587,832 active members*
3,455 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > Announcing Kogna 16-axes Ethernet Motion Controller
Results 1 to 5 of 5
    May 2006
    4052
    2.7GFLOP Kogna 16-axes Ethernet Motion Controller
    https://youtu.be/UDlTK3OzClM
    • On-board Analog
    • Differential receivers and Drivers
    • Hi-Res PWMs
    • RS422/485
    • Relay Drivers
    • More
    Feature Comparison between KFLOP and Kogna
    Attachment 491350
    For more info and to order see Here.
    New software for Kogna/KFLOP
    • Support for both KFLOP and Kogna
    • Projects now compatible with Visual Studio 2022
    • Multi-language support
    • Many upgrades and fixes
    Download Here
    TK
    http://dynomotion.com
    Jun 2013
    1041
    Re: Announcing Kogna 16-axes Ethernet Motion Controller
    I absolutely love kflop etc. This new board looks very promising. I will have to try on soon. As as always thank you for the innovation and support.
    Ben
    Sent from my E6910 using Tapatalk
    Jun 2005
    1730
    Tom, The new Kogna looks interesting. The KFLOP has been pretty solid, but mine disconnects from time to time over the USB port. Using a USB isolator really helped but it still happens from time to time. I noticed the Kogna has ethernet, so does Kmotion and KmotionCNC know how to talk to the Kogna over the Ethernet port as well as the USB port? I love the extra encoder ports which would make adding linear scales to a machine much easier.
    Russ
    Jul 2014
    26
    Looks fantastic. Having some onboard analog I/O will be really useful. I look forward to trying it soon.
    May 2006
    4052
    Hi Russ,
    Yes Kogna uses the Ethernet port for communication at ~10X the data rate than the USB port on KFLOP. The Kogna USB port is only used as a Virtual COM port for debugging, setting the Kogna IP Address and such.
    TK
  1. UC300ETH ETHERNET MOTION CONTROLLER?
    By rmachinist in forum Benchtop Machines
    Last Post: 01-01-2020, 02:51 PM
  2. ETHERNET MOTION CONTROLLER
    By maellaguitars in forum Stepper Motors / Drives
    Last Post: 01-31-2016, 08:03 PM
  3. Is the Ethernet SmoothStepper still the best motion controller for Mach3/4?
    By DingbatCA in forum Controller & Computer Solutions
    Last Post: 12-02-2015, 05:48 PM
  4. Announcing the GM215 Motor/Motion Controller
    By CoAMarcus in forum Gecko Drives
    Last Post: 01-12-2015, 11:14 PM
  5. Ethernet Connection, Motion Controller, Mach3, New !!
    By Robiz in forum News Announcements
    Last Post: 03-28-2012, 04:59 PM
