Good day, I would like to connect KFLOP to VFD of the 18000rpm ATC spindle.
I used JP6 pin7 IO28 on KFLOP as PWM output and connected it to (PWM to Analog (0-10V) Converter Module) (example link: https://opencircuit.shop/product/pwm...nverter-module)
When I use the Digital IO screen screen and set the bit HIGH I get the max RPM on my spindle about 600HZ
How should I set the Tool Setup Screen for S on Kmotion so I can use S1000 for 1000rpm, does it need to be in C program or can I do it with DAC option?
If the only option is with C program, can you help me with C program example?
Thank you very much.
Best regards.
Attachment 492810
