587,523 active members*
3,861 visitors online*
IndustryArena Forum > MetalWorking Machines > EMCO CNC Machines > EMCO Lathe > Concept Turn 155 Turret Make / Model (Live Tooling)
Results 1 to 2 of 2
    Jan 2006
    176
    Folks,
    Any chance someone with a Concept Turn 155 that has the turret with live tooling could drop a reply here with the manufacturer and model number info or a pic of the model plate? I'm looking at a retrofit of one where the machine is like new, but it was the "economy" model with the more basic turret and I'm on the lookout for the more capable turret so I can do a bit of an upgrade.
    Thanks!
    May 2016
    318
    Re: Concept Turn 155 Turret Make / Model (Live Tooling)
    My 325-II uses a Sauter 0.5.474.510 turret. I believe the 155 used the same turret when the live tool option was fitted.
    Sauter still has a 0.5.473.5xx turret listed on their site and it appears identical to mine.
    If you do find one, be prepared for some financial pain when tooling it up with live tools. While they're not as expensive when new as bigger VDI holders or BMT, unlike the more common sizes VDI16 live tools are essentially unobtainium on the used market.
    I've been searching world-wide for 4 years, and I've yet to find a used live tool that fits the Sauter turret & drive. New - axial are about $1100 and radial are about $2k.
  1. Puma 2500LSY live tooling squeal from turret
    By Silv3rDragon in forum Daewoo/Doosan
    Last Post: 01-03-2023, 03:57 AM
  2. Emco Concept Turn 155 ACC
    By Fire_in_the_hole in forum EMCO Lathe
    Last Post: 09-12-2022, 02:13 PM
  3. Replies: 0
    Last Post: 03-17-2016, 09:21 PM
  4. Replies: 1
    Last Post: 05-26-2012, 09:29 PM
  5. BMT Turret Live Tool Design Concept
    By selvaraj205 in forum Mechanical Calculations/Engineering Design
    Last Post: 05-26-2008, 04:03 PM
