Originally Posted by
Malish
The feed rate in the program above can not be in in/min. A feed rate of 11.66 in/min would take over 2 minutes to cut a 6x6 square, that is insanely slow. The program I pasted above is with a 2fl. 3/8 compression bit in plywood. AT 18,000 RMP and a chip load of 0.019 (The low end of the recommended load) the feed rate should be around 684in/min, not even relatively close to 11.6in/min.
That was my question, does the MG305 machine program in something else other than in/min like most machines do?
