Originally Posted by
maver1ck
Although your pictures are not conclusive, as mentioned previously it looks like it could be a RT Bios issue. However, as these get older I've also been seeing some boards DOA for various reasons. For example, a power supply failure (especially with all the old/used/refurbished power supplies shops have been buying) or the end user reversing the power connectors can damage the board.
I test/reflash these for shops regularly for a lot less than Fives or Siemens charge, but if the repair is beyond just a new battery and reflash I recommend sending the board to Siemens for repair in most cases.
