Hello,
We have a Hitachi Seiki HITEC-TURN 20 SII which uses the Seiki Multi control panel.
We are trying to allow users to import/export programs from a laptop, we have the Putty terminal installed with a USB-RS232 connector and we have tried the following settings (separated by a /) but they have not worked, any ideas on if this is possible and if so what have I gotten wrong?
Putty Terminal:
Speed(baud): 9600 / 4800 / 2400
Data Bits: 8 / 7
Stop Bits: 2 / 1
Parity: None / Even
Flow Control: XON/XOFF / None
Seiki Panel:
Stop Bits: 2 / 1
Control: Used / Available
We are not attached to using Putty so if there is some other terminal interface that works i would be interested in that too, any help is greatly appriciated.
