587,436 active members*
3,725 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Tool release button override to a user defined M code
Results 1 to 8 of 8
    Jul 2014
    222
    Hello, don't ask me why, but I would like to connect additional wire from tool release button on spindle (Z axis) inside machine and not the one on keyboard to an optional M code relay like this:
    https://www.haascnc.com/service/codes-settings.type=mcode.machine=mill.value=M26.html
    If you understand, I'd like to use let's say M21 to behave exactly as if you press on the Tool release button inside machine (on spindle)...
    I know there is M82 and M86 for Tool clamp and Tool unclamp function, but the problem is it waits for the operation to complete (signal that the machine really did unclamp/clamp the tool). So it does not behave exactly as if you pressed on tool release button.
    Sometimes air valves or drawbar mechanism on this old machine sticks and won't open secondary valve so you have to press it a couple of times so it does (when machine is very cold and didn't work for longer period of time), but I don't want to mess with real problem and fix the machine, I just want to do "simple fix" by making a small program which will do what I manually do when it sticks (press on tool release button as many times as necessary so it unsticks).
    Anyways, the question here is: how to connect this wire to a relay to do what I want?
    Dec 2008
    3126
    Re: Haas Tool release button override to a user defined M code
    Get one of thse "drinking birds" to press the button on the keyboard while you hit the tool with a hammer....
    Or... Fix The Bloddy Machine
    You shouldn't bypass safety designs
    Jul 2014
    222
    Ok, I've tried fixing it, no luck. I tried putting small amount of air tool (compressor) oil to lines, both to machine and left and right of the tool release solenoid. No luck. Then I removed and totaly disassembled tool release solenoid valve and Schroder bellows right next to it, cleaning it and it still does what it does...
    What else could it be?
    Could it be somehow caused by tool release piston assembly and drawbar? Why does it stick like that, when you press tool release button (or a small plastic button on top of the tool release solenoid valve to actuate it) the tool release piston drops down on the first stage, just gets off the upper drawbar limit switch, but doesn't go down to the lower limit switch until it unsticks...
    Heres the video:
    https://youtu.be/8LDrTn5n8vM
    Aug 2009
    1573
    ...turn up the Air Pressure 10-20 lbs
    DJ
    Jul 2014
    222
    Didn't work.
    Jul 2014
    222
    Ok I think I've found where problem lies but I'm still not sure.
    I've noticed that when you turn spindle orient on (M19) little pin (about 12mm in diameter) which signals the machine that spindle is in orient position (by using limit switch with small wheel on top of it which slides on that pin or out of it) releases air through O-ring around that pin...
    I'm not sure if it's enough air loss to cause problems but that definitely doesn't happen on other similar machine.
    I've also disassembled tool release piston, cleaned it, lubricated and reassembled. And I repeated that procedure 3 times. It didn't help at all.
    I've also removed inlet air pipe to air precharge valve on the back of the spindle and poured small amount of compressor fine oil to that pipe, tightened it back and cycled tool release multiple times in order to try to see if something inside that valve was stuck and didn't work properly, but it also didn't help.
    So only thing I'm thinking of doing now is to somehow disassemble this M19 pin with it's block and see if I could clean it and replace O-ring but it looks to me it's gonna be tough to do as there is very little space to remove it and I'm also not certain if it can be removed as I think now.
    It looks to me it's held by 4 bolts on top of that block but I'm not sure if it's in one piece with rest of the mechanism (spindle encoder block and solenoid block)...
    Any advice for this situation would be much appreciated.
    Thanks in advance.
    Jul 2014
    222
    Actually I think I'm wrong although this might be a small problem, but I think it's not causing this because when you just press on Tool release button it doesn't orient spindle and this air loss through M19 block wouldn't be a problem.
    The problem I think now, could be a precharge valve because comparing tool change with other machine where this is working properly, the precharge valve opens first and drops pin down a little (letting it off the upper tool clamp switch) and then main valve opens and drops tool release piston all the way down...
    On this machine when it sticks, the precharge valve doesn't move the pin down immediately but with delay and while it struggles to open it makes a buzzing or humming sound, it moves the pin off the upper tool clamp switch a moment too late, so I think this precharge valve is the culprit.
    Can it be fixed somehow?
    Jul 2014
    222
    Okay I've fixed it.
    First off, I had to totally disassemble TRP mechanism, clean the cylinder and piston thoroughly, polish them (cylinder had smaller scratchmarks on couple of places at the top of travel), lubricate everything using small amount of compressor fine oil and reassemble.
    Secondly, the precharge air pressure was too weak and when I tried to increase it first time I thought I hit the maximum setting but I was wrong, it just was much harder to rotate adjustment knob so I managed to increase air pressure for precharge to a good enough value so it finally worked properly. I'm not sure what was the buzzing sound, I think it was from precharge valve/solenoid but it also could be from TRP as it was unable to move properly, maybe it just vibrated on top of its travel and produced this sound... but anyways when I adjusted the valve correctly it immediately stopped buzzing and now works fine, as it should.
    Only problem which left is with the M19 pin block which leaks air on the O-ring but it seems it doesn't affect tool changes which now go smoothly so I won't touch it at this moment.
    Anyways, thanks for all your help guys!!
  1. Bad crash: Tool won't release, flashing release button
    By CrashTestDummy3 in forum Daewoo/Doosan
    Last Post: 04-04-2018, 02:38 PM
  2. HSD SPINDLE MANUAL TOOL RELEASE BUTTON LIGHT IS.OFF
    By M.Abid in forum Chinese Machines
    Last Post: 08-06-2015, 09:06 AM
  3. Control Panel Tool Release Button
    By l u k e in forum Haas Mills
    Last Post: 06-15-2015, 02:51 AM
  4. USER DEFINED TOOL PARAMETERS
    By fsa in forum PTC Pro/Manufacture
    Last Post: 12-12-2012, 02:47 PM
  5. Tool Release Button,
    By Ken_Shea in forum Haas Mills
    Last Post: 08-05-2003, 02:27 AM
