587,510 active members*
3,525 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Single or Double Start Ball Screws?
Results 1 to 6 of 6
    May 2009
    1337
    All cnc table top mills I built before they were with RM1610 ball screws single start with 10mm lead. The guy I used to buy these screws closed shop and so I had to find a new supplier (BSTAutomation) who supplies RM1610 with double start, 5mm
    I’m using Mach3, how do I calculate the steps/per in Mach3 when I come to configure the motors?
    Nicolas
    Nov 2013
    4530
    Re: Single or Double Start Ball Screws?
    a double start 5mm screw is the same as a single start 10mm screw. No need to change anything.
    Craig
    May 2009
    1337
    Thank you Craig for the help, happy to know there is no difference but I just remember another possible problem.
    The ball screws I will buy now are for the Y and X axis. For the Z axis I plan to use a ball screw I have from a previous project and is single start, 10mm lead. Is there a problem to have different screws on Y/X and Z axis?
    Nicolas
    Nicolas
    Nov 2013
    4530
    No.
    Craig
    May 2009
    1337
    Thank you Craig
    Nicolas
    Nicolas
    Mar 2024
    1
    Piese auto Ford Mondeo 5 Facelift sunt esențiale pentru menținerea performanțelor și aspectului acestui automobil remarcabil. Fie că este vorba de componente mecanice, electronice sau de caroserie, fiecare piesă este proiectată și fabricată cu precizie pentru a asigura funcționarea optimă a vehiculului.
  1. SINGLE START AND DOUBLE START NUT
    By huongnhat in forum Linear and Rotary Motion
    Last Post: 04-23-2019, 11:26 PM
  2. Single start vs double start ballscrew.
    By darik in forum Linear and Rotary Motion
    Last Post: 03-22-2007, 01:53 AM
  3. Thoughts on single or double screws.
    By LeeWay in forum DIY CNC Router Table Machines
    Last Post: 02-17-2005, 07:00 PM
  4. Single Nut Ball Screws
    By Cold Fusion in forum DIY CNC Router Table Machines
    Last Post: 03-25-2004, 04:41 AM
