587,104 active members*
4,174 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Buying my first CNC machine - Advice needed
Results 1 to 1 of 1
    Apr 2024
    2
    Hey,
    I'm looking for help with evaluating the conditions of this Emcoturn 140. It has some rust and comes with no tools, except for the mounted chuck. No manuals/spec sheets included, but the owner has I/O maps. I don't have the opportunity to inspect the machine in person, but I have some pictures and a video.
    Runout test can be seen at 3:10
    Here is a video link of it running:
    https://drive.google.com/file/d/1crF...ew?usp=sharing
    1) Does the spindle or bearings sound okay?
    2) Is rust on the spindle/spindle nose salvageable? It has a D1-D4 camlock system, and I don't know if the rust has creeped inside of the locking holes or not. Would this be repairable if that were the case, or would I have to replace the spindle?
    3) What is a good price for a CNC-lathe in this condition?
    Are there other factors I should consider? I know that the proprietary tools/fixtures are rare and expensive, but the owner told me that is has a D1-D4 spindle nose. So the plan is to make an adapter plate and use 5C collet chuck(since I'll only be working with cylindrical workpieces). I am also considering removing the turret, and make a gang tool setup (and maybe add an Y-Axis).
    All comments and suggestions are appreciated
    Kevin
    Attached Thumbnails Attached Thumbnails 793_175158862.jpg   793_318442174.jpg   793_790336973.jpg   793_898429936.jpg
    Apr 2018
    135
    Re: Buying my first CNC machine - Advice needed
    The 6 photos did not transfer from IndustryArena properly, so 5 are attached here:
    Apr 2018
    135
    Last one:
    Apr 2024
    2
    Extra info:
    The machine is retrofitted to run on Linuxcnc.
    Here is a video of runout test on spindle:
    https://drive.google.com/file/d/1iTd...usp=drive_link
    I also attached some additional pictures showing the condition of the ballscrews.
    - - - Updated - - -
    Extra info:
    https://drive.google.com/file/d/1iTdK7ntIl8cW3uAtecZp558ZZ62kgH2K/view?usp=drive_link
    Jun 2021
    11
    As for LinuxCNC G7x is not safe to use at the moment (early 2024), and probably not on the retrofit with an older version.
