 2003
    41
    You know that stuff that weightlifters put on their hands to get a better grip? Its milk of magnesia in block form.
  1. spindle temp, motor temp.
    By nervis1 in forum Uncategorised MetalWorking Machines
    Last Post: 07-20-2004, 03:09 PM
  2. servo motor
    By mace in forum DIY CNC Router Table Machines
    Last Post: 02-08-2004, 10:07 PM
