587,087 active members*
2,793 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc OM Homming Problem plz help !!
Results 1 to 16 of 16
    Mar 2019
    58
    Machine takes the home without touching limit switch . And not gets close to switch .
    Takes home in current position ( any current positon , if i change position and turn off machine and gets back on and make home , its take home in the current position )
    Cincinnati milicron sabre 1000
    Fanuc omc
    Jun 2005
    194
    Re: Fanuc OM Homming Problem plz help !!
    Clean the limit switches.
    JR Walcott
    Georgia Machine Tool Resources, LLC
    Mar 2019
    58
    Quote Originally Posted by Jarwalcot View Post
    the 3 switches need to clean in same time !!! how !!!!
    i need to know parameter related to this problem
    Make sure you do not have any Stored Stroke Limits set. Search your Parameter Manual for STROKE LIMIT, and make sure nothing is set wrong in there.
    Grid Shift Parameters are for 0 control - 508,509,510,511
    Mar 2019
    58
    Quote Originally Posted by the_gentlegiant View Post
    grid shift helps me how ?
    Quote Originally Posted by yurirevenge View Post
    If you have Incremental Encoders. (meaning no batteries in your Servo Drives) Gird Shift will help you set Home Position if lost.
    Try turning on your Control (OMC) while holding down P and CANCEL. DO NOT HOLD DOWN ANY OTHER COMBINATION. This will clear SOFT LIMITS and give the machine a chance to re-Home.
    1) What is the history of this machine with you?
    2) Was it working then suddenly stopped Homing?
    3) Did you loose parameters and this started after reinstalling them?
    4) Does it not home in all axis or only one axis?
    5) Was any of the electronics messed with?
    As was already mentioned... check your limit switches. Seems like your Deceleration Dog is stuck on. Or you have Stored Limits set.
    Mar 2019
    58
    thanks for your reply
    my machine have only batteries to parameter only
    my deives have not batteries
    my all parameter was lost and am making a new parameter collecting from all net
    and when finishing all error and make homing ALL Axies
    i found the machine takes the home in current position without touching any switch
    All hardware like switch or other mechanical an electronic all are well
    all i need now how to delete all homing from machine , and whos parameter is related to makes machine takes homing in currect position
    Have you tried anything I've suggested? Like P CANCEL on Startup and checking into Stored Stroke Limits?
    Grid shift is what you use to set Home on an Incremental Machine. (No batteries)
    Getting Parameters off the Net is not going to work unless you get parameters for a nearly exact copy of your machine.
    Check out this website for help.
    https://www.machinetoolhelp.com/Trou...rnproblem.html
    https://www.machinetoolhelp.com/Proc...eroreturn.html
    Dec 2009
    967
    can you confirm that you have no bits activated in parameters 21 and 22?
    Mar 2019
    58
    Quote Originally Posted by zavateandu View Post
    yes param 21 and 22 is = 0
    Mar 2019
    58
    am try all of this
    an no happen and still take home in current position
    even i change position still takes in current position
    Do the X Y and Z HOME indicator lights light up when you try Zero Return? If not... you're not actually Zero Returned.
    Are you holding the button in the whole time or one push.
    If you have a Mode knob, make sure it's not rotated on the shaft so when you think you're in Zero Return you might be in something else.
    Mar 2019
    58
    that it not a problem man , sure i holding HOME
    i need to reset encoder position
    am sure that is the problem
    Aug 2009
    1573
    ...X2 or replace the micro switches if, possible.
    Another example of some one finding a switch problem was causing a Homing issue.
    https://www.cnczone.com/forums/fanuc...anuc-om-c.html
    Mar 2019
    58
    anyone can help me????????????
    Mar 2019
    58
    ؟؟؟؟؟؟؟؟؟ظظ
