587,700 active members*
3,746 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > SETP wrong turret, Froze loading screen
Results 1 to 6 of 6
    Aug 2019
    7
    Hello,
    in SETP (Parameters) window i choose by mistake wrong turret. When i HIT MANUAL to confirm, FADAL froze instantly. I shutdown FADAL for 5mins, and when i turned it up, i can see only FADAL Logo on screen and nothing happens. Cant even get to cold-start screen. Is there a way, to lose all data, and start everything from first steps?
    Oct 2008
    1641
    Re: SETP wrong turret, Froze loading screen
    You most likely short the battery out for a few seconds like a cmos battery it will wipe all the memory and settings. I believe removing the cpu card then removing the RAM card from the cpu board for a few minutes will discharge it and wipe the memory. It seems to have done it each time I've done that.
    There is also a Bat Test button and a reset button on the edge of the CPU card. I have no idea if holding reset will clear the settings. I hadn't found any information about it.
    Aug 2019
    7
    When i press Battery test button, LED doesnt blink.
    When i push restart button, something is happening. But it doesnt change situation.
    Seems, i have to take cards out, like you said.
    Thank you.
    Oct 2008
    1641
    Did you get it cleared?
    Aug 2019
    7
    yes, i did
    Oct 2008
    1641
    What ended up working?
    Quote Originally Posted by Ernis View Post
    yes, i did
  1. Replies: 8
    Last Post: 10-15-2020, 03:43 PM
  2. Replies: 0
    Last Post: 04-14-2020, 03:17 PM
  3. SetP + M60 Brake
    By rwskinner in forum Fadal
    Last Post: 09-15-2019, 04:27 PM
  4. MachOS Tormach Screen Froze and Won't Boot ....
    By twocik in forum Tormach Personal CNC Mill
    Last Post: 08-20-2014, 07:09 PM
  5. Lathe turret loading strategy?
    By Donkey Hotey in forum Haas Lathes
    Last Post: 09-02-2011, 03:52 PM
