587,513 active members*
2,811 visitors online*
Results 1 to 5 of 5
    Jun 2007
    26
    New Used Larken 24/24R
    I have just bought a used in REALLY great condition Larken 24/24R router.
    1) I need a operator manual - can I download one somewhere?
    I have downloaded Starcam 1.85 and StarCNC 2.06 already.
    I also downloaded and printed the manual for the software.
    Is there another manual - for the machine?
    2) I have a laptop with Win XP - no serial port/parallel port
    Can I some how use the USB port to hook it up to the control box
    I have a USB Serial converter a 9pin to 25 pin converter. I hooked that all together and plugged in to the control box but the machine did not respond
    Leo
    Feb 2007
    966
    It runs for the Parallel port on any windows PC.
    Your best to run it from a desktop pc though, but you can get older Laptops with a parallel port.
    Be sure you plug the computer and control box into the same surge-protected power bar and then plug the router power cord directly into the wall.
    Jun 2007
    26
    Getting going
    Larry,
    I got an old desktop - and I have the spooler software running.
    I beleive there is an issue with the z-axis stepper being wired wrong. The previous owner admitted that they fooled around with the plug going to the z-axis stepper.
    I will be sending pics to your e-mail address either later today, or tomorrow.
    Thanks for your responsiveness and promptness.
    I am sure this machine will run well.
    It apears to be a well constructed machine. Nothing cheap about it.
    I will be in touch.
    Leo
    Jun 2007
    26
    Z axis
    Larry,
    I got my Z axis to move up and down in jog mode without the router mounted.
    WITH the router mounted it does not go up. The stepper motor is not strong enough to move the router UP.
    Do you have a stronger stepper motor?
    My email is receiving but not sending.
    Leo
    Feb 2007
    966
    From your picture, the Z motor is not wired correctly. Someone rewired it.
    It needs to be connected in Series for best performance and torque. I have it on paper if you have a fax.
    Larry
  1. Larken 2424R
    By MikeBerry in forum Larken
    Last Post: 01-10-2009, 03:36 PM
  2. Larken is still
    By cncadmin in forum Larken
    Last Post: 12-16-2008, 04:23 AM
  3. Larken Router Models
    By routerman in forum Larken
    Last Post: 06-23-2007, 12:50 PM
  4. Larken, Techno, Precix, or used?
    By Drassk in forum Commercial CNC Wood Routers
    Last Post: 06-17-2007, 04:47 AM
  5. Larken
    By CNC Pro in forum Larken
    Last Post: 02-12-2004, 02:14 AM
