587,443 active members*
3,228 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > what causes realtime board failure?
Results 1 to 4 of 4
    May 2023
    8
    what causes a real-time board failure ? PN: 3-424-2169A03
    the cmos battery is at 3.084v could it be the battery
    bad contacts ?
    or failing power supply?
    Re: what causes realtime board failure?
    Quote Originally Posted by steevgg View Post
    bad contacts ?
    In most cases it is caused by the battery, you can replace a new battery and see if the problem solved or not.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Nov 2013
    4521
    that problem has been reported before. My understanding is that replacing the battery, while required, will not fix it. Critical data has been lost and needs be repopulated before it will run again.
    There are various repair companies whom do this.
    Craig
    Dec 2006
    585
    You can not replace the battery without deleteing the BIOS on the board unless you have a parallel voltage
    MIKE E
    http://cncmachineservices.com
  1. A2100 Realtime board BIOS help request
    By spumco in forum Cincinnati CNC
    Last Post: 04-01-2023, 12:34 AM
  2. Arrow 1500 realtime board problems
    By WrenchX1 in forum Cincinnati CNC
    Last Post: 09-24-2022, 12:54 PM
  3. Realtime CPU Board 2442A02
    By Trutech in forum Cincinnati CNC
    Last Post: 04-17-2021, 04:46 PM
  4. A2100 Control Realtime Board Spares
    By davekensco in forum Cincinnati CNC
    Last Post: 01-21-2013, 04:45 PM
  5. Help on Realtime board replacement
    By sunnybank in forum Cincinnati CNC
    Last Post: 10-13-2009, 08:10 AM
