587,837 active members*
3,863 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > pin out pulse coder A860-0360-v501
Page 2 of 2 12
Results 21 to 26 of 26
  1. #21
    Dec 2003
    24220
    Re: pin out pulse coder A860-0360-v501
    That is a synchro resolver it has three windings. used to be used for positioning, but fell out of favour
    Albert E.
  2. #22
    Mar 2013
    47
    Thanks for enlightening me Al... Will have to do some reading...apparently the best thing for reliability and cost effectiveness...
    If you were me(with what YOU know, of course), would you reuse or replace such feedback in this day and age ?
  3. #23
    Mar 2013
    47
    Do you know of any affordable converter / encoder emulator to get ABZ out of a resolver ?
  4. #24
    Dec 2003
    24220
    I have never seen one using a reference, you are better off going to or converting to quadrature encoder.
    Albert E.
  5. #25
    Mar 2013
    47
    How affordable are the ones without reference ? (You meant Z right ? AB should be enough for my application) Any DIY option ?
    Oh, by using a converter to get AB, I will surly loose the Abs feature of synchro resolvers right ? the only thing that incites me to keep them is the Abs no homing feature otherwise, I see no other reason !
    Oh BTW, is there any complex alignment procedure required to reinstall the synchro resolvers after I remove them... if need be ?
    Thanks very much ! :thumb:
  6. #26
    Dec 2003
    24220
    Syncros are quite a bit different than quadrature encoders, they operate with two sine waves, calculating the co-tangent between the two.
    No re-alignment to do.
    Albert E.
Page 2 of 2 12
  1. pulse coder type: A860-0300-T001 2000P
    By rahul.62629 in forum Fanuc
    Last Post: 01-22-2021, 02:04 PM
  2. Lokking for A860-0360-V501 PULSE CODER ALPHA
    By shivisood_24 in forum Fanuc
    Last Post: 05-22-2010, 02:06 AM
  3. Need info on A860 pulse-coder (encoder)
    By jmelson in forum Fanuc
    Last Post: 03-23-2010, 06:08 PM
