587,558 active members*
3,628 visitors online*
Page 6 of 7 4567
Results 101 to 120 of 121
  1. #101
    Aug 2006
    673
    Re: PM45 mill upgrades
    what mill do you have? I'd be interested to know what your depth and width of cut is.
  2. #102
    G0704.
    I'd have to look up the DOC, off hand I'm thinking it's around .25". I'm working with about 1hp, so it's nothing crazy, but my mill is working pretty hard at that point anyways.
  3. #103
    Aug 2006
    673
    Getting things dialed in a bit more...at the cost of my TAS rougher
    Best i could do before it broke (my fault the tool started to pull out of the TTS) .7 DOC x .08 WOC @ 5000RPM and 75 IPM (4.2 MRR). It's looking my spindle motor is going to be the weak spot going forward.
    https://www.instagram.com/p/BhzqAOqFZpg
    Also got the coolant container installed and air lines run. I'm almost ready for some projects!
    Next up is linear rails for the lathe!
  4. #104
    Aug 2006
    673
    So I did a thing today...Finally got my power draw bar installed and working!
    I had to machine a new draw bar, which is ok the original one was VERY loose in the spindle bore which audibly threw thing off ballance when at higher RPM. The new one just barely fits, and in fact i had a surprise step down in diameter on the inside of the spindle bore which i had to account for.
    Installed and ready for testing:
    It's alive!!
    https://www.facebook.com/26967417639...858642621/?t=0
  5. #105
    Dec 2015
    46
    Any updates? How are your gas springs holding up?
  6. #106
    Aug 2006
    673
    she's working good so far although i have yet to do any heavy cuts with it yet.
    struts are fine I've had them on the mill for a few years now.
  7. #107
    PM45 mill upgrades
    Can someone help with the 220vac hook up in the power box? I bought a pm-45m at an auction but the main feed was disconnected and I cannot find a manual. Thanks in afvance
  8. #108
    Aug 2006
    673
    contact Precision Mathiews. Their customer support is top notch and I'm sure they can get you up and running.
  9. #109
    Aug 2006
    673
    Finally got the doors on the enclosure installed!
    Also finally got the flood lights installed.
    up next is to revisit the power drawbar. I think it's time to go hydraulic as I've had a few tools start to pull under heavy loading.
  10. #110
    Wow doesn’t that put size into perspective? I think this is why many don’t attempt this because they don’t have the extra mill. Finding one to assist without breaking the bank funding the project is the other.
    Quote Originally Posted by CS900 View Post
    OK! well now that Christmas is past and I'm done playing Santa with the mill it's time to get on with the upgrades! First step...disassembly. This was nearly a day long project itself.
    And in case the previous pictures didn't give it away she's getting a full set of linear rails!
    So a little bit of clearance was needed on the saddle. I only took about a 1/16" off of one side to get it to fit. Sure is nice to have another mill to help along the way:
    In an effort to keep everything mostly square right out of the gate i'm using the original dovetails to align the master rail. A combination of precision ground barstock and height gauges are used to ensure the master rail runs parallel to the dovetail.
    After drilling and tapping the first hole manually I made this trick drill bushing to make sure all the other holes are concentric with the rail holes. Works like a charm, and I'm super happy I took the time to make it. The slave rail was then installed by using the new saddle plate and bearings to set the distance and parallelism.
    Foreshadowing what's to come
    but not yet...Major clearance issues with the table and the bearings! I tried to capture it the best I could but the table is hovering about a 1/8" away from the rail
    clearance was needed! Also...the point of no return!! Also...thank goodness for power feeds!!!
  11. #111
    Aug 2006
    673
    yeah, the 45s are good size machines for home use. For anyone looking to do something similar you should look in your area to see if you have a local makerspace. You can always get a months membership, make your cuts and you'll be on your merry way. of course there's always the tried and true method of showing up to a local machine shop near break time with a 6 pack and watch it magically get done...
  12. #112
    Oct 2013
    543
    Just make sure when you show up at the machine shop at break time with the sixer that they machine first...then guzzle. Makes for a better job!:cheers:
    Stuart
    "THE GRIZZ" photo album - https://goo.gl/photos/yLLp61jooprtYzFK7
    Youtube - https://www.youtube.com/channel/UCT2lq9obzEnlEu-M56ZzT_A
  13. #113
    Curious how well yours machines parts? Depth of cut?, speeds, etc... in hindsite would you have gone bigger blocks knowing you machines dovetails anyways? I have the room for 30’s on my 833t but the Y axis ends up a little more complicated. To prevent travel loss I would need to run rail extension supports off the base of the casting otherwise it’s doable. My casting is worn already less than two years so I don’t care what I machine off as long as nothing thins out. Thinking 15’s or 30’s would prevent rigidity loss from the dovetails. Curious to hear or see a video link of your machine running. Fortunately I have a 20x40 bed mill I can easily machine up base and column. The other thing is an aluminum saddle seems like it may not be as rigid and dampening as using a cast iron block. Already spending the money what’s $200 more?
  14. #114
    Aug 2006
    673
    the rails are not the limiting factor in any way. The rigidity of the column is the weak spot.
    the saddle is more than sturdy enough being aluminum. Yeah i could have spent more money on a cast iron piece, but i'm not looking to hold tenths, nor is this mill capable of that. I can hold .001-.002 all day, which is more than adequate for anything I do.
  15. #115
    May 2017
    25
    Have you posted your drawbar and belt conversion anywhere?
  16. #116
    Aug 2006
    673
    I don't believe that I have. I'll try and get something together tonight for everyone.
  17. #117
    Aug 2006
    673
  18. #118
    Aug 2006
    673
    Been a long time since I made any updates to this thread, but I recently finished the latest addition. A 5 axis trunnion table...
    There are 2 harmonic drives that provide the rotary motion. For those that are not aware, they are about the only way to truly get 0 backlash with a gear reduction.
    The C axis is belt driven thru the frame. Not a great design, but I wanted to keep the stepper away from the table as much as I could
    the belt just has a 3d printed cover keeping all the chips out
    It needs a few little upgrades, but works quite well as is. Surface finish is pretty good, no wired vibrations in the system.
    Not sure how to embed videos but....
    https://i.imgur.com/iti7T3Y.mp4
  19. #119
    Pretty cool! I built a trunnion for my G0704 and got tired of messing with it and ended up scrapping it.
    Yours seems to work better than mine did. Though the designs were nearly identical.
  20. #120
    Aug 2006
    673
    what isues did you have?
    I spent a LOT of time getting everything dialed in square/flat and getting steps/angle correct before I made a single chip. It still has some quirks. I need to reinforce the C axis table a bit. I get a bit of deflection when doing drilling operations. The first drill i tried was super dull and made it very apparent the flex it had. haha.
Page 6 of 7 4567
  1. Fix for Noisy/Hot Mill-Turn Spindle (& other upgrades)
    By n1tr0 in forum Shopmaster/Shoptask
    Last Post: 09-16-2016, 06:33 PM
  2. MILL TURN UPGRADES
    By smallblock in forum Shopmaster/Shoptask
    Last Post: 02-03-2016, 08:23 PM
  3. Replies: 2
    Last Post: 12-21-2015, 11:31 PM
  4. Bridgeport Mill Rebuilds Repairs and Upgrades
    By 2SQIndustrial in forum Bridgeport / Hardinge Mills
    Last Post: 10-21-2013, 08:21 AM
  5. Opinions on the PM45 M Mill or ???
    By skray775 in forum Benchtop Machines
    Last Post: 11-24-2011, 07:48 PM
