587,920 active members*
3,348 visitors online*
Results 1 to 3 of 3
    May 2024
    4
    Tail stock movement
    Hi all. I have a xyz ct65lyt running siemans 828d. I'm trying to find a m code to use the hydraulic tailstock to advance to position with a live center. Tried many m codes but nothing moves. Any help would be appreciated
    Thanks Brian
    Dec 2008
    3136
    Re: Tail stock movement
    Under what conditions are you trying to run the M code ?
    Are you wanting to advance the quill or tailstock body ?
    You may not be able to move either with spindle turning
    If via program... it may need to be advanced to a set position before any run command can be executed. Or it may need an addition M code to ignore an alarm condition (ie limit or pressure switch triggered before a spindle start can occur).
    I don't know the codes, we use Shopturn to program a DMG lathe which controls the tailstock body positioning.
    May 2024
    4
    Sorted. Tried for a long time using G and M codes to no avail. Then found in shop turn there is a cycle which is very easy.
